Diesel Vehicles Freezing in the Snow
Submitted: Wednesday, Aug 10, 2005 at 16:17
TerraFirma
Go Auto news has published an article re the alarming amount of new diesel vehicles that have had to be towed off the snow mountains recently due to the diesel in their tanks being frozen. There has also been much discussion re the solution and the cause of the problem, the diesel fuel in Australia, the use of an Alpine Blend that may contain heater oil etc etc . I read this article back to front and heard everybodys storys , what is the practical solution..?? It occurred with both European and Japanese vehicles and gum contained in the diesel was often the blame. It was costing $200-300 to tow the vehicles off the mountain and theb mechanics were having to de-freeze the vehicles with large inudstrial heaters and often having to replace filters etc.
What is the recommended approach/solution to this problem...?
Reply By: Member - Karl - Wednesday, Aug 10, 2005 at 16:24
Move to WA, there is no snow here. LOL.
When I lived in the ACT and we went up to the snow line we used to put in the Alpine blend and never had problem.
124633
Follow Up By: Kiwi Kia - Wednesday, Aug 10, 2005 at 21:37
It was below zero one night in
Perth recently and that is low enough to have wax problems with diesel !
379587
Reply By: OtherBrother - Wednesday, Aug 10, 2005 at 16:33
TerraFirma,
Check out the info provided here on BP Web site , particularly the "Winter Diesel Problem Summary" document.
124636
Reply By: Member - Mozza (NSW) - Wednesday, Aug 10, 2005 at 16:43
as you can tell from teh Rig Pic.. i like the snow. my car is petrol so i don't have the problem.. but comments as follows >>
as mentioned above, the use of 'alpine' diesel helps alot with the 'non-freezing' of diesel in tanks...
i think the problem only occurs when the cars are left in the snow overnight or for longer periods (say 2-3 days) of time.. which allows both the snow to come in contact with the fuel
tank.. getting it colder quicker.. and hence hepliong the freezing cycle...
soution 1 - use alpine diesel
solution 2 - move to WA as mentioned above
solution 3 - buy a petrol 4by
solution 4 - don't leave your car 'in' the snow for long periods of time (atleast start it every afternoon)
solution 5 - if visiting perisher blue in nsw.. drive your car to
bullocks flat and catch the skitube !..
124639
Reply By: See You - Wednesday, Aug 10, 2005 at 18:26
diesel can gel in 15 minutes if it is cold enough outside. It is caused by the fuel getting cold and turning to gel. It very rarely occurrs in the fuel
tank itself. It usually only occurs in the fuel lines between the
tank and the engine due to the thin volume.
The solution is really simple. just fill up with Alpine diesel just before you get to the entry to the resort. You will need to have about 75% of the
tank Alpine diesel so travel on a near empty
tank and fill up at the last town.
I am sure that a lot of diesels are gelling up in Victoria at the moment as it is snowing down to sea level.
124654
Follow Up By: Member - Jeff M (WA) - Wednesday, Aug 10, 2005 at 18:40
Yep,I've got photo's of snow in Tarralgon today!
But I'm a firm believer in the other solution,
Move to WA.
Acutally no, we don't want all you buggers crowding us out, stay in the snow! ;-)
379540
Follow Up By: Member - Chrispy (NSW) - Wednesday, Aug 10, 2005 at 18:44
Exactly!
Get to the nearest town (
Cooma,
Berridale or
Jindabyne for the NSW skiers) and fill up on Alpine diesel. Make sure you do a fair number of kilometers to get it through the fuel lines.
If tou run a common-rail diesel like I do - then it's DOUBLY important to make sure you do this, as injector pressures are up around the 23,000psi mark and they don't appreciate sludge for breakfast the next morning.
379542
Follow Up By: fisho64 - Thursday, Aug 11, 2005 at 18:10
Wow those pressures are high Chrispy? I assume you are talking about an EFI diesel? Never had much to do with them but most conventional (mechanical) diesels run between 2000 - 5000 psi (130 - 400 bar)
379684
Follow Up By: Member - Chrispy (NSW) - Thursday, Aug 11, 2005 at 18:49
Fisho -
These are the new common-rail diesel injector pressures - and
mine, being "second generation" are now quite low at 1,586 bar. The 3rd gen pressures are up around the 26,000psi (1,793 bar) mark.
Take a CRD for a spin - you'll swear it was a petrol motor - and a good one at that.
Chris
379690
Follow Up By: fisho64 - Thursday, Aug 11, 2005 at 23:02
Havent really taken much notice of that technology as I have never had to work on them. What I was getting at more was that common rail does not necessarily mean electronic, and I hadnt come across any mechanical pump using those sorts of pressures.
379728
Reply By: Member - Nick (TAS) - Wednesday, Aug 10, 2005 at 18:52
Plenty of snow about in Tassie today.
