Bio diesel
Submitted: Tuesday, Aug 23, 2005 at 11:54
Boc1971
I am just curious if anyone here makes there own bio diesel? friend of
mine works in a plant - and told me that its not really to complicated , maybe a little time consuming -
has anyone here done it - and what are some of the down falls ??
Frank
Reply By: Truckster (Vic) - Tuesday, Aug 23, 2005 at 12:26
try searching the site AND archives... there are about 1000 threads on it.
126431
Follow Up By: Boc1971 - Tuesday, Aug 23, 2005 at 12:43
already done the
site search for biodiesel and bio diesel - 0 results -- 1000's for diesel - but nothing specific
found lots of webpages in reference to it --- but would like input from people here who actually make it for themselves
381061
Reply By: G-wizz - Tuesday, Aug 23, 2005 at 13:05
Search Google for biodiesel and you'll get more hits than you can possibly read.
126437
Reply By: Ozboc - Tuesday, Aug 23, 2005 at 13:13
I must not speak the queens english -- I KNOW i can look on google and find millions of webpages, i have been on the internet now for about 9 years and have a good understanding on how it works ( sarcasm ) --- I want the input from people on THIS
FORUM -
126438
Follow Up By: Leroy - Tuesday, Aug 23, 2005 at 13:20
Switch your post view to 'both' and then search. You will get better results.
Leroy
381064
Follow Up By: cokeaddict - Tuesday, Aug 23, 2005 at 17:36
Way to go Leroy :-)
381090
Follow Up By: ExplorOz Team - David - Wednesday, Aug 24, 2005 at 14:11
Here is a link direct to the 34 threads related to Biodiesel using the search details as specified above. Biodiesel.
Ozboc I know this may not answer your questions however the search system and results do work. The feedback below about
Site Search will also yeild a much better result set as it uses a different seach engine system. I am working on the rollout of this search system for all
forum threads, this will be released when available.
381198
Follow Up By: Leroy - Wednesday, Aug 24, 2005 at 14:27
'already done the
site search for biodiesel and bio diesel - 0 results '
I wasn't being smart just trying to help.
Leroy
381203
Follow Up By: ExplorOz Team - David - Wednesday, Aug 24, 2005 at 14:39
Leroy,
I was not commenting about your information it was exactly correct - enable the Both mode with the
forum search and you find the results as per the link above - you were exactly correct and helpful - I just decided after reading some of the incorrect infomation below about
forum serch not working to post a link in the section that in fact had the most correct information.
Also in
Site Search there is a
forum archives box that is turned off by default if you turn it on you get results - this is what I was saying above so a link to the
Site Search with
forum archives enabled is
Site Search Biodiesel - inc
Forum Archives.
Again thanks Leroy for your helpful & correct answer I was not in any way making a negative comment about your information just trying to expand and provide a direct link to the results.
381205
Follow Up By: ExplorOz Team - David - Wednesday, Aug 24, 2005 at 14:50
Ok it has sparked my testing of the search system a little more and this link to
Site Search yields 49 results. The sting is "bio diesel" or "biodiesel" or "bio-diesel" -
Forum archive enabled.
381206
Reply By: arthurking83 - Tuesday, Aug 23, 2005 at 19:33
Hi Boc1971,
I have trouble using this site sometimes too.
I just did a search on bio diesel, and got a "No results found" too!
Then on the search page I ticked the option for
Forum archives and found 1000 hits!
Dunno if this helps, as I haven't yet browsed the results..........
see how 'ya go with that.
126495
Reply By: Eric from Cape York Connections - Wednesday, Aug 24, 2005 at 07:06
They are good arnt they spend all that time telling how to look somthing up but no real answers.
If people dont ask questions this site will become extinct.
Good luck with the bio deisel if you get a answer let me know.
All the best
Eric
126561
