Fitting a Winch
Submitted: Thursday, Aug 04, 2005 at 21:47
ThreadID: 25364 Views:3958 Replies:7 FollowUps:6
Now this is a dinkhum question.
I can get a winch at a very good price but do not want to add the expense of a bullbar.
Has anyone, or do you know of a way, of fitting a winch to the chassis rails without a bar?
Surely it's possible?
Jim
Reply By: Member - Howard (ACT) - Thursday, Aug 04, 2005 at 21:54
Jimbo , what vehicle
easy on a landcrusier just get a big piece of checkerplate run from chassis rail to chassis rail. front crossmemberr to engine crossmember. use the tow point bolt points and any other captive nuts you can get into. mount winch to checkerplate , weld up a angle ironframe for rollers.
have had this on 45. 60 and 80 series no probs
Howard
Resigned to Retirement
AnswerID: 123880
Reply By: Wayne (NSW) - Thursday, Aug 04, 2005 at 21:57
Jimbo,
A heavy plate could be bolted to the chassis rails and the winch could be fixed to it, but the bumper bar will have to go. This is a problem when it comes to the vehicle complying to ADR,s.
You got the winch cheap and a winch bar from the Trading Post should not be hard to find.
Wayne
AnswerID: 123882
Reply By: Utemad - Thursday, Aug 04, 2005 at 22:03
On ARB winch bars the winch mounts in the bar. However going from memory on TJM bars the winch mounts seperate to the bar in a cradle. Could be worth investigating.
AnswerID: 123885
Reply By: Member - 'Lucy' - Thursday, Aug 04, 2005 at 22:26
I'm pretty sure 'jerrycans' don't have chassis rails
AnswerID: 123890
Follow Up By: Truckster (Vic) - Thursday, Aug 04, 2005 at 22:48
what about garbage cans????
Jimbo - just buy the bullbar
FollowupID: 378873
Follow Up By: Member - Duncan W (WA) - Friday, Aug 05, 2005 at 19:54
oh but they do.
dunc.
Dunc
FollowupID: 378974
Reply By: 4X4Treker - Friday, Aug 05, 2005 at 01:25
Jimbo
As said before depending on what type of vehicle depends on the type of mount that you can use.
On my old GQ Patrol I had an aluminium bull bar so I simply use a C channel that went behind the bull bar 180mm x 75mm x 5mm with two plates welded onto the ends with the bolt holes drilled to match the mounting holes in the chasic rails. Just had to cut the correct size hole in the bull bar to allow the cable and flare head.
This worked with no problems and I was able to remove the bull bar without removing the winch if I needed to work on the vehicle.
I think from memory that the Warn web site shows a cradle mount as in the States quite often they mount them this way.
Treker
AnswerID: 123900
Reply By: Member - Roachie (SA) - Friday, Aug 05, 2005 at 09:43
Something else that no one has mentioned yet Jimbo, although Wayne touched on it with his thought about compliance..........air bags!!!
I have seen plenty of cobbled-together arrangements on older 4bys which did not require a bullbar. But with todays compliance regs etc, I reckon you'd have to bite the bullet and get a proper bullbar (even a Smart Bar would be okay if you're worried about weight).
Roachie
AnswerID: 123930
Reply By: fatz - Friday, Aug 05, 2005 at 12:52
Jim, as I posted on the other site this morning, it can be done. If you're in Sydney send me a pm on the other site and I'll give you the number of a company who will do it for you. If you're willing to have a go yourself, I'll give you a hand.
AnswerID: 123955
Follow Up By: Jimbo - Friday, Aug 05, 2005 at 20:41
Thanks Crack A,
Can you email me at jimbest at internode dot on dot net
Unfortunately I'm in Melbourne, unless you want to come down, I won't be able to take you up on your kind offer of help.
Any ideas of how to do it will be appreciated.
Thanks,
Jim.
FollowupID: 378981
Follow Up By: awill4x4 - Friday, Aug 05, 2005 at 22:48
If you can come up with a design Jimbo, I could weld it for you and I don't live too far away from you either.
I'm in Berwick as well :-) (southside quite near the car yards)
Regards Andrew.
FollowupID: 378994
Follow Up By: Jimbo - Saturday, Aug 06, 2005 at 07:20
Thanks Andrew,
I'll have to give it some serious thought and check out any ADR issues.
Jim.
FollowupID: 379007
Follow Up By: chump_boy - Thursday, Aug 18, 2005 at 11:36
Fatz,
You couldn't let me know the details of that mob that does the mounting cradles, could you?
My email is budgieboy at fastmail dot com dot au.
Chump
FollowupID: 380434