An old Rodeo I used to have gelled up the fuel in a small inline fuel filter I had in it but not from snow but one of Tassie's great Frosts.Vehicle was parked under a tree and about 5min on way to work she conked out.Went bac in my lunch break , fired it up and away I went
124661
Reply By: herkman - Wednesday, Aug 10, 2005 at 18:54
Mercedes Benz, in the operators handbook for the ML270. lists the amount of keresene that should be added to avoid this problem.
In Europe this is their solution to the problem.
Col Tigwell
124662
Follow Up By: Member - Chrispy (NSW) - Wednesday, Aug 10, 2005 at 19:06
Yep - same goes in my Jeep manual. Same engine! :)
379547
Follow Up By: Ted (Cairns) - Wednesday, Aug 10, 2005 at 19:53
I'll second that. Iveco in their (truck) manual in Europe says up to 50%kerosene in diesel depending on temperature. I forgot the exact proportions, but 50% was like for -35 degC or so - I'd keep to max 20% kerosene for ski trips here.
When kerosene was not available we used petrol (10% or so).
Better still, you could find bottles of additives at most petrol stations - pour it in the
tank, do another 30km to mix it and fill the fuel lines, and that's it.
Very cold mornings and "untreated" diesel: wood fire under the
tank - I've seen it done on trucks, would NOT recommend though. Plus heating up the filters with steam, hot
water etc.
I don't have these kind of problems any more though - here in
Cairns;-)))
379552
Reply By: Member - Geoff M (Newcastle) - Wednesday, Aug 10, 2005 at 20:06
Many years ago Toyota sold a diesel additive that "converted" summer mix diesel into winter mix, among other benefits. Not sure if it's still available.
When I left for the snowy I'd add it in the prescribed amounts. My 2H Troopy spent many a week in
Perisher Valley (yes, it was winter) with both tanks quarter full of diesel bought in
Newcastle without problems.
Geoff.
| Geoff,
124676
Follow Up By: rolande- Thursday, Aug 11, 2005 at 22:10
Was in Suoercheap yesterday, they had brochures on the fornt coutner from Shell, one of the bottles of you-beaut stuff for sale was an additive which is designed, "to help cold weather starting and running"
May be of use, other than that add about 5% unleaded to the
tank
Rolande
379724
Reply By: Jimbo - Wednesday, Aug 10, 2005 at 20:28
Surely there must be a simple fix to this that is used in Europe.
Europe has an extremely high % of diesel vehicles and a large portion of Europe is under snow for months on end. Do they use different fuel? What is in it that makes it work?
The thought of adding kero or petrol (they are much more volatile than diesel) would worry me if I owned a diesel. You would be changing the chemical make up of the fuel. But what would I know? Just thoughts.
124682
Reply By: Leroy - Wednesday, Aug 10, 2005 at 20:44
What can I add to my split air con unit as it's freezing up as I type lol
Leroy
124689
Follow Up By: gramps - Wednesday, Aug 10, 2005 at 20:53
Petrol or kero should brighten up your night ..... :-)
379577
Reply By: Steve - Wednesday, Aug 10, 2005 at 21:04
this might scare one or two of you, but in England you'd see truckers light a little fire under the truck. The more cautious would carry a little parrafin heater.
124691
Reply By: Tim HJ61 (WA) - Wednesday, Aug 10, 2005 at 22:27
Chilly night in
Perth tonight - it's 9 degrees...... Might have to turn the heater on.
I remember seeing a TV show about a guy going to all the extreme
places in the world. The trip to the coldest place meant they lit a fire and heated not only the fuel
tank but the diff, axle bearings, any moving part, with a flaming torch. I 'think' it was an air cooled diesel engined vehicle they were driving. Seemed to 'fire' up okay with all of this. Battery must have been pretty good too.
Tim
124710
Reply By: Trekkie - Wednesday, Aug 10, 2005 at 22:59
Karl, Goeff M & Tim
Stop telling all the Easterners about our secret state
If they all come over here we will not be able to go bush without being inundated by them
Keep it to ourselves
124720
Reply By: arthurking83 - Wednesday, Aug 10, 2005 at 23:47
Yeah! all diesel owners should move to WA (the ski season is very short though!)
Why would you have reservations about adding kero to diesel, especially if Mercedes recommend it!
Another solution would be................Don't go into the alps during the snow season!
How easy is that?
124727
Follow Up By: Alloy c/t - Thursday, Aug 11, 2005 at 18:40
Short ski season !?? c-ap ! all year round [
water ski that is ] LOL.
379686
Reply By: peterll - Thursday, Aug 11, 2005 at 02:13
Had to smile at this thread. Being an ex-pat now living in Canada I couldn't understand what the fuss about diesel was all about.
