3500 dohc paj valve stem seals
Submitted: Thursday, Dec 12, 2002 at 01:00
Member - Paul
can anyone advise me of a reliable repairer to replace my valve stem seals on my 3500 dohc paj. melb based. I have tried Mitsubishi by the dollars scared me off.
Reply By: OziExplorer - Thursday, Dec 12, 2002 at 01:00
Paul are these internal or external valve stem seals?
How badly are they leaking?
Do you just get a small puff of smoke at start-up?
9600
Follow Up By: Member - Paul- Thursday, Dec 12, 2002 at 01:00
I'm not sure but I know that they can be replaced without removing the heads. so I assume they are external. & they are leaking quite badly in my opinion. If I let the car idle for 2 minutes then rev it there is quite a large clod of blue smoke. although there is no noticiable smoke when I am driving along.
thanks, paul.
4956
Reply By: Will - Thursday, Dec 12, 2002 at 01:00
Paul,
The reason the $$$ scared you off is because to do the valve stem oil seals on that engine (being twin overhead cam) they have to remove the camshafts, to do that they have to remove the timing belt, it is a V6 which means they have to repeat the process for the other side....
Quite a bit of work....
Make sure it is the stem seals, I got a friend who had the same problem and it was the rings...
Good Luck
9610
thanks for your input, sound like I might give the dealer the job. paul
4961
Follow Up By: Oziexplorer - Thursday, Dec 12, 2002 at 01:00
Why not go to a reliable mechancial
shop. Dealers are always horrendously expensive, usually have mechanics that are not as good as those out in the private area, as you can see the dealers are always advertising for mechanics as they don't hold them.
4963
As a matter of interest, how many k's have you done?
Seems pretty strange these days just to need valve stem seals.
Have you been using one particular brand of oil?
4964
Follow Up By: Axel + Karen - Thursday, Dec 12, 2002 at 01:00
Ozi ,as usual you have no real idea,,the reason dealership workshops have to charge what may seem excessive rates is the overhead involved in keeping the mechanics trained upto the new technology,,,but then again the word FIGJAM is just for you.
4969
Reply By: MikeyS - Friday, Dec 13, 2002 at 01:00
Paul- I can recommend David Officer at Officer Smith Automotive in Villiers Street North
Melbourne. David is a member of the Paj Club so he would have a lot of people to answer to if he did the wrong thing! Reasonable rates too. I've always been happy with the service. MikeyS
9644
Follow Up By: Member - Paul- Friday, Dec 13, 2002 at 01:00
thanks Mikey, thats the sort of response I was looking for. paul
4983
