How to tow???
Submitted: Wednesday, Aug 10, 2005 at 09:13
Grazza
Hi folks,
I have had very little towing experience (i.e. the most complex has been takeing the old 6x4 full of rubbish down to the local tip) and am about to jump right into the fire by towing our new camper trailer around Aus! We leave on Jan 1st and will be away for at the very least, a year...so firstly, sorry if this is a silly question, but I would like to know if there is a specific "method" to try and use when towing? Im mainly refering to gear choice, brakeing etc etc. The tow vehicle is a SWB 4.2L diesel Patrol.
Any advice would be greatly appreciated.
Grazza
Reply By: Member - Rene (QLD) - Wednesday, Aug 10, 2005 at 10:44
Hi Grazza
We tow a 6m van everywhere without a hitch behind 4.2 cruiser, you didn't mention if it had any braking system as this will obviously make a considerable difference, I assume it has so as long as you allow for extra distance when stopping and following other traffic, that should be ok, and tuning corners if the camper is longer than you are used to allow a wider turn area.
Most towing is common sense, just keep an eye in your mirrors and allow extra room for braking, the heavier the load the longer it will take to stop and the longer the load the moor room it will take to turn, the 4.2 will take it any where
Rene'
124575
Reply By: stevesub - Wednesday, Aug 10, 2005 at 10:51
To start off, take it slow until you get enough confidence to know how much extra road you are taking up, how much slower you accelerate, how much longer to slow down, how much slower you have to go on corners, etc. Once you have that confidence, you should be able to keep up with most other traffic over most roads.
Two very important facts though.
1. When turning, your trailer will take a tighter line than your tow vehicle to allow plenty of extra room at the apex of corners.
2. When overtaking, you will accelerate slower than normal, BUT you are also twicwe the length that you used to be so you need heaps more room for overtaking and do not pull in too early.
If you have brakes on the camper, brake as normal and read the instructions for the brake controller. If you have no brakes on the trailer or on very steep downhills, think about using the gears to slow down, saves overheating the brakes.
Change gear early for hills if you think that you will not get up it in top. This keeps your speed up.
If the trailer starts to sway, take you feet off all the pedals and you will find that it will soon stop. If you get the swaying too much, there is a loading problem on your trailer, maybe more weight is needed on the front - but make sure that you do not go above the reccomended towball loading.
Thats all I can think of or now - towing is really a piece of P*** after a few Km and have a great trip.
Stevesub
124579
Reply By: Well 55 - Wednesday, Aug 10, 2005 at 10:52
My advice would be, once you start towing don't try and keep up with the traffic, allow more room for stoping, keep the weight off the tow ball as much as possible and finally enjoy your trip.
Carry spare wheel bearings, pre greased and and ready to install. And regular checks on vehicle and trailer.
124580
Follow Up By: Jimbo - Thursday, Aug 11, 2005 at 07:41
Why would a 4.2L Patrol towing a camper not be able to keep up with the traffic?
379616
Follow Up By: Well 55 - Thursday, Aug 11, 2005 at 11:58
Did I say 'not be able to keep up with the traffic' I thought it was 'don't try and keep up with the traffic'
Use a bit of CDF Jimbo, how much the speed when towing a camper will affect your stopping distance.
My 4.2 intercooled turbo can keep up and ahead of the traffic, but when towing I back off and let the following pass when they can. The electric brakes on the camper will help me stop but I don't rely on them alone.
379632
Follow Up By: Jimbo - Thursday, Aug 11, 2005 at 18:33
CDF?
379685
Follow Up By: Member - Pezza (QLD) - Thursday, Aug 11, 2005 at 19:42
Hey Jimbo, you'll find it means "common dog f$5#k".
Not a real polite answer to your sensible question in regards to a confusing statement IMO.
Well 55,
Why can't you leave a bigger gap between you and the car in front, for extra braking distance, and still "keep up with traffic" at the same time, I did it for years in something that weighs 42 & 62tn.
