AnswerID: 123268 Submitted: Tuesday, Aug 02, 2005 at 00:51
Sand Man (SA)
replied:
jfr,
If you still can't make up your mind why not try a prepaid phone.
A Nokia 2112 CDMA phone can be purchased outright from Telstra for $89 including $10 call credit.
It doesn't use a Sim card so you just activate the assigned mobile number and away you go. If you decide you don't need your GSM Mobile at any time, you can swap your mobile number over to the CDMA. Or, keep and use both.
The GSM is handy if you are travelling overseas as only GSM has International Roaming.
I selected the 2112 CDMA as it is the same size and configuration as my 6610i GSM and both fit in and work from the same car cradle. You can use a proximity coupler to an external aerial which will suit both the CDMA and GSM phone.
Even though technically the aerial is slightly "out of tune" for a GSM phone, by installing a Laser Hi-Gain CDMA Antenna I have found the reception to the GSM (when used in the car kit) to be superior to the "through glass" antenna I used before.
The coupler is not listed as an accessory for the CDMA but it definitely works.
Using the phone in country areas and observing the signal strength improvement when connected to the external aerial, it is quite obvious.
Decisions, Decisions!!!
 Click Image to Enlarge |
| HooRoo !
I'm diagonally parked in a parallel Universe! |
Reply 8 of 14
