Another wheel on rear door
Submitted: Thursday, Aug 11, 2005 at 13:31
ThreadID: 25519 Views:2317 Replies:11 FollowUps:8
simple question.. (hopefully get a simple answer too - not likely on here though!)
on the rear door of the frontera is where the spare wheel is mounted, is there no reason that i couldn't get another bracket fabricated, which bolts/connects to the existing tyre/bracket, to hold another spare wheel in the same place as the existing ? (if that makes sense? ie: double them up?)
the obvious query is the load rating of the existing bracket, and whether is has the capacity to handle 'another' tyre ?
any thoughts ?
Reply By: flappa - Thursday, Aug 11, 2005 at 13:36
I very much doubt it would handle it.
An example is the Patrols. , the existing wheel can occassionally cause problems , 33's will fit , but have been known to cause problems , and the 35's have caused heaps of problems.
Thats just from going up in size , adding maybe 10kg all up extra.
I doubt a another wheel and tyre weighing , what ? 40kg ? would do the door anygood at all.
AnswerID: 124765
Reply By: Peter Guy - Thursday, Aug 11, 2005 at 13:36
Go To your local ARB outlet who supply and fit the necessary hardware.
Cheers P Guy.
AnswerID: 124766
Follow Up By: Member - Mozza (NSW) - Thursday, Aug 11, 2005 at 13:48
and walk out financially drowned...... no thanks.
p.s. neither kaymar/AR/TJM make a rear tyer carrier to fit the holden frontera.
FollowupID: 379654
Reply By: robak (QLD) - Thursday, Aug 11, 2005 at 13:53
Mozza
I reckon the forces would be too great. The bracket is like a lever. If you go out twice as far you'll be doubling the forces. So the two wheels will exert forces on the bracket and the rear door equvelent to three times the weight of the original.
It might be ok on the blacktop but i don't think it'll hold when off road.
R.
AnswerID: 124771
Follow Up By: Member - Mozza (NSW) - Thursday, Aug 11, 2005 at 13:58
what if I took the lining off the inside of the back door, took off the existing bracket, had a new bracket fabricated (mroe durable, better fixing plates to door etc).. ???
FollowupID: 379656
Follow Up By: robak (QLD) - Thursday, Aug 11, 2005 at 14:21
Well, I guess there's only one way to find out isn't there. Go for it.
R.
FollowupID: 379661
Follow Up By: GaryInOz (Vic) - Thursday, Aug 11, 2005 at 14:36
Take the wheel off the door, open the door and sit on the top of it, as you bounce up and down as hard as you can (eg. 80-90 kg over corrugated roads).
Have you bent the door? Do you really trust your rear door hinges THAT much???
You need a rear bar mounted twin tyre carrier.
Also the leagalities of having objects protruding outside the lines of the bumperbar would need to be addressed (yes, even tow hitches are meant to be removed when not in use.)
FollowupID: 379663
Follow Up By: Member - Mozza (NSW) - Thursday, Aug 11, 2005 at 14:45
comments taken.
gary... though not a very good example because surely the amount of pressure from corrugations when the door is in the CLOSED position, would be totally different from the amount pressure when door is in the OPEN position...
FollowupID: 379666
Follow Up By: GaryInOz (Vic) - Thursday, Aug 11, 2005 at 15:29
You have two hinges and a feeble latch. The latch is not designed as a vertical load bearing element, if it was then the door would droop and drag when ever it was opened, and would have to be "lifted" or "slammed" back into place to align itself on the load bearing part of the body. You have a weather seal around the door because it DOESN'T contact the body, the latch holds the pressure from the seal against the body and obviously holds the door closed (in "tension"), but is not designed to take excessive vertical loads.
Leaving....the two hinges.....
FollowupID: 379669
Reply By: Member - MrBitchi (QLD) - Thursday, Aug 11, 2005 at 14:09
Most models that carry the wheel on the rear door have a variant that wears steel rims. These are twice as heavy as the alloys so the weight should be OK.
