Bestest reason yet
Submitted: Friday, Aug 26, 2005 at 10:02
ThreadID: 25890 Views:2590 Replies:4 FollowUps:17
The best reason yet to have 15" instead of 16" wheels is price . bridgestone 694sAT 31x10.5R15 overall diameter =778mm and cost $175 ea.
694sAT 265/70R16 overall diameter =779mm and cost $250 ea.
not much more tyre for $75.
Reply By: Member - Chrispy (NSW) - Friday, Aug 26, 2005 at 10:04
Not to mention the price of steel rims as well..... 15 inch: $45.00, 16 much more...
AnswerID: 126928
Reply By: Rosco - Bris. - Friday, Aug 26, 2005 at 10:06
Good point .. but what's availability like in the bush?
AnswerID: 126929
Follow Up By: Member - Jeff M (WA) - Friday, Aug 26, 2005 at 10:11
31x10.5R15 are the most popular size in general, this will no doubt change but all the older 70 series utes in the bush plus a lot of hilux's are running that size, so I don't think it would be a problem. I found the same price diff when I was getting my Goodyear MTR's, $235 vs $300!!
FollowupID: 381473
Follow Up By: Alloy c/t - Friday, Aug 26, 2005 at 12:29
A -ell of a lot easier to find than 16" or heaven forbid 17+" ,,
FollowupID: 381503
Follow Up By: Member - Davoe (Widgiemooltha) - Friday, Aug 26, 2005 at 20:26
Not that good Rosco I enquired about 15 inch tyres at Drysdale river as I was down to 1 spare and was lookead at a bit funny and told everyone runs 16 inch these days ( I had lost my eftpos card anyway - but thats another story)
FollowupID: 381565
Follow Up By: Rosco - Bris. - Friday, Aug 26, 2005 at 20:41
My suspisions exactly Davoe ... hence my query.
From my research 16 are most common by far .. esp 235/85 jobbies
FollowupID: 381570
Follow Up By: Member - Jeff M (WA) - Friday, Aug 26, 2005 at 21:33
That's interesting when I traded my Desert Duallers in (about 2 months ago or so) they said that they would have no problem on selling them as they were the most popular size...?? They were 31's.
FollowupID: 381577
Follow Up By: Member - Davoe (Widgiemooltha) - Saturday, Aug 27, 2005 at 00:55
Surprised me to as I reckon they are pretty popular. i thought the main reason for price difference was the construction as all the 15 inches I have seen have been 6 ply with farly low load ratings and max pressure of 50psi. They werent really suitable on my camper for this reason as I needed about 55 psi in the rears to give them the same appearence as a normal vehicle with 28 psi and as a result i blew 3 of them out
FollowupID: 381594
Follow Up By: Member - Jeff M (WA) - Saturday, Aug 27, 2005 at 12:50
Hmm, fair enough, I just went and had a look at my MTR's. They are a 31"10.5xR15LT, the maximum load per tyre is 1030kg, Load Rating C. I can't see the surf geting over 4 tonne so I'll be alright, but I can see how you may have had dramas with the Camper...
The specs say 5 ply, 3 ply sidewall. I wonder what the 16" are? Anyone got some MTR's? in 16"?
FollowupID: 381629
Follow Up By: Member - Davoe (Widgiemooltha) - Saturday, Aug 27, 2005 at 22:50
No consideration have you Jeff. You have made me leave work and drive into camp to find the surveyers ute who has 235x16 Goodyear mtr fitted.
They have a load range of 1380kg with max tyre pressure of 80 psi and have 7 ply tread and 3 sidewall not sure what the load rating was - there was a p marked on them
FollowupID: 381678
Follow Up By: Member - Jeff M (WA) - Sunday, Aug 28, 2005 at 11:35
LMAO! Well there you go! That's very interesting... So the 16" is stronger... You know after all the hours I speant researching tyres before buying these ones I NEVER saw that written anywhere that the Ply numbers change depending on the size of the tyre! I figured an LT tyre would be the same weather 15" or 16" as far as Ply's go. Of course they talk about the wonderous 3 ply sidewall but that's not where 90% of punctures are...
