Suggested designated UHF channels???
Submitted: Friday, Aug 12, 2005 at 09:32
signman
I put it to the
forum that some system of designated UHF channels be established for 'outback' touring in various areas. Similar to the
Simpson Desert area where most travellers are on the same channel which can come in very handy for safety purposes. I do realize that some groups prefer to have their own chat channels- but most modern transceivers have dual watch to at least monitor whats going on in the area.
I have just returned from a very interesting trip across the Anne Beadell, Connie Sue & sections of the Gunbarrel and of the 5 oncoming parties we met- including 2 solos- all were on different channels.
As
well as the safety aspect (eg "look out for the blind washaway around the mulga tree") it could also advise other travellers of interesting sites and 'where the cheapest fuel is in
Coober Pedy'.
Maybe this would be a good project for the ExplorOz team (as if they haven't got enough to do) or the AN4WD people.
Your feedbak is most welcome!!!
Reply By: howie - Friday, Aug 12, 2005 at 10:21
the subject has been flogged before, but anyway,here in w.a. at least the 4wd clubs and i think the 4wd assoc have tried to promote ch 10 for 4wd's.
it would be nice if all groups/solos used this channel but it does not mean that the absence of chat on ch 10 means that there is nobody hurtling towards you on a blind corner.
most people/groups just scan or have 2 radios.
124896
Follow Up By: signman - Friday, Aug 12, 2005 at 11:23
Thanks howie
Yes, there has been a bit of comment about this topic- but no resolution. However, it appears Ch 10 seems to be a concensus, so maybe it should be promoted more. Of my initial post- all the parties were from WA and none of them on Ch 10.
I do agree that
"it does not mean that the absence of chat on ch 10 means that there is nobody hurtling towards you on a blind corner."- however, the presence of chat on Ch 10 might avoid such an incident.
It should not be just a state suggestion, as we know the remote areas are accessed by all - so a national promotion would be the thing.
379749
Reply By: Member - Tonester (VIC) - Friday, Aug 12, 2005 at 11:51
Reply By: Member - George (WA) - Friday, Aug 12, 2005 at 12:10
Check out this site, explains all.
http://www.acrem.org.au/AUS%20UHF%20CB%20PRS.pdf
124908
Reply By: Member - Jeff M (WA) - Friday, Aug 12, 2005 at 12:13
It depends where you are. When we go to the extremely popular
powerline trek in Sawyers Valley just east of
Perth on a Sunday there is absolutally no point trying to use Ch10 as every 4wd club and their dog is on it. We use channel 10 when it's free but if there is another party on there or it's a long weekend and EVERYONE is on there, we bugger off and use another channel and scan the rest on a second radio.
Basically 40 on the highway, 10 off road is my general rule if your travelling by youself, if theres two or more and your chatting away with midless chatter (which a great majority of us LOVE to do, it's one of the best parts of UHF's in convoy IMHO) get out of everyone's way and leave 10 for other users.
I think scanning is the most simple solution to these woes.
124909
Reply By: Footloose - Friday, Aug 12, 2005 at 12:27
This has been on my mind for many years, having suffered drivers screaming around blind corners in the middle of the track,
sand dunes etc.
One solution that I toyed with was a small beeper box that would emit a beep via your
UHF radio which could be picked up by a UHF that was scanning . This would theoretically indicate the presence of a vehicle somewhere in your immediate vicinity. It would simply be a small box between the mic and the UHF set. This would automatically disengage when the mic button was pressed and have an overide etc.
Advice by the appropriate authorities indicated that despite any safety improvements such a device might
foster, it would be illegal unless type approved, a process costing a fortune.
In the wrong hands I suppose it could drive other drivers crazy :)
Technically fairly simple, but I never did get around to thinking it through. It may even be possible for the beep to be transmitted at a fairly low level to keep interference to a minimum.
No, it wouldnt tell you how far away they were etc.
And since not everyone has or uses a UHF it might just provide a false sense of security.
But every time I hear of a head on in
the desert I wonder why I didn't persue the idea.
A nutty idea ? I still wonder...
124912
Reply By: greydemon - Friday, Aug 12, 2005 at 13:29
There seems to be an obvious flaw here. It has been suggested that everyone use channel 10 for safety reasons, but if you are chatting with your convoy or mates then switch to another channel to avoid hogging the airwaves. You then presumably drive smack into someone who is monitoring channel 10. It has been mentioned that not everyone has a radio - obviously correct, but of those that do I would think that very few have two.
I have no solution, I am usually on 40 on road and 13 or scan off road so I seem to have got that wrong - though I can't be alone because I often pick up others on 13.
Then there are CARAVANS!!!! Many many times I have come up behind a caravan with a
sign on the back stating their channel - usually 13. I have NEVER, repeat NEVER, come up behind one that actually has their radio turned ON!!!
Perhaps all that is required is a small transmitter/receiver of low power and fixed frequency that transmits a beep as suggested above on a dedicated channel outside of the normal 40. Tandy's is currently selling hand held UHFs for as little as $20 so a simple device like this should be pretty cheap. As it would only have a range of about a kilometre or less it shouldn't cause problems. This could be stuck on your windscreen or dash with a sucker just when needed.
