GU Wheel Studs
Submitted: Sunday, Aug 14, 2005 at 21:16
Pilbara Wayne
G'day All
Had an interesting experience this weekend. Was crossing a dry river bed near
Marble Bar and suddenly an all mighty crash and we stopped. Got out to take a look and the rear right hand wheel is lying on the sand next to the vehicle (undamaged) and the hub is buried to the top of the axle.
A lot of digging, jacking and using LARGE rocks later and the hub was out of the sand but no wheel studs left. Fortunately travelling with another vehicle so sent the "girls" into
Marble Bar, where they managed to get a set from another Nissan Patrol. Checked with the local wrecker and after hearing "yep, they'll fit love" they came back out.
Fitted the studs, put the wheel back on and away we went.
Now, whats the chance that the other studs are the same?? Looks like these ones were weakened a while ago, probably by some over zealous use of a rattle gun.
Should I change them all and keep some as spares in the back?
Thanks for input.
Reply By: angler - Sunday, Aug 14, 2005 at 21:22
Change them, easier now than some other real good spot (NOT)
125165
Reply By: Patrolman Pat - Sunday, Aug 14, 2005 at 21:25
Got a 4Wd club member who had a GU in his tyre
shop yesterday with 9 studs missing/sheared off the back two
wheels ???????????
Aparently he had it serviced last week.
125166
Follow Up By: angler - Sunday, Aug 14, 2005 at 21:29
Dem rattle things do em up tight
hay.
379925
Reply By: Member - John (Vic) - Sunday, Aug 14, 2005 at 21:34
Not a nice feeling I bet.
125169
Reply By: lhall - Sunday, Aug 14, 2005 at 22:36
Never heard of it i wouldn't carry spares and i doubt it was the rattle gun . Most likely they have rattle loose over time. Only need one to start coming loose and the rest will follow.
125181
Reply By: Tessysdad - Sunday, Aug 14, 2005 at 23:14
Hate to be the "dunce" in this post, but here goes. How did you get what was left of the old studs out - did you have an "easy-out" handy or something? Its just not the sort of problem I have ever encountered and it sounds like I need to upgrade the tool kit a little.
Happy
camping,
Mike.
125187
Follow Up By: Pilbara Wayne - Monday, Aug 15, 2005 at 08:00
Tessysdad
Once the wheel was off (which was already done for me) all I had to do was remove the brake caliper and the brake disk. Then the wheel studs are removed by using a hammer.
The new ones fit in from behind, replace disk, replace caliper, tighten the studs into the holes and refit the wheel.
Not really hard, just not the right time to have to do it!
379947
Reply By: bware - Monday, Aug 15, 2005 at 00:21
had the same problem on a troopy a few years back and was told the wheel bearings were the cause with a help-along by over/under-tightened studs. Once corrected you shouldn't need to carry spares
125192
Reply By: Member - MrBitchi (QLD) - Monday, Aug 15, 2005 at 09:42
For the cost of them I'd chuck a few spares in the tool box. You may never need them but someone else might.
If you really get stuck you can take some studs out of the other
wheels, say one from each wheel, to get you going again.
Do you have standard
wheels fitted? Have seen this happen with incorrectly fitting
wheels, where the load is on the studs instead of being carried by the centre boss.
125217
Reply By: Member - Duncs - Monday, Aug 15, 2005 at 10:19
John,
Firstly let me say that you are not alone and it is not a Nissan problem it happens to all makes and models and not just on 4x4s. I had two studs break on the front of a Honda Accord I had borrowed.
I have snapped studs on my vehicle too. Despite what was said above I believe it is related to the use of rattle guns.
The specified torque for a Nissan wheel stud is 80 foot/pounds, not that high really.
Every time I know someone has been at my
wheels with a rattle gun I check them when I get home with a torque wrench. I have found them as high as 130ft/pds.
With a rattle gun no body knows what torque they are putting on. Mostly it is too high but it can be left loose too. Those little torque wrench things that they put between the gun and the socket are at best an estimation. I have come across many tyre fitters who don't even know what the colours mean or which one they should use for which vehicle.
My advice is check them yourself and do it on a regular basis. Oh, carry spares as
well they don't take up much room and are cheap insurance. What would you have done half way down the Canning or in some other remote place where driving for help was not an option.
Duncs
125223
Follow Up By: Member - Collyn R (WA) - Monday, Aug 15, 2005 at 11:21
It's all but certain to be due to overtightening - I never EVER let a tyre fitter tighten my wheel nuts on any of my vehicles - having seen one using the same torque setting for my ex Jimny and my OKA!
Nuts work loose for reasons that few suspect. As this problem paricularly affects camper trailers I've included a whole chapter to it in my forthcoming new book (The Camper Trailer Book) but you can get the general idea for nothing as there's a shorter version on my website: click on 'Articles' - and the 'Nuts and Bolts'.
I think you'll be surprised by the explanation - how they work loose is not how most people suspect! And you'll find it's a very powerful argument for shock absorbers.
Truct this interests
Collyn Rivers
379965
Reply By: GaryInOz (Vic) - Monday, Aug 15, 2005 at 12:33
First question: Do you have alloy
wheels?
Rattlers and alloy rims don"t play
well together. The alloy is softer and more maleable than the studs. What happens is when the alloys get hot (from braking/general bearing heat) the alloy expands more than the stud, potentially overloading the stud (technically, into the plastic deformation region - stretching the thread).
It also can initiate radial cracks in the holes of the rim from the excess crushing forces exerted on the rim (a reason for nuts "loosening themselves" as the alloy contracts more than the stud when it cools). The process is a bit like a logsplitter.
The logical "solution" by most ppls logic is to tighten them up more next time. This is the very thing that is causing the problems in the first place.
125255
Reply By: muzzgit (WA) - Monday, Aug 15, 2005 at 22:38
Last week I had a puncture, the day we were heading off for 4 days up the coast. When I stopped to change the tyre, I checked the wheel nuts on the front tyres (puncture was on the back) and damn they were tight. The brakes were done last week and I know my mechanic uses a rattle gun, so I backed off all the nuts and did them again by hand.
The tyre mob I use, use a tension wrench every time. They are the only people I have ever seen take the time to do it properly.
Here's a free plug for the guys at Ardross Tyres, Canning hwy, Booragoon W.A
125345
Follow Up By: Coops (Kalgoorlie) - Wednesday, Aug 17, 2005 at 21:18
use those guys every chance I get.
They have had a good reputation for years now and apparently it's not unwarranted.
380340
Reply By: Pilbara Wayne - Tuesday, Aug 16, 2005 at 23:55
Thanks for all the replies.
To answer a few questions:
No I dont have alloys, have the original Nissan steel rims. The wheel was on the drivers side, so they should be doing up, not undoing as we move along.
I think I'll get them checked out (replaced) and also have the rear axle checked out. Had some
water in the diff from the rain at
Nullagine a few weeks ago and the clutch plates in the LSD are still making a noise. Might be pertinent to get them, the bearings and everything else down the back checked properly. Somehow it all just doesnt feel right at the moment, but thats just a
seat of the pants feel.
125497
Reply By: cmilton54 - Wednesday, Aug 17, 2005 at 19:55
Not sure what model nissan you have.
The torques are as follows
MQ/Maverick 80ftlb, mq is now listed at 100ftlb, maverick at 80ftlb
GU 100ftlb
out of njoy tyre fitment book
Cheer
Charlie
125630
