Site Search
Section Image
Turbo Timers
Submitted: Wednesday, Dec 11, 2002 at 00:00
Paul
All,
Being new to having a 4WD and also having a Turbo. Have been told about letting our Patrol 3.0L idle for a period of time after stopping to allow the turbo to cool down thus extending its life.
Bad habits die hard and comming from a Petrol car background we are finding ourselves (Myself and the wife) 90% of the time turning it off, then saying "oh s%^*" and starting the car up again to leave it idle for a while.
1: By doing this are we possibly causing more damage?
2: Are the Turbo timers a worth while investment?
3: Whats the deal after a long drive and stopping for a break, do you simply turn off, remove the keys, lock the car and walk away.
4: Can you install them yourself?
Paul
Advertisement
ThreadID: 2583 Replies: 4
Views: 593 FollowUps: 1
AnswerID: 9595   Submitted: Thursday, Dec 12, 2002 at 00:00
Bob Y. replied:
Paul, If you are turning engine off immediately, a lot will depend on how hard you have been going prior to stopping. Restarting immediately should lubricate turbo bearings before they dry out. Steady cruising round the 'burbs shouldn't do any damage, but traffic light drags, towing or heavy pulling in hilly terrain will require up 2-3 mins idle. Hot weather increases idle time, because vehicle is working harder, and under bonnet temps will be higher.
I reckon they are worthwhile, cheaper than a turbo rebuild. If you do as in "3", then it is illegal(got to get caught first) to leave the vehicle unattended while it is running. Also run risk of it rolling away, if your handbrake isn't too good. However I've been guilty of this many times.
Can install them easily, just disconnect the correct plug, and fit the leads on timer in line, but you need to be a contortionist to get under the dash.
Make sure you clean off any Armourall off the dash before sticking the controller in your desired position. Catch you later...
Reply 1 of 4
AnswerID: 9596   Submitted: Thursday, Dec 12, 2002 at 00:00
voxson replied:
A turbo can spin on for quite some after you switch the car off IF you have been using the throttle to the extremes and creating a lot of boost. Normally if you have been just country driving or just cruising around the city a turbo should not be spinning too fast, so by the time you have slowed down, stopped and turned the car off it should have settled just fine.
If you have been thrashing it ( as such ), i would wait a minute after you have stopped but if normal driving has occurred since thrash just go back to the first procedure.
I have owned quite a few turbo petrol cars from new and NONE of them has ever come from the factory with a timer because it is against the law to leave your car running unattended even if it is locked.
A turbo timer is good if you dont wanna sit in the car for a minute on a warm down after mounting a huge sand dune.
And they are easily installed and cost about $120 for a good one with heaps of options.
Reply 2 of 4
AnswerID: 9616   Submitted: Thursday, Dec 12, 2002 at 00:00
Truckster replied:
Check with your insurance company, some wont allow Turbo timers...
Reply 3 of 4
FollowupID: 5032   Submitted: Sunday, Dec 15, 2002 at 00:00
Paul posted:
GIO will only honor Factory Fitted TT.
Not sure if Nissan can factory fit them.
One things for sure......if they do it will be the mid to high hundreds rather than the couple of hundred for the off the shelf ones.
AnswerID: 9681   Submitted: Saturday, Dec 14, 2002 at 00:00
dave replied:
I'd recommend the turbo timer. I have one on the troopy, very easy to install.
Reply 4 of 4
Activities Index
Canberra Explorer, Australia Canberra Explorer, Australia's Capital
Canberra - INT
Enjoy the comprehensive tour of the Australian capital, Canberra.
Signature Massage - 90 minutes Signature Massage - 90 minutes
Sydney - NSW
Come and experience our signature massage - a unique combination of relaxing body and Swedish techni
2 day surf camp to Seal Rocks 2 day surf camp to Seal Rocks
Coffs / Mid North - NSW
2 day surf camp to seal rocks Learn to surf and discover the beautiful Seal Rocks Inclusions:
12 Lap EVO Rally Experience + 1 hot lap - SA 12 Lap EVO Rally Experience + 1 hot lap - SA
Big River Country - SA
Find out what rally driving is all about as you take a Mitsubishi EVO for 12 laps + 1 hot lap around
Book Now - Things To Do