Well I spose it wouldn't have changed my decision on these ones as I just couldn't afford 5 new rims as well as the tyres, and the surf wouldn't have looked too good with sunny's on it! LOL
FollowupID: 381705
Reply By: Philip A - Friday, Aug 26, 2005 at 10:27
Just watch the load ratings. A lot of 15 inch tyres are not LT and have thin sidewalls.
It is illegal and ill advised to fit tyres with load ratings less than the tyre placard ratings. I contributed to a thread on another forum a while ago where someone was complaining of lots of punctures on 31x10.5s . When I looked , their load ratings were quite low and under what is specified on a Range Rover anyway.
Regards Philip A
AnswerID: 126933
Follow Up By: Alloy c/t - Friday, Aug 26, 2005 at 12:26
Load rating is actually higher on the 15" and is an LT with 2x extra plies compared to the 16" ,definitly more tyre for the lesser $$$$$
FollowupID: 381502
Follow Up By: Member - Chrispy (NSW) - Friday, Aug 26, 2005 at 12:40
Yup - in my experience its always been the 15" that are called "LT" in comparison to their metric cousins.....
FollowupID: 381505
Follow Up By: Member - John C (QLD) - Friday, Aug 26, 2005 at 17:09
Still like my 235/85/16s. LT 10 ply 116/120 load rating.
1" bigger OD.
Same OD as 7.5/16 so easy to get replacement out west if I need to.
And just paid $145.00 each for Simex roadtrekker.
I'm happy with that :-)
FollowupID: 381546
Follow Up By: Member - Phil G (SA) - Friday, Aug 26, 2005 at 22:03
I found the load index to be higher on 16 inch tyres.
The 31x10.5R15 usually have a load index of 109. Closest 16 inch tyre equivalent is the 265/70R16 with load index of 112+, and slightly taller, the 265/75R16 is usually 119/122. The 245/75R16 are usually 120.
In my experience the 15 inch rubber was more likely to puncture in the desert country.
FollowupID: 381583
Follow Up By: Member - Davoe (Widgiemooltha) - Saturday, Aug 27, 2005 at 00:57
alloy what are the specs of these tyres? I have been unable to find them on the net, Most 15 inches I have seen are 6 ply 2 sidewall and 4 in the tread with much lower load rating
FollowupID: 381595
Reply By: arthurking83 - Saturday, Aug 27, 2005 at 01:21
as that stupid old commercial used to say "wheredoyageddit?"
I'm curious as to where one can purchase any 16' tyre for less than $180 (retreads not included!)
I replaced my 205's with 31's for the price point.
A set of tyres a year at a saving of $160!
The reason for the less costly 31' tyres is thanks to the good 'ol USA.
Their bush bashing cowboys won't wear anything else! (used to!)
You'd reckon that very soon the status quo will change towards the 16' though??
cheers. (and I really do want a set of 235/85/16's for $145....pleeeease!)
AnswerID: 127052
Follow Up By: Member - Davoe (Widgiemooltha) - Saturday, Aug 27, 2005 at 05:15
no problems but i dunno about the 235s. I was quoted $140 each for 7.5x16 s and that included the tube as well (thats country prices)
FollowupID: 381602
Follow Up By: Utemad - Saturday, Aug 27, 2005 at 10:20
When I got my 225/75 16 BFG KO A/Ts I paid $199ea and they were the most expensive A/T in the shops (4yrs ago but still the same price now). There were plenty of tyres in that size for under $180ea. I would have thought 205s to be even cheaper.
FollowupID: 381620
Follow Up By: Member - John C (QLD) - Sunday, Aug 28, 2005 at 18:15
Just got them locally in Brisbane.
Local as in the local garage/workshop who is a Simex rep.
If you want something cheaper than $145.00 try Triangle.
Was quoted $113.00 eas for the 235/85/16 AT, but felt Simex a more well known 4wd tyre maker:-)
FollowupID: 381733
