Air again
Submitted: Tuesday, Aug 16, 2005 at 17:35
ThreadID: 25644 Views:2969 Replies:6 FollowUps:4
Just got the new SuperC---p flyer in the mail box, 12v air compressor with air tank for $249 ,max air flow 50lt/min,max pressure 100psi ,tank cap12lt, continuous use time 30min ,states 10/12 min to fully fill tank , question is who will be first to buy and road test ,and for the maths gurus ,how many 31x10.5x15 tyres would/should such a unit inflate from flat to 36psi ?? get them calculators working !!
Reply By: Member - John C (QLD) - Tuesday, Aug 16, 2005 at 18:16
Rough calc - 31x10.5x15 is about 100 litres.
For 2 bar (29psi) in the tyre, that is equivelant of 100 litres to pump at atmospheric pressure, or 150 litres to pump for 2.5 bar(36 psi).
(1 bar is atmospheric pressure which is about 14.5psi)
Taking 10 to 12 minutes to pump up the tank with a capacity of 12 litres to 100psi (6.9 bar) says it all. That is about 80 litres of air by my calcs, which you gives you about 1.7bar (25psi) in the tyre. Pump output volume drops as pressure increases too. Your going to wait a while for the other 7 psi to get to 32 psi since it will need to pump about 40 litres of air against the pressure in the tyre. Well, you know what I mean if you are working at atmospheric pressure. Trying to keep it simple :-).
Tank is a good size however for filling one standard car tyre, then waiting another 10 minutes for another tyre.
Those figures sound right?
AnswerID: 125441
Follow Up By: Member - Jeff M (WA) - Tuesday, Aug 16, 2005 at 18:49
Those figures look pretty good, however your basing them on Chinese specs written on the box which mean bugger all. I've seen that compressor and it's got the same compresor mounted to the tank that I had under the bonnet before the Blue Tounge. It's Crap basically. Those figures only count (if that) when the compressor is cold, as soon as it's done a little work it SLOWS RIGHT DOWN. I went through two of them (they crapped themselves) before I chucked it in the bin, kissed my money goodbye and then went and bought a decent brand compressor.
I have a 24L 240V air compressor in the garage and when it's charged to 120psi it barley get's my 31x10.5xR15's from 30psi to 42psi without having the crank the compressor up and start recharging the tank (at about 70psi it kicks in). Even @ 70psi the infalation rate (equalising of the tank and tyre) is very slow.
ie, I'd leave it on the shelf.
FollowupID: 380200
Reply By: Truckster (Vic) - Tuesday, Aug 16, 2005 at 20:34
the place aint called supercheap for nothing and it aint the price.
AnswerID: 125464
Reply By: Member - Brian (Gold Coast) - Tuesday, Aug 16, 2005 at 20:43
$249????
For not quite double that I bought the Ox 12v compressor..... (Paid $400) takes about 5minutes each to pump my 33 X 12.5 Pro Comp muddies from 18psi to 40psi. I originally had a Supercheap unit..... got about 6 pump-ups outta it before it fritzed in a cloud of smoke!
AnswerID: 125467
Reply By: Nick R - Tuesday, Aug 16, 2005 at 22:22
A lot of people selling compressors list a flow rate, I'd say the 50 l/min is the free air flow, many list this, makes the compressor appear better than it is.
you get what you pay for......
NickR
Carpe Cerevisi
AnswerID: 125490
Follow Up By: Ruth from Birdsville Caravan Park - Wednesday, Aug 17, 2005 at 17:44
Shouldn't you be working so the old fella can be on holidays?
FollowupID: 380312
Follow Up By: Nick R - Wednesday, Aug 17, 2005 at 20:27
Ruth,
he is on holidays, they are somewhere on the NSW north coast but on his way home, some committment in melbourne bringing him home early next week.
Believe me, I have been working but if you note the post time of 22:22, I do try to knock off before 19:00 at the moment.
I think they have had a good break this time catching up with EO and other friends, weren't you mean't to be visiting some time???
see ya,
NickR
Carpe Cerevisi
FollowupID: 380328
Follow Up By: Ruth from Birdsville Caravan Park - Thursday, Aug 18, 2005 at 07:48
Yes it was lovely to see them - albeit briefly, but both of them were sick as - with the lurgy -hopefully, the warm sea air in Mackay has made them well again. You are a good boy, Nick, to work such long hours to enable your father to play at his 'other' job in Melbourne!!!! (My other life was in the same business!!!)
FollowupID: 380392
Reply By: muzzgit (WA) - Wednesday, Aug 17, 2005 at 01:28
The big thing everyone is forgeting....these compressors are made for airbrush or paint guns. not mechanical workshops.
I have a compressor which states 70l p/m.
My mate has a compressor which states 70l p/m.
They look almost identical.
His pumps almost twice as fast as mine (18 to 38).
His is a genuine MAX AIR @ $350.00, and mine is a copy @ $149.00
He is finished, packed up, and standing around with a beer in hand checking out the scenery while I still have 2 tyres to go !!!
Once again..... wise old indian saying
GOOD THING NO CHEAP
CHEAP THING NO GOOD
AnswerID: 125503
Reply By: Member - DOZER- Wednesday, Aug 17, 2005 at 06:49
Im happy with my $79 12 cfm Woolworths compresser (tank mounted compresser, on wheels)....looking for an inverter big enough to run it....and somewhere to mount it :-)
Andrew Wollongong
AnswerID: 125506
