Suspension upgrade for 100 series
Submitted: Tuesday, Aug 02, 2005 at 22:08
ThreadID: 25303 Views:2592 Replies:7 FollowUps:1
G'day all.
I am in need of some advise, I need to improve the rear suspension of my 100 series diesel cruiser but do not wish to raise the vehicle. Have been down that road before and now that I am over all my extreme 4 wheel driving am just looking for a suspension kit that will give me better towing characterics when i pull my trak shak. As it is when I am loaded up, cars coming the other way at night think I have my high beam on. By the way, yes the load in the trailer is even it's just all the gear I also carry in the back of the cruiser.
All the kits I have seen so far raise the vehicle too much for what i want as I am happy with the front end so need to keep the rear end at standard hieght.
Any advise would be appreciated. Bootha.
Reply By: Woobla (WA) - Tuesday, Aug 02, 2005 at 22:17
G'day Bootha,
Check out thread 25301
Jeff
AnswerID: 123465
Reply By: Leroy - Tuesday, Aug 02, 2005 at 22:18
polyaires? Firestone airbags? Pumpem up til the rear is level. Not as sexy as a 4" heavy duty lift lol!!
Leroy
AnswerID: 123466
Reply By: fozzy - Wednesday, Aug 03, 2005 at 07:32
bootha
airbags is go as most upgrades springs give an increase in height as well
also the lights from 100 series straight off the factory floor shine to bright/high and bleep off other drivers either oncoming or sitting in front of you.
may need to adjust down a bit
fozzy
AnswerID: 123489
Reply By: Member - MrBitchi (QLD) - Wednesday, Aug 03, 2005 at 09:07
King Springs make standard height replacements for most vehicles.
AnswerID: 123512
Reply By: wheeler - Wednesday, Aug 03, 2005 at 10:15
I had Old Man Emu std height springs fitted in my old 100 series. Was very impressed.
AnswerID: 123524
Follow Up By: hazo - Wednesday, Aug 03, 2005 at 13:28
I had similar problem, I fitted set of pedders springs ,went to pedders and explained the problem and got uprated set slightly higher than standard but only by about 40mm and perfect when 2.5 tonne van on back, vitually no rear end sag at all and all for $175 , note I fitted them myself.
Cheers brian wa
FollowupID: 378570
Reply By: Member - Paul T- Thursday, Aug 04, 2005 at 16:35
Bootha
I have the TD 100 series.
King Springs (standard height but larger spring diameter), koni shocks and polyair bags. The konis are a little expensive comnpared to others but have done 110,000 klms with no probs.
AnswerID: 123816
Reply By: Bootha - Friday, Aug 05, 2005 at 22:28
thanks one and all, have found a local dealer for king springs and they are looking good for the job.
Thanks again everyone, Bootha
AnswerID: 124024