124922
Follow Up By: Footloose - Friday, Aug 12, 2005 at 13:52
The problem with using channels outside of the UHF is that you need a both a transmitter and a receiver. UHF's are cheap because of volume production. These devices may not be, another incentive for people not to have them.
379767
Follow Up By: Member - Alan H (QLD) - Friday, Aug 12, 2005 at 19:25
When me and my mates are travelling we try for a channel where no one else is so that we can hear each other. There are various groups with various channels.
Caravans use 18 and motorhomes use 20. We usually stick around the centre 21,22 etc. Relying on others being on a certain channel is false security. We all have to rely on sight in the end. Dune flags and taking it easy over a crest. If a bit of pace is required then someone has to walk it first and make sure it is clear.
Occasional scanning seems to give us notice of others around us and we start to look harder.
In the end, it is our own responsibility to look after ourselves and I for one don't want to see responsibity regulated. We would end up like america and try to find someone else to sue whenever something goes wrong.
Cheers Alan
379797
Follow Up By: motherhen - Friday, Aug 12, 2005 at 19:31
Greydemon - we have a big 40 on the back of our caravan, and it is usually turned on - but i know what you mean - try saying hello to a passing traveller and no response!
379799
Follow Up By: angler - Friday, Aug 12, 2005 at 21:35
Alan H,
looks iike the
greenvale railway on your signature. Drove it the other day.
We use 18 and 40 most of the time, We always try and keep the radio on scanning those two freqs. Also have a
sign on the back "scanning 18 and 40" I have talked to quite a few truckies and vanners over the years.
379813
Follow Up By: Member - Alan H (QLD) - Saturday, Aug 13, 2005 at 09:39
Angler
No the pic is from the road into Woombeyan Caves SW of
Sydney.
Can you drive the
greenvale rail line these days?
379836
Follow Up By: angler - Sunday, Aug 14, 2005 at 16:09
Alan,
Yes the railway can be driven now after you get lots of permissions from the local councils etc. A guide is reccommended as there are some trailbike riders doing the wrong thing (as usual). Slow is the name of the game and care is required in the tunnels and some of the blind corners. Very much single lane traffic only with the occassional area to allow passing oncoming traffic. Gates are locked to prevent illegal access.
Sorry for breaking the thread of the original
forum item.
Pooley
Angler
379892
Reply By: Member - John C (QLD) - Friday, Aug 12, 2005 at 20:18
Ok, say we all use Ch10 or some other channel, but unless you are transmitting every 5 minutes, who is going to hear you?
Large group may transmitt that often, but just one or two vehicles? Doubt it.
As the post above suggests, if it is going to work, every 4wd needs a device to regularly 'beep'.
But then if I am driving that fast I can't swerve to miss some one coming around a corner, or a tree, or slow for a washaway, maybe I am going too fast anyway?
A case of less haste for the sake of speed?
124972
Follow Up By: arthurking83 - Friday, Aug 12, 2005 at 21:36
John C said:
"...maybe I am going too fast anyway?"
It seems the way life is heading! We seem to have so little time and so much to do, that the vast majority have to as much as possible, and hence rush around like lunatics!
A" head on in the bush" just stinks of people travelling way too fast.
Cresting a dune???
Well that is something that is invariable going to happen on a one lane track. Only because people don't seem to be looking around at the surroundings so much any more. A vehicle in the on coming direction should be "visible" from
miles away. So the driver takes an educated guess and assumes it's travelling in the opposite direction! Right?...............Wrong!
The driver assumes that it's another slower vehicle he's catching and instead speeds up to overtake as quickly as possible!!
"The rest (as they say) is history........."
379814
Reply By: Member - Brad G (SA) - Saturday, Aug 13, 2005 at 22:03
I believe a dedicated 4wd channel is must, perhaps ch.10 as a call channel, when away I always scan 5 (Emergency Channel), 10, 11 (Call Channel) and the regional repeater channel. I also always scan the VKS-737 network on HF or if that is fairly busy Ch.2 8022. Not sure what the ultimate answer is but Ch 10 is probably a safe bet if you get into trouble and need help locally.
125058
Reply By: geocacher (djcache) - Wednesday, Aug 17, 2005 at 00:01
Interestingly I think it is the Lands department or some other beauracracy in WA that recommends the use of 40 on the
Canning Stock Route.
It's certainly mentioned in enough of the guides on the trip.
So at the start of the season with four fifths of f. all travellers on the track we did the right thing and sat on 40 and called ahead from time to time.
Met one group coming the other way (morons from Melton in F250 and 100 series with 4 2-stroke motocross bikes and a four wheeler on a trailer they'd already stuffed (?cooked) - oh and they did 2 axles on the trailer in the trip too - looked little better than a garden trailer,) on a channel in the 20's and another tag along group on yet another channel.
Nearly had a head on with the 100 series too - 30 seconds apart at the top of a dune. We weren't impressed. 30 seconds sounds like a long time but when you consider we only saw about 15 vehicles in 2000km I'd say that's a close call. Murphy must have been having an off day.
125498