Our new
home is in that part of Canada where the average winter temps are minus 25 C. and on a few days we get a little chillier at minus 40 - 50 C. With that and the altitude of some 2000m I have yet to see a diesel vehicle having problems with fuel
Diesle 4bys are very common here. I never thought about some of the problems mentioned. I might run down to the local Petro Can (petrol station) and ask them just what is in the fuel sold here in winter.
How I wish Toyota would let me import an LC or even a Troopie. Some deal they have globally about moving new vehicles from one country to another grrr.
But we get to come
home each year and wander around
the desert so I suppose things aren't that bad.
124728
Follow Up By: Nudenut - Thursday, Aug 11, 2005 at 08:02
when you come
home peter make sure you leave the 0 to -25> there!
If you bought a toyota here Toyata couldnt stop you from taking it back?
379618
Follow Up By: See You - Friday, Aug 12, 2005 at 13:29
You wil find that in Canada they run the same fuel all year. Its just their "version" of diesel. Different chemical make up than in Aus
379765
Reply By: Nudenut - Thursday, Aug 11, 2005 at 08:21
had the same problem with a cascade refrigeration system making 7 ton of liquid S02 (sulpher dioxide). The wax in the oil solidified in the low temp -70c evaporator which would block the refrigeration circuit...simple solution changed to an compressor oil that didnt have any wax
never even bothered to think it could happen to diesel......but I'm amazed that we (austrailia) have different diesel fuels to combat this for those areas that are affected by this condition.....wouldnt it make more sense to have ONE fuel (one refinement process) that could handle the worst expected conditions to prevail anywhere in OZ?
Is this learning curve left to trail and error?..... or are we told to never drive this car to mt hotham this when purchasing a diesel vehicle in say
Darwin? if your not told by manufacturer that is a condition that can arise then i'd be asking for tow and defrost fees
124738
Follow Up By: Ted (Cairns) - Thursday, Aug 11, 2005 at 12:07
Re same fuel/refining process: I think it's a bit like with oils: a very thin one for extremely low outside temperatures won't do your engine too much good at +40 degC (I have never seen engine oils with viscosity index 60 in europe - never higher than 40). Diesel with a lot of kero burns perfectly
well at -10, but may burn holes in your pistons when it's +40. That's how I understand it, I might be wrong.
379635
Reply By: Member - Duncs - Thursday, Aug 11, 2005 at 09:58
I'm from
Broken Hill and diesel freezing is not much of a problem here, although we do get the occasional 0 or -1 overnight
In the October hols I am planning to take the kids to Mt Buller for a look at the snow. I know that the bulk of the snow season will be over by then but do I have to worry about this (GU 4.2TD).
We will be staying at
Pinnacle Valley which is just near
the entrance to the National
Park. Probably won't take the car up to the ski fields as the resort offers a shuttle bus, but the car could
well sit still for 5 days.
Lastly, where can I get this Alpine Diesel, we will probably travel along the Murray then head south to
Mansfield from
Echuca.
Duncs
124746
Follow Up By: Leroy - Thursday, Aug 11, 2005 at 10:53
You'll get Alpine diesel at
Mansfield. Prob wise to fill up there just incase we have a little cold snap like the one last feb. I saw few vehicles being towed back down the mountain - the weather took everyone by surprise!!
Leroy
379629
Follow Up By: See You - Friday, Aug 12, 2005 at 13:31
Leeroy are you at Buller??? What is it like there??? I may bring the hummer down for a play in the snow.
379766
Follow Up By: Leroy - Friday, Aug 12, 2005 at 15:04
I'm at
Falls Creek. Heaps of snow. Twice as much as Buller.
Leroy
379772
Reply By: peterll - Friday, Aug 12, 2005 at 14:42
ah yes
well Nudenut ... it seems that most of the big manufacturers have a global deal about selling different models in other countries... You can buy an LC here (Canada) but it will be second hand and 15 years old !! Funny how you can buy other Toyotas but not a troopie or an LC (new)
They have Nissan Pathfinders but no Patrol
The F150 V8 4x4 is kind of impressive but only carries half a tonne.
Then they have some really weird rules for importing any vehicle.. to begin it has to be registered for at least 6 months in the country of origin. ...then it has to meet emission standards.. and then it has to meet another standard..and so on.
Should have heard the phone conversation when chatting with Canada Customs about an idea to import a HSV Maloo ute (they had no idea what I was on about)..
well you would have thought I was going to send GM out of business !! :)
oh and you are right Seeyou !!
.. I asked at the local gas station umm garage ..whatever.. diesel is diesel all the same, all year round here.. although they do add stuff to the petrol in our part of Canada in winter.
124928
Follow Up By: Member - Toonfish - Friday, Aug 12, 2005 at 16:50
you may
well see a ss version of a storm there soon a mate is looking at a build up of one think he lives in black
rock now .
379791
