Wide track Jack - 285/75/16 anyone?
Submitted: Thursday, Jul 28, 2005 at 15:42
ThreadID: 25136 Views:1780 Replies:4 FollowUps:1
Hi All
Is anyone running 285/75/16 on a widetrack Jack or and Jack really. Looking at putting some bigger muddies on. Currently have 265/75/16.
thanks for your help
Ads
Reply By: Member - Tonester (VIC) - Thursday, Jul 28, 2005 at 16:02
I *think* I remember seeing them once on a Jack in an auction house. Can't exactly remember, but they were sizable.
AnswerID: 122563
Reply By: Leroy - Thursday, Jul 28, 2005 at 16:10
I think you will find that a body lift is in order to squeeze that amount of rubber under the guards without rubbing. When I was researching around I found an Isuzu forum with heaps of info in the States www.4x4wire.com.
Leroy
AnswerID: 122567
Reply By: Member - Bradley- Thursday, Jul 28, 2005 at 19:04
check out the expeditions west site for the details on their trooper, they run that rubber but it does give a bit of rub.
But dont forget ya crazy bugger you will need to lay out about $800 - $1000 for a set of trans case gears to bring the gearing back in line as it will be really overgeared and you wont be able to pull the skin off a custard.
Whats next? the alpine developments 6psi blower kit !!
AnswerID: 122596
Reply By: Diamond (Vic) - Friday, Jul 29, 2005 at 13:13
crazy our jack has 2inch lift and i tried some 285s at the tyre place looked like there would be alot of rubbing.
AnswerID: 122709
Follow Up By: Member - Crazie (VIC) - Friday, Jul 29, 2005 at 14:49
Ta Jim
FollowupID: 377902
