AnswerID: 9300 Submitted: Wednesday, Dec 04, 2002 at 00:00
P.G. (Tas)
replied:
G'day Chris, have I had experience with Gas Magnums! I purchased a set at a "good" price for my 100 series RV. Installed them in 20 mins, drove to the back
gate (about 30 metres), reversed back to where I was and put the old ones back on! They were dreadful! With out a word of a lie, in 30 metres I suffered motion sickness! I returned to my supplier (Repco), told my sad story and they were marvelous. They gave me a 1800 number for Monroe Tech Support in S.A. The Tech support told me they were aware of the problem with the 100 series and shipped over another "extended" set that had different (stiffer) valving. Huge improvement! I went off on my expedidation through
central Australia (about 7,500km) and when I returned the rear shocks were knackered! They had been battered by flying stones off the front wheels and severely dented around the bottom (the original shocks had a steel plate welded around the front for protection). These Gas Magnums also fit the 80 series and I'm told it's not a problem with those because the shocks are mounted behind the axle. Anyway, the damaged shocks (pair) were happily replaced by Repco under warranty. Since then I have done another 10,000 or so K's without a drama. Would I use them again? Probably not, but that is my personnal preference, would I buy from Repco again? Definately! The problem I encountered with the 100 series is simple to explain. Toyota use very soft springing in the 100 series with very high pressure Tokico shocks to control thr ride. The original Gas Magnums were low pressure and thus the horrible body roll. I replaced the original springs at the same time as I replaced the rear shocks and the result is very pleasing. Hope this helps, Cheers!
Reply 3 of 6
