WINCH OR DIFF LOCKERS
Submitted: Sunday, Aug 21, 2005 at 19:34
gforse
HI GUYS MISSUS AND I ARE OF TO GULF AND CAPE NEXT YEAR WE HAVE A 99HILUX DUAL CAB WOULD LIKE SOME ADVICE ON FITTING A WINCH OR DIFF LOCKERS OR IS IT BEST TO HAVE BOTH WE DO NOT WANT TO OVER DO IT THANKS FOR ANY ADVICE KAREN AND GARRY
Reply By: Haza - Sunday, Aug 21, 2005 at 19:45
Diff locks are great but might get you into more trouble as your confidence grows. Then you'll need a winch. Though with a winch you'll need some to attach it to etc. tree. I'd go both if the money was there. Remember a winch will need a compatible bar. Also most winchs are not
water proof and will require servicing as the diff locks don't really need much maintance. Another point is that you can always remove the winch and add it to another vechicle when you decide to sell your current fourby.
126204
Follow Up By: Rob from Cairns Offroad Training & Tours - Monday, Aug 22, 2005 at 13:47
You don't NEED either. I have been up and back to the Cape more times than I care to remember, no lockers no winch, all the way along the OTL sometimes have to bypass gunshot which is not a problem you can still drive in and watch the heros wreck their vehicles. Save your money and buy more usefull everyday useable accessories. Cheers Rob
380925
Reply By: Footloose - Sunday, Aug 21, 2005 at 19:46
How long is a piece of string ? :) I could say (and no doubt be taken to task by others) that lockers only get you into trouble, a winch helps you get out of trouble. Of course that's not the whole story. If the track is wet you'll wish you had lockers. If you're stuck in a
creek or river you;ll wish you had a winch.
I suspect that it depends on exactly where you're going, and what you intend to do there. Basically if you stick to the main drag you almost certainly won't need either.
If you do need help and stand on the track for 10 minutes you'll probably get run over :))
126205
Reply By: Truckster (Vic) - Sunday, Aug 21, 2005 at 20:17
One will get you into chit one will get you out of it.
lockers will drive you further into the crap, and once stuck, your fubar.
IMHO go the winch first.
126212
Reply By: Member - Roachie (SA) - Sunday, Aug 21, 2005 at 20:50
I've got both and before I fitted the diff lock to the front of the Patrol, I always said that they were something that would only help get me 100 meters further into the shyte than I would've got without them.
Now that I've got it, I can honestly say that there is only one occasion when the winch has been needed to get me up a very steep, slippery
hill that the diff locker wasn't enough.....for those that know the Brindabella's, it was on a rainy/snowy Sunday afternoon, trying to get back up from Macintyre's Hut. In hindsight, I reckon if I'd let my tyres down to around 15psi (I had only let them down to about 25psi), I probably could have driven out anyway, but I'll never know for sure).
As for the
Cape York trip (I've been there twice), i can only say that I was able to get up the south side of every
creek crossing along the Old Telegraph Track. We were travelling alone with the camper trailer. However, we were following 2 other vehicles that were not towing anything and I was finding that they were having extreme difficulty on exiting banks, that I would subsequently get up without even spinning a wheel; using my air locker.
If it was my money, the diff locker would be more needed than the winch.
Roachie
126221
Reply By: niikki - Monday, Aug 22, 2005 at 07:46
My husband and i do a lot of travel up the cape region and although we have diff locks and a winch, i personally would get a winch, as we actually got boged and the diff locks could not help us, Then again it depends on where and when you travel, If you can afford both ..do it ... as circumstances may call for a winch or diff locks or both....YOU NEVER KNOW!!!
It's best to be prepared before than sorry later
Peace
Niikki....
126245
Reply By: Voxson (Adelaide) - Monday, Aug 22, 2005 at 07:52
If you need either,,, you need both...
126247
Reply By: Member - Karl - Monday, Aug 22, 2005 at 09:09
If you go a winch - as stated you will need a compatable bar (more $$) and don't forget you may have to have your front
suspension upgraded (more $$).
Why not go diff locks and a Tirfer type winch. It is a bit more on the effort side - but if you are reasonably fit they are ok. They are relativily cheap (between $400 - $700), don't need to have a compateable bar - just some rated tow hooks, don't need to up grade your
suspension. They are transferrable from vehicle to vehicle and your can use it to winch forwards, rearwards and side ways.
With the money you save - spend it something else - like a compressor etc.
Just a thought.
126251
Reply By: Crackles - Monday, Aug 22, 2005 at 10:38
I'm with Truckster. Diff locks will get you deeper into trouble & a winch will get you out. That said really for
Cape York there is no need for either. For the average driver the Cape is the most over rated 4x4 destination in Oz. If you put all the 4 wheel drive bits end to end you would only need to have the hubs locked for 1000 metres & that includes the telegraph track. (Not including the optional beach runs) The place is so busy now that in the unlikely event you did get stuck you'd only have to wait for 15 minutes before someone would come along & pull you out :-) A photo of my dad parked next to an XD Falcon on the
Jardine ferry is testimant to how hard the Cape is these days.
Cheers Craig..........
126265
Follow Up By: Voxson (Adelaide) - Monday, Aug 22, 2005 at 19:06
I am with you on the amount of people there and the small amount of time needed to lock the hubs....
"BUT" i would bet $5 you could "NOT" drive a standard XD Falcon all the way along the Telegraph Track to the Ferry crossing....
If you were going to drive the bypass roads up there and back you would have to need your head read!!!!!!!!!!!
The OTL -
CREB Track etc are a pretty awesome drive...
380966
Follow Up By: Voxson (Adelaide) - Monday, Aug 22, 2005 at 19:08
and if you take me up on the bet i will gladly give $5 to watch you try...
380967
Follow Up By: Rob from Cairns Offroad Training & Tours - Monday, Aug 22, 2005 at 23:52
It would be more comfortable on the development and bypass roads in a Falcon or a Holden specially the older ones. If you are fortunate enough to own a 4wd why not make use of its capabilities. You should be in 4wd hubs locked and headlights on, on any loose surface. The car will steer much better, brake much better and tyre wear will be less and more even.We see so many tourist get stuck in the very first
creek on the
Bloomfield track where we have our lunch every day because they don't have their hubs locked. They dig big holes in the loose rocky bottom causing problems for the next bloke. They then get out into knee deep
water to lock their hubs which should have been locked as soon as they were on dirt. Doh! Cheers Rob
381008
Reply By: Utemad - Monday, Aug 22, 2005 at 11:07
I have never been to the cape but in general I think that if you travel alone then get a winch but if you are with a group then get the lockers.
I have a winch and no lockers and have only used the winch to recover myself when I was alone or to recover someone else in a group.
However whenever I go out in a group I usually wish I had lockers.
The only reason I got the winch is that it was free :-) So maybe I should just go out and pay for the lockers?
Perhaps you could get one locker and a hand winch?
126275
Reply By: Rosco - Bris. - Wednesday, Aug 24, 2005 at 17:39
Just pulled a stump with the winch ... hard to do with lockers.
Food for thought ... versatile.
126659
