AnswerID: 9694 Submitted: Sunday, Dec 15, 2002 at 00:00
David_NSW
replied:
HI Folks,
I have constucted a home made drawer system for my GU. I am a carpenter so naturally used timber (ply wood). I spent alot of time researching a suitable sliding setup for the _Affordable_Storage_Drawers.aspx.
Unfortunately heavy duty kitchen style sliders are not really suitable, they just won't carry enough weight. Remember your talking about live loads when your vehichle is bouncing along rough tracks.
The heavy duty rollers that you find on the commercially made units are great, but very expensive and are probably more suit to _Affordable_Storage_Drawers.aspx constructed from metal. Also some highly accurate engineering would be required to end up with a setup that didn't rattle it's head off on anything other then the smoothest black top.
I ended up using strips of the hard plastic material used on boat trailers. It comes in 1m lengths and is designed to slide with very little friction with aluminium boat hulls. I used aluminium angle on bottom edge on each side of my drawrs with slides along the plastic strips.They slide very smoothy and easily even when heavily loaded.
I'm very pleased with the result, the whole thing cost about $300 for materials. The plastic strips I readily available from
Boating Accessory stores.
Hope this helps. Good luck. David
Reply 7 of 7
