engel freeze temperature
Submitted: Tuesday, Aug 16, 2005 at 23:00
ThreadID: 25649 Views:2256 Replies:5 FollowUps:4
was wondering if anyone can enlighten me on the temperature a 60ltr engel gets down to when it is in freeze mode using 240 volts. i want to use it as a freezer at home so i need to know how low it can go.
thanks in advance
Reply By: V8troopie - Wednesday, Aug 17, 2005 at 00:26
A bit of googling found this:link text
Where it says 0 deg Farenheit which equates to -18 deg C.
Klaus
AnswerID: 125500
Follow Up By: Nudenut - Wednesday, Aug 17, 2005 at 07:45
V8 how to post links is at the bottom of the reply page
FollowupID: 380240
Reply By: Peter - Wednesday, Aug 17, 2005 at 02:26
thanks for the link V8. that answers my question. looks like i dont have to buy myself a new deep freezer. cool. now with the money i have saved i can afford to buy some food to put in it. if your ever in bairnsdale drop in for a free feed. its the least i can do.
actually i couldnt even think of how i was going to do an internet search. the brain was in a non functioning gear. lack of sleep i think. so thanks for being my brain on this one. i have the fish now if only i could learn to fish.wouldnt need to really on others for info. and to think i have the rods and reels just sitting there gathering dust.
peter
AnswerID: 125504
Reply By: ExplorOz Team - David - Wednesday, Aug 17, 2005 at 11:48
V8troopie posted this followup
oops, havn't figured out how to post a link yet, obviously.
here is the long version:
Here is the link embedded.
The origiinal reply was removed as it caused the screen to require vertical scrolling due to the URL length.
AnswerID: 125549
Reply By: Member - Brian (WA) - Wednesday, Aug 17, 2005 at 21:05
Peter. My 40lt gets down to -19 on 12volt useing the engel thermometer with the probe clipped in the middle at the top. cheers brian
AnswerID: 125651
Reply By: Member - MrBitchi (QLD) - Thursday, Aug 18, 2005 at 08:22
It will probably get cold enough but will also probably run the motor more than it should. I'd say they're OK to use as a freezer for a short period but they're more designed to be used as a fridge.
IMO, using it permanentely as a freezer may considerably shorten the life of the motor.
AnswerID: 125696
Follow Up By: TroopyTracker - Thursday, Aug 18, 2005 at 15:11
G'day there MrBitchi,
You may be right re motor life but I've had my 40 litre on freeze for last 3 years-constantly and it hasn't popped yet!!
Cya
Matt
FollowupID: 380458
Follow Up By: Member - MrBitchi (QLD) - Friday, Aug 19, 2005 at 07:52
Sweet ;-)
FollowupID: 380552