Avagoodn
Pezza
379697
Follow Up By: Tony F - Friday, Aug 12, 2005 at 19:40
can't say i agree with keeping as much weight off the tow ball, you should have between 10% and 15% of the total trailer weight on the ball other wise she's gona be pig rooting all over the road.
379800
Reply By: Footloose - Wednesday, Aug 10, 2005 at 12:13
Until you have a bit of experience, be vewwwy careful when executing manouvers such as backing :))
124590
Reply By: ellmcg - Wednesday, Aug 10, 2005 at 12:35
I think the important points have already been covered, but I would just re-inforce some of them:
1 - electric brakes - marvellous invention and
well worth the money
2 - reversing - find a large flat area to practice before you leave for your trip, and stick to either mirrors or looking over your shoulder - switching between the two methods only causes confusion!!!
124597
Follow Up By: Member - Blue (VIC) - Wednesday, Aug 10, 2005 at 12:46
re: reversing... I got a hold of some
orange witches hats(in my youth) and took the missus to a local shopping centre over a couple of evenings. Had her backing in a straight line from one row of parks thru the next and eventually into the
park on the third row. Also had her reversing thru 90 degrees. Took her a while, found low range a very useful tool for her to build confidence.
379500
Follow Up By: Well 55 - Wednesday, Aug 10, 2005 at 13:22
For reversing, use the side mirrors and place your hand on the bottom of the steering wheel. Now if you want the trailer to go left that is the way you move your hand, with pratice it becomes easy.
The other thing we do is the navigator is outside with a hand held UHF, so tune both to the same channel and listen to what you are told, (says the wife).
379502
Follow Up By: Member - Karl - Wednesday, Aug 10, 2005 at 16:33
I agree with the reversing - get in as much practice as you can.
In the Army I was taught to put my vehicle in Low 1st to reverse and take it slowly - has always worked for me. Just remember to take it out of low when you have finished.
Remember the lenght of your vehicle with trailer attached - particulary if you overtake someone.
I also like to sit on 100 kph when towing - just gives that little bit of extra space when required.
Practise short runs with your trailer on and remember when you service your vehicle (ie fuel, tyres etc) don't forget your trailer.
379527
Reply By: Member - Trevor R (QLD) - Wednesday, Aug 10, 2005 at 12:57
Grazza,
Find an empty
carpark with line marks for the
parking bays and try to reverse and drive through these marks. The biggest thing with towing is knowing where the trailers
wheels are and being able to put these
wheels where you want them to be. This can only come with practice. Empty shopping carparks make great practice areas.
Towball load is reccomended to be 10% of trailer mass so load trailer appropriately or swaying and the like will occur. Especially with SWB tow vehicle.
I would suggest to tow in 4th gear max (no 5th) but talk to a gearbox specialist for the reasons why or why not. It won't make that much difference to fuel consumption but may save thousands on a gearbox rebuild.
Other people have already mentioned braking and turning distances so I won't add to what has already been said on these topics.
Anyway find your confidence and have a safe and happy trip.
Regards Trevor.
124605
Follow Up By: Member - Jeff M (WA) - Wednesday, Aug 10, 2005 at 14:10
I'm glad someone bought up 5th gear!.
Yeah I would be very cautiious with 5ht, being a camper it may be ok to use 5th on
long flat sections at higher speeds, but as soon as it starts to labour, put it back in 4th, otherwise you will damage the gearbox. 5th is an overdrive and is a smaller cog than 1:1 (4th) it's not designed to be laboured in.
379511
Reply By: dock - Wednesday, Aug 10, 2005 at 14:57
Grazza
Keep an eye in your rear view mirrors for other traffic and if you get a line of vehicles behind you try and find a spot to let them overtake you,especially if you are towing in hilly country.This courtesy wiil allow you to travel at your own pace and will be greatly appreciated by other road users.We find travelling at 95 kph with the camper trailer really helps with the fuel consumption and gives a bit more room for error but you get the consquence of traffic build up so you have to allow those behind the chance to get around.
