Idle-up switch in FJ60????
Submitted: Wednesday, Aug 03, 2005 at 16:38
fj60inOakford
I know this is gonna sound dumb, but...
What is the "Idle-up" rocker switch in my 60 supposed to do? Doesn't appear to increase the revs, has no mechanics connecting it to the carbie (at least none I can see). It's not mentioned in any of the manuals I've bought or the owners handbook in the glovebox.
OT - Why do we still call them gloveboxes? Can't ever remember seeing one with a pair of gloves in it. :-)
Reply By: Member - Jeff M (WA) - Wednesday, Aug 03, 2005 at 16:49
I thought they only had idle up's in Diesels?
123609
Reply By: garrycol - Wednesday, Aug 03, 2005 at 17:48
Most cars have an idle up switch for when the A/C is switched on - but it is connected to the A/C system and activates automatically - dunno about a manual switch
123623
Reply By: muzzimbidgie - Wednesday, Aug 03, 2005 at 19:13
The idle up for aircon is called "fast idle", which is activated by a vacuum hose on the carby.
An idle up switch is more likely to be for keeping the revs at about 1200 rpm for running a PTO or charging batteries when stationary.
123654
Reply By: theshadows - Wednesday, Aug 03, 2005 at 20:28
Muzz has it right.
The idle up only increases the revs about 300 rpm. how ever with constant tuning the carbs get ill adjusted.
have a look for the vacuum switch on the passengerside wheel arch. Make sure it still works when you hit the switch. then all you have to do is follow the vacuum line to th carbie and re adjust the arm so it increases the idle when you hit the switch.
shadow
123670
Reply By: ellmcg - Wednesday, Aug 03, 2005 at 23:53
Great! One less 'dumb question' I have to ask!
123722
Reply By: fj60inOakford - Thursday, Aug 04, 2005 at 11:53
Thanks to all for taking the time to reply. I'll check out the vacuum stuff on the weekend.
123777
