Water Tap for Jerry Can
Submitted: Friday, Aug 12, 2005 at 21:54
Phil P
Hi all,
Looking for suggestions/ideas for extracting
water out of Plastic 20L Jerry Cans. I currently use the plastic tap that comes with the jerry can, it works ok, but I'm alwasy worried it's going to break off and leak
water everywhere. Ideally I would like to be able to pump it out from the top lid (without spending a small fortune).
Any suggestions or recomendations would be appreciated.
Phil P
Reply By: Member - John C (QLD) - Friday, Aug 12, 2005 at 22:00
Tried a syphon hose?
124992
Reply By: Member - Phil G (SA) - Friday, Aug 12, 2005 at 22:09
I have it syphon thru a half inch hose thru the lid.
Need to drill a hole in the top of the cap, then widen it with some sort of a reamer, until a piece of the 1/2 inch nylex blue
water hose is a tight fit. Drill a second very fine hole next to it as a breather.
To make up the hose, I use a right angle 1/2 inch barbed connector at the cap, with a piece of hose down to the bottom of the jerry, then another piece of blue hose of whatever length terminating with either a half inch tap at the end, or even better a trigger hose with
the tip chopped off.
You'll need to suck it thru to start the syphon, but after that the
water comes thru fine until the jerry can is empty, provided you keep the trigger or tap below the
water level.
Important to use the blue Nylex hose so no plastic taste. And you can also use a piece of fine tubing for the breather, which will avoid the chance of a few drops of
water escaping thru the breather hole.
124993
Reply By: Member - Ivan (ACT) - Friday, Aug 12, 2005 at 22:18
Reply By: Member - Roachie (SA) - Friday, Aug 12, 2005 at 22:18
Depends how "complex" you want to get and whether you have onboard compressed air supply. If you have a compressor which you can have a semi permanent air hose going from, to the gerry can, then you could follow the above suggestion as far as the hose through an air-tight fitting (don't put the small hole in for breathing purposes) and when you want
water, just turn the compressor on (or if you have a permanent
tank of air under pressure it's easier).
The air pressure forces the
water out of the hose.
124996
Follow Up By: Tessysdad - Friday, Aug 12, 2005 at 22:48
Or even connect it to your spare tyre. Had a VW once and the windscreen washers operated from pressure from the spare. They had it arranged so that you put in 60psi and it ceased to work when you got down to 30psi. If you have a portable compressor you don't need to worry about how low the pressure in the spare gets.
Happy
camping,
Mike and Jan.
379823
Follow Up By: Member - John C (QLD) - Saturday, Aug 13, 2005 at 20:36
Just checked my VW manual in the glovebox.
Pump to 30psi, pressure won't go below 20psi.
Normally enough for a good few washes or emptying the bottle (1 litre).
379861
Reply By: AndrewW - Friday, Aug 12, 2005 at 23:13
Not quite as fancy as a pump, but I have seen people with taps that fit the filler end of the 20lt
water containers. When the drum is upright, it would be very unlikely that an damage to the tap would occur. I have had the small taps at the bottom of the drum come partially out before, lost a lot of
water, and made a huge mess. Now I unscrew the small taps, before travelling, but its a pain to do all the time.
Sadly, I am yet to find a place that sells these though, but I am still looking.
125003
Follow Up By: Member - MrBitchi (QLD) - Tuesday, Aug 16, 2005 at 07:46
You can get them from Pool shops. They sell them as taps for liquid chlorine bottles. Unfortunately they don't fit a jerry.
380115
Follow Up By: Member - Chrispy (NSW) - Tuesday, Aug 16, 2005 at 08:23
We use them all the time. My wife works at a Great Outdoors
camping store, and they sell them. The tap is set into the middle of a normal plastic jerry cap and is very rubust. We use it on the Willow (tha tap is not made by Willow) 10L containers because on those the cap is flat - not angled - which means that when you rest the jerry on its side the tap is pouring straight down - not slightly backwards. All in all, it means that we can store a few jerries together on trips without worrying abount knoocking those sill little screw-in 1/2" taps off.
380122
Follow Up By: Member - Chrispy (NSW) - Tuesday, Aug 16, 2005 at 08:24
I wish that I could type this morning..... :(
380123
Reply By: Member - Duncs - Friday, Aug 12, 2005 at 23:37
We use a supersyphon.
Little marble in a copper fitting on the end of the hose. Jiggle it up and down and the syphon starts.
When the container, billy cup etc, is full we simply put the delvery end of the syphon back into the jerry and it holds the
water in the syphon. Next time all we need do is pull the end out and take it lower than the
water level in the jerry. My kids have been successfully operating this since they were about 3yrs old.
Duncs
125006
Reply By: at4x4 - Saturday, Aug 13, 2005 at 08:20
A caravaning place has small 12 v pumps for around $30, if you dont want to use a sureflo pump, but you can also fit a pull up/ push down caravan pump handle into the lid of a plastic jerry can with a hose off the bottom to the bottom of the container, which means no accidental losses like syphon, or tap off the bottom.
125012
Reply By: Member - Banjo The First (SA) - Saturday, Aug 13, 2005 at 08:35
I'm with ats - I've seen the manual - pull up/push down type caravan sink
water pump mounted in a plastic jerry screw on lid - just extend the pick up with some plastic tube to the bottom of the jerry - somewhat reliable and simple overall I'd say. Just ned a hole saw for the lid work.
125015
Follow Up By: Michael ( Moss Vale NSW) - Saturday, Aug 13, 2005 at 12:36
Yes also a pressurised system on 4x4 acc on ebay 4 jerry cans,, plenty solutions there.. Michael
379841
Reply By: Member - Phil G (SA) - Monday, Aug 15, 2005 at 21:50
I've used the caravan pump in the lid. They leak like a sieve. Thats why I changed the system I use.
125333
Reply By: Phil P - Monday, Aug 15, 2005 at 21:55
Thanks for your replies.
125334
Reply By: Tony Shaw - Tuesday, Aug 16, 2005 at 20:53
HI there Phill,
It's afew days later but if your still looking for a great idea have a look at the pump below.
[ View Image]
It'll also fit directly onto the
water drums and just runs of 2 D cell batteries. It pumps a huge amount of
water on one set of batteries. The switch on top makes it really easy if you've got messy hands as
well. They are around $40 but
well worth it.
Cheers ToNy!
125469