Have seen it done on Pajeros but haven't done it myself.
The thing to watch is, as Robak says, the extra weight is further back and therfore exerts a lever action on the door which, over time, could destroy the door.
The bracket would probably be strong enough but is the door?
AnswerID: 124772
Follow Up By: GaryInOz (Vic) - Thursday, Aug 11, 2005 at 14:38
Also may make steering a little bit "too light" from the leverage
FollowupID: 379664
Follow Up By: Member - MrBitchi (QLD) - Thursday, Aug 11, 2005 at 15:41
Don't think there's THAT much leverage involved ;-)
FollowupID: 379670
Reply By: Member - Matt Mu (Perth-WA) - Thursday, Aug 11, 2005 at 15:51
Seriously..wheel mounts break off with one wheel let alone two!
To strengthen the door would add weight and MIGHT stop the bracket destroying the door but you cant strengthen the mounting point of the hinges at the rear of the body!
You WILL end up with a very expensive problem to fix if you get a bracket on the door that will hold two wheels.
There is no cheap way of doing this (why do you think Kaymar exists with their pricing), Im sure the cost of rebuilding you rear end will be more than getting a rear bar and carrier fabricated!!
Matt.
AnswerID: 124784
Reply By: Longreach - Thursday, Aug 11, 2005 at 16:13
I don't think the extra weight and 'leverage' would make the steering light as someone suggested, but the extra weight further back would add significantly to the overall load up back with all your gear as well. Have your thought about just taking an extra tyre without the rim and a bead breaker ? This saves weight and gives you a bit more flexibility to repair as well as change tyres.
AnswerID: 124786
Reply By: Member - Kimberly Kruiser (WA) - Thursday, Aug 11, 2005 at 17:04
Mozza
"the obvious query is the load rating of the existing bracket, and whether it has the capacity to handle 'another' tyre? "
The bracket probably yes.
The door, the hinges probably not.
Legal, more than likely not, obscured vision from angles to tail lights etc.
Would I do it--------------- Nup.
Dual carrier or roof rack!
AnswerID: 124797
Reply By: cokeaddict - Thursday, Aug 11, 2005 at 18:09
Definately not the way to go about it. I inquired about having my bracket modified (Adding an alluminium plate to my spare wheel carrier) so i could mount a 15 HP outboard motor to it when doing weekend fishing trips and was talked out of it. Problem is, Where the bracket mounts inside the door, it is still only supported by sheet metal. Eventually with corrigations, it would crack and spread until something let go.
The idea has been on my mind for awhile but the weight would eventually cause some expensive repairs.
AnswerID: 124813
Reply By: vitara - Friday, Aug 12, 2005 at 10:26
Why not just add a foof rack (basket) and you can throw another two spares on top fairly simple and wont cost the earth, have done that to my hilux now I have 3 spares when i"m travelling just a thought.Have a great day Steve M
AnswerID: 124897
Reply By: at4x4 - Friday, Aug 12, 2005 at 12:37
you could just ratchet strap a carcass to a tyre on an alloy rim on the back, without to much worry, if you really need that 6th spare.
AnswerID: 124915
Reply By: Casnat - Wednesday, Aug 17, 2005 at 21:02
Hi Mozza,
I know this response is a bit late but I just returned from a week away and am reviewing posts since I left.
Much of the talk has been on the strength of the brackets but I suggest you also need to consider the door hinges also.
I did a trip recently up Googs and around the top of Lake Torrens with my GU and another vehicle, a GQ, that had a second casing strapped to the spare on the rear door (I had my spare casing on the roof). Whilst only a casing, the weight was enough that to open the door you had to lift it a little to get the lock to release.
This is just an observation and many people talk about carrying a spare casing there with not many reports of problems. It may have just been some problem for my mates vehicle but worth taking into consideration.
The other thing for me is that the spot on the back of the spare on my vehicle is taken by the rubbish bag.
Trevor
AnswerID: 125650
