4.2 fuel consumption
Submitted: Sunday, Jul 31, 2005 at 20:42
magilla
Hi all, I own a '92 4.2 injected GQ patroll with 270,000 clicks on the clock. It's been lifted body and
suspension and has 33's on it, trouble is that I used to get about 600 k's out of a
tank (90 litres) and that was after the mods were done however that has droped dramaticaly of late so that I now get about 350 k's, no one seems to be able to find out why. Any hints about where to look would be apreciated.
Reply By: Voxson (Adelaide) - Sunday, Jul 31, 2005 at 20:49
Well,,, the 33's will give you the odometer reading to appear that you are travelling less kms for your dollar.....
And if you have fitted a roof rack since doing all your original testing then that will be robbing you also...
Roof racks are WOEFUL.....
123054
Reply By: Jimbo - Sunday, Jul 31, 2005 at 20:51
Mr Gorilla,
600 km's out of 90 litres is 15L/100km. That is unusually economical for a 4.2 GQ. They are more likely to use 20. My 1992 3.0L GQ used to use 20 and my old man's 4.2 (1992) used a little more.
Given the bigger tyres (assuming you haven't had the speedo corrected) 350 km's would possibly be a genuine 400 km's or more out of your 90 litres which sounds fair to me.
Jim.
123056
Follow Up By: Uppy - Member - Monday, Aug 01, 2005 at 19:27
Hi guys, Ive got a 1994 efi 4.2 gq which is very much std, Im currantly getting 600 ks per
tank.I dont use a roof rack,and on trips Im loaded to the roof as we travel with the hold family 3 boys 2dogs,1 wife,sorry I cant say why your gq is using so much petrol.One thing has just come to
mine ,I only use pulp petrol in
mine
regards uppy
378276
Reply By: prado_95 - Saturday, Aug 06, 2005 at 17:06
A couple of things to consider;
1. your speedo is probably out by about 7%
2. your (effective) gearing has changed taking the engine away from its peak torque
3. you have more air drag as a result of the lift and wider tyres
So you a likely getting 375km per
tank, better but not good.
Whats the compression like, and are the valves seating properly?
124092
Reply By: Truckster (Vic) - Saturday, Aug 06, 2005 at 17:24
Yea everyone is sayin ya speedo is out this is out this is bigger, but those things arent going to make your truck worse by close to 50%
15/100 IS a good run for a TB42- the poll on the GQ list vast majority were 18/100 or worse..
What have you done so far to fix the issue?
Filters?
- fuel etc?
- timing?
- servicing?
- air filters - what sort are you running
Borrow a set of 31s for a day, see what happens.
124096