124622
Reply By: Member - Jezza (NSW) - Wednesday, Aug 10, 2005 at 15:47
Hi Grazza,
There is some good advice on this site under the "vehicle rquirements" tab. I am not sure where you are, but Great Divide Tours in
Braidwood NSW offers off-road camper trailer courses - no doubt other operators have similar courses.
Jezza.
!MPG:7!
124630
Reply By: Shaker - Wednesday, Aug 10, 2005 at 15:55
Many years ago when I first started towing trailers, the best advice that I got was ... don't worry about it, unless the trailer overtakes you!
124631
Reply By: Lyds - Wednesday, Aug 10, 2005 at 19:28
Some other tips:
make sure your Patrol has sufficient lift so thats you can connect up to the trailer and still be able to lower the jockey wheel
get into a routine to hooking/unhooking to make sure everything is connected/disconnected e.g. make sure you lower and secure the jockey wheel before separating from vehicle
be extra aware of ignorant drivers; I can't believe the number of people who
spot I'm towing, see the larger gap and decide to zip in front of me with no allowance for breaking distance
available parking is limited, be prepared to walk a little further
the
places that you can go can also be limited ie 3 point turns don't work like they used to and you can't always reverse yourself out of trouble.
get wheels that are like the ones on your 4WD
124668
Reply By: Member - John (QLD) - Wednesday, Aug 10, 2005 at 20:42
It is important to practice emergency braking (locking up the wheels) at the local shopping centre. Start slowly and build up to a good "slam on the brakes". You will now how vehicle and trailer reacts and which way things may pull, left or right .
You must be confident braking heavily when the time comes and not hesitate.
Also EVERY time you hitch up, walk around the whole caboose to check things - what this really does is slow you down so you check and double check everything throughly.
Be always mindful of where the trailer is, we saw some poor chums scrape there lovely new Teardrop on a bollard in a service station.
Don't be in a hurry.
124687
Reply By: ian - Wednesday, Aug 10, 2005 at 21:06
Grazza,
on a different part of the same topic......
learn how to re-pack the wheel bearings
carry spares such as a wheel bearing kit and some grease
carry a couple of spare wheel nuts
run the same wheels as your Patrol
Use LT tyres with plenty of tread
have a great trip
Ian
124692
Reply By: Member - Duncs - Thursday, Aug 11, 2005 at 10:27
Grazza,
I have been towing a camper for a long time, most of it with a 4.2Diesel Patrol.
I found that the car was happiest just under the 3,000 rpm mark. That is about 100 to 110 kph. It would happily do more than this so overtaking is quite safe, just remember what others have said about acceleration and the length of your vehicle
If you are at this speed then as soon as the slope starts to slow you down grab 4th and keep your foot a little off the floor. On bigger hills don't let it labour in a any gear or it will be more likely to overheat. Go to a lower gear and lift the foot a bit. On steep decents go down the
hill in the gear you would need to get up it and you will be able to leave the brake pedal alone.
Make sure the trailer is level when coupled to the car. You can easily adjust the height of the coupling by about 50mm by turning the tounge of you towbar up the other way, ie the tounge comes up and out rather than down and out. That's as clear as mud. If you have a hayman reece type tow bar the removable bit is a box section with a heavy L shaped piece welded on the end. By turning it over the taab tha you fit the coupling to is at the top of the box not the bottom and the coupling height of the trailer is about 50mm higher. This can make a big difference to the comfort in the tow vehicle as it better distributes the weight and improves vision over the top of the trailer, if you have any vision at all, some do some don't.
If you are going to be towing off road I recommend that you go to your favourite 4wd track and try it with the trailer on. Take a mate in case you get stuck.
Finally don't worry too much, it's not rocket science and after a couple of days on the road, or track, you should be having a ball.
Duncs
124750
