Rims& tyres
Submitted: Sunday, Aug 28, 2005 at 11:28
ThreadID: 25935 Views:2482 Replies:5 FollowUps:2
Hi All
I am currantly running cooper st tyres tubeless on 6'' prado rims my quary is can i run dunlop sp road grippers on these rims tubeless, I have just scored a couple more prado rims & would like to put my 2 spares on them tubeless instead of the split rims they are on now ,thanks in advance.
Friar
Reply By: Member - Phil G (SA) - Sunday, Aug 28, 2005 at 11:53
Friar
Read the sidewall of the tyre. It will either say "tubeless" or "tube type". Then check whether the load index is high enough.
Are you using them on an RV Prado??
AnswerID: 127172
Reply By: friar - Sunday, Aug 28, 2005 at 12:07
Thanks for the reply Phil ,just checked nothing on tube or tubeless stamped on tyres,will check with tyre company tomorrow when open.
AnswerID: 127175
Follow Up By: Ted (Cairns) - Sunday, Aug 28, 2005 at 15:14
I'm sure someone is going to shoot me down for this, but I used tube type tyres (car ones) mounted tubeless some years ago and with no problems. I guess if they seal properly on the rim that's all they have to do. I think dedicated tubeless may have softer rubber where it contacts the rim???? Ask your tyre place, they should know(?)
FollowupID: 381722
Follow Up By: Member - Davoe (Widgiemooltha) - Monday, Aug 29, 2005 at 07:09
the drillers at work run nylon tube tyres on one piece rims as tubeless
FollowupID: 381783
Reply By: friar - Sunday, Aug 28, 2005 at 12:11
Phil forgot to say running them on a hilux
AnswerID: 127176
Reply By: Member - Davoe (Widgiemooltha) - Sunday, Aug 28, 2005 at 20:07
Are you mad?? road grippers are a very ordinary tyre to say the least they puncture easily and the last ones I had removed had started to self distruct with the wires poking through on the inside causing punctures
AnswerID: 127225
Reply By: cmilton54 - Monday, Aug 29, 2005 at 19:09
Tubeless have thicker layer of internal rubber over tube type. Have had customers that have run both with no troubles.
Charlie
AnswerID: 127342
