gearbox oil
Submitted: Thursday, Jul 21, 2005 at 22:00
turnitup
Can you tell me what grade oil & how much is needed to change the oil in my gearbox & transfer case in a 80 series manual as I've been told it could be running the wrong grade oil, as it is hard to sellect first & notchy when going to second & third or is this normal as I've never owned a landcruiser before. Cheers Dave.
Reply By: Member - Bill S (NSW) - Thursday, Jul 21, 2005 at 22:18
Try Hd 75 grade and see what the result is,
mine has done over 460,000 ks and no problem with the gear change. Also check you fuel usage and report back later
on this post.
Regards BILL
121528
Reply By: J.T. - Friday, Jul 22, 2005 at 00:31
Turnitup, There is some gearbox oil called vmx80.Works
well on hard shift synchros.Put it in our troopy gearbox only and is good.Makes shifts smoother.We put 80w/90 gear oil in the transfer case.Good luck.
121540
Reply By: Member - Davoe (Widgiemooltha) - Friday, Jul 22, 2005 at 01:41
Sounds normal to me pretty average g box from memory use 75 - 90 g box oil and 80-90 t-case
121541
Reply By: Member - Jezza (NSW) - Friday, Jul 22, 2005 at 11:39
Try this lube guide from Castrol, it gives suitable oil and volume. Valvoline and Shell have similar features on their web sites.
Jezza
!MPG:7!!MPG:7!
121581
Follow Up By: Member - Jezza (NSW) - Friday, Jul 22, 2005 at 11:41
DOH, sorry about the double pictures!
376750
Follow Up By: cokeaddict - Friday, Jul 22, 2005 at 14:21
Jezza..u mean it was an honest mistake ?
Damn and here i was trying to pick the 6 different tings in it
376768
Reply By: Member - Jezza (NSW) - Friday, Jul 22, 2005 at 14:27
Hi cokeaddict,
Let me know how many you can spot - I'll be very interested. LOL
Jezza
121603
Reply By: Toy_Hilux - Friday, Jul 22, 2005 at 19:22
Hi Turnitup,
We had the same problem with our 80series manual and at first we were told that it was the wrong oil, started running straight 80 grade oil and still no change. The gear changing got progressively worse so Toyota evenutally pulled the gear box out and found that the first, second and third mesh gears had worn with a lip on themm therefore catching shift change gear. They replaced all the sync gearing and also found that the ball and yolk on the clutch had also worn. Replaced the hole lot under warranty (160000ks on clock) Since then the vehicle changes smoothly and is totally different to drive, it is a dream to drive!
121643
Follow Up By: turnitup - Friday, Jul 22, 2005 at 22:08
Hi Toy_Hilux was yours repaired under new car warranty as
mine is a 96 model 80 series thats only done 168000ks. Cheers turnitup.
376846
Follow Up By: Toy_Hilux - Friday, Jul 22, 2005 at 23:36
Turnitup,
No. We purchased our 94model second hand with 132000ks on the clock. Then 4mths after purchased, we noticed that it was sticky between changes 1, 2 & 3. This got prgressively worse as time wore on and was in and out of the workshop for a while because we kept saying that there was something wrong with it. Then after about 6mths of complaining, they decided to do something about it. By this time though, our 6mth warranty had run out. They found then that it was the clucth that they replaced earlier was faulty. They then proceeded to do replace this and give us our vehicle back. I took it back to them the next day with the gear worse between 2 & 3, it was actually crunching during change (it gave a new meaning to a crash box). They then proceeded to pull out the gear box and found what the cause was. Toyota were very good to us on this occassion as they said it would take them 3 days to repair it. After the third day they rang us up to come and pick up their demo vehicle as it was going to take them 3 weeks to get the parts from overseas. Didn't mind running around town in a brand new camry, but it did put a dampener on our week-end getaways. In total we had had the vehicle almost 11mths (10 driving), clock up almost another 30000k, and they said not to worry about the bill, it is a warranty job.
376864
Reply By: 120scruiser - Friday, Jul 22, 2005 at 20:34
Correct oil is
Mobil 424 fluid.
Caltex brand is Textran.
Wack this in and you will never look back.
121668
Reply By: Member - DOZER- Saturday, Jul 23, 2005 at 14:45
Gday
General consensus on 80scool.org is an oil called Castrol vmx-m (m is for mitsubishi...they had a similar problem) it is a 75/80 i believe and as i said, most people on that list are using it with their notchy boxes, and have tried many others b4 hand. Thats not to say all the above oils will not work better than what you have at the moment....just that...
well you know about free advice.
121747
