glow plugs
Submitted: Saturday, Aug 27, 2005 at 07:01
ThreadID: 25910 Views:1673 Replies:2 FollowUps:1
good morning,replacing glow plugs in 1hz 91 is there any tricks or is it as straight forward as it looks,any info would be great. haveagoodweekend...
Reply By: Member - Davoe (Widgiemooltha) - Saturday, Aug 27, 2005 at 07:21
I had to pull the glow plugs out of my 2h donk when i filled it to fast with oil and yea it was as easy as it looked
AnswerID: 127054
Follow Up By: haysie222 (SA) - Saturday, Aug 27, 2005 at 07:23
thanks davoe,thought it might be.
FollowupID: 381605
Reply By: Tuff60 - Saturday, Aug 27, 2005 at 15:58
This is for 2H's, from memory the same on your motor.
Check the voltage coming out of your glow plug relay, make sure it is not above the voltage on the new plugs. Over time the relay voltage sneaks up, generally why the glow plugs die. Hope this helps.
AnswerID: 127092
