Section Image
Inverting balljoints. D.I.Y
Submitted: Tuesday, Aug 02, 2005 at 16:43
Dan
have read a few posts on inverting upper balljoints after fitting bigger torsion bars.
Can someone run me throu the process, or explain exactly how it works?
I'm fitting new torsion bars to my Rodeo and was wondering if i should do it. preferably D.I.Y
thanks
Dan
ThreadID: 25289 Replies: 5
Views: 618 FollowUps: 2
AnswerID: 123372   Submitted: Tuesday, Aug 02, 2005 at 16:50
Willb replied:
Hi Dan, give this site a glander.
link text
Will
Reply 1 of 5
AnswerID: 123374   Submitted: Tuesday, Aug 02, 2005 at 16:53
Member - Crazie (VIC) replied:
Hi Dan
Read the two forum treads attached
http://forum.australia4wd.com/index.php?showtopic=1083
http://forum.australia4wd.com/index.php?showtopic=45
LC200 V8 - and loving it!
Click Image to Enlarge
Reputation built on character
Reply 2 of 5
AnswerID: 123418   Submitted: Tuesday, Aug 02, 2005 at 19:24
Member - Nick (TAS) replied:
I dont know if this will work on a Rodeo but I on my 4 Runner I fitted a ball joint spacer,a one inch alloy spacer between the ball joint and upper control arm.I'll try and find a link if you like.
Our Camps - Mainland Australia
Reply 3 of 5
AnswerID: 123443   Submitted: Tuesday, Aug 02, 2005 at 20:51
Member - Toonfish replied:
im not sure its recommended?
ask nic or anyone from the forum get together from big desert this year
lol
Reply 4 of 5
Activities Index
Full Day Fly Fishing Tuition - Judbury, TAS Full Day Fly Fishing Tuition - Judbury, TAS
Hobart - TAS
Our introductory Fly Fishing classes offer comprehensive instruction in essential fly fishing skills
Tandem Skydive Weekend - Picton Tandem Skydive Weekend - Picton
Sydney - NSW
Try Sky Diving in the only self contained, purpose built Skydiving Centre in Sydney (Picton).
Twin Island Escape Day Cruise (Option 1) Twin Island Escape Day Cruise (Option 1)
The Whitsundays - QLD
Explore two Whitsunday Island destinations in one day, Daydream Island and Long Island.
Sydney Highlights Scenic Flight Sydney Highlights Scenic Flight
Sydney - NSW
Experience the unique beauty of Sydney from a luxurious seaplane.
Jet Boat Sydney Harbour Adventure Jet Boat Sydney Harbour Adventure
Sydney - NSW
Jump in a Jet Boat and discover the magic of Sydney Harbour as we race past all the Harbour icons; w
Indian Head, Neck & Shoulder Massage Indian Head, Neck & Shoulder Massage
Sydney - NSW
Indian Head Massage (or Champissage) has been practiced for over 5000 years!
3 Day Cradle Mountain Experience 3 Day Cradle Mountain Experience
Devenport and North-West TAS - TAS
During our walk you will explore the fragile flora, observe timid wildlife, be humbled by the hars
Highlander Food Trail Tour Highlander Food Trail Tour
Cairns and Tropical North Queensland - QLD
A day of sightseeing with Food Trail Tours explores the varied landscapes and what local food &
Sports Car Platinum Drive Day Sports Car Platinum Drive Day
Sydney - NSW
Visit the Harbour Front at Wollongong and enjoy a scrumptious 3 course meal.
'Shipwrecked!' Sound and Laser show
Great Ocean Road - VIC
Step on board a 19th-Century sailing ship as it sinks in the boiling seas off Victoria's wild shipwr
Book Now - Things To Do
AnswerID: 123459   Submitted: Tuesday, Aug 02, 2005 at 21:51
Leroy replied:
Hi Dan,
You don't actually invert the ball joint. The upper ball joint is mounted through the uppper control arm. You can remove it and mount it under the upper control arm. You can also place a spacer between the ball joint and the control arm. What this does is give you the ability to adjust your camber when you wind up your torsion bars for more lift. I personally have don't this and don't really recomend it. In the end I broke cv joints and always had them 'clicking' a full lock. I would recomend winding up the torsion bars a little say 30mm or this in conjuction with the 'ball joint flip' as it's commonly called but you wouldn't need the spacer for such a mild lift. Would n't worry about the torsion bars unless you have a steel bar and winch. Would consider better shocks though.
Leroy
Reply 5 of 5
FollowupID: 378582   Submitted: Wednesday, Aug 03, 2005 at 14:11
Dan posted:
Leroy, i'v just had the new 'West Coast Suspension' heavy duty torsion bars and shocks fitted, and still dont have a great deal of clearence, im thinking of winding them up more, but would this mean my camber would be out? if so would you then recomend the ball joint flip?
The guy who fitted them for me said he didn't wind them up all that much. cheers
FollowUp 1 of 2
FollowupID: 378624   Submitted: Wednesday, Aug 03, 2005 at 17:34
guzzi posted:
with a 30 to 40 mm lift just "flipping" the ball joint will be sufficient to keep your wheel alignment in spec.
Putting a spacer in will allow you to crank your bars higher, but it does have a downside.
Downward wheel travel is reduced as you're now very close to the bump stop, CV angles are now getting quite steep and CV and CV boot wear now will be a problem.
Boots are easy enough to change but it is a PITA.
While you're changeing the boots on your CV's and repacking them with clean grease you'll notice that the whole shooting match is held together by a 1.5mm thick ring clip, the higher the bars are cranked the greater the load on this massive bit of accountant engineering. When this fails things fall apart. Limit your lift to 30 to 40 mm and you minimise this.
Cranking your bars right up and cutting the bump stops almosts guaranties CV failure.
have a look on planet isuzu and the outer limits (gmh/isuzu) sites and do a search heaps of relevant info there.
FollowUp 2 of 2
