Additional wiring in a 4WD
Submitted: Monday, Aug 29, 2005 at 08:11
ThreadID: 25951 Views:3082 Replies:7 FollowUps:7
Hi all,
I have searched and read a lot in the archives about additional wiring for fridges ,compressors, lamps etc. and have picked up some valuable information through this forum. I am confident enough to attent to do it all myself.
There seems to be two schools of thought about running two wires versus one positive and earthing the negative to the body.
The obvious advantage of one wire is less wires running through the vehicle, however can members please advise the pros and cons of the two systems. The critical part of both ways appears to keep the fuses as close as possible to the auxilliary or main battery.
Am I on the right track.??
Thanks in advance
Terry
Reply By: Alloy c/t - Monday, Aug 29, 2005 at 08:37
+ and - to the batt = less voltage drop ,using the body as the neg comes with its own set of problems such as rust/paint ,loose bolt/screw , best to batt 2nd best to engine block least to body.
AnswerID: 127261
Follow Up By: Mainey (WA) - Monday, Aug 29, 2005 at 10:17
My dad always said "do it once and do it right" and I have followed his advice 'often' :-(
With a designated wiring system for the fridge as mentioned above, the power is at 'full strength' direct from the battery and is not being also used by other electrical items.
The diameter of the cable is directly relevant to it's length and power consumption of the fridge to avoid voltage drop at the fridge.
FollowupID: 381797
Follow Up By: Willem - Monday, Aug 29, 2005 at 11:10
My wiring looks like a spaghetti factory during a cyclone. Ran out of black 6mm wire so used red for the negative wire as well lol. All earth wiring goes to the body near battery. Ran this wiring to independant cig socket for Engel fridge and fridges own wiring from there. Have never had an issue. My 'bush' wiring seems to be OK. It's the genuine Nissan electricals that are PITA :o)
FollowupID: 381801
Reply By: V8troopie - Monday, Aug 29, 2005 at 15:02
While the earth return wasn't such a big problem in older, pre electronics vehicles, it cetainly could be in the newer computer driven models.
The manufacturers carefully select a few strategically placed earth connections for the auxiliary wiring, to avoid stray earth currents and galvanic reactions.
With things like another stereo under the dash, the earth return could connect to the nearest one that's used for the dash wiring.
For high powered add ons its definitely a better idea to use two seperate wires. Twin core wiring comes in reasonable sizes and its like running a single wire to install it.
You are right about the fuses.
Klaus
AnswerID: 127311
Reply By: cmilton54 - Monday, Aug 29, 2005 at 19:03
If you use twin sheathed cable you gain red and black together in a protective cover
available in 3, 4, 5 and 6mm squared cable
Charlie
AnswerID: 127339
Reply By: drivesafe - Monday, Aug 29, 2005 at 19:56
Hi Terryfirma, first off, I’m surprised someone has not yet posted how they just use the body for the earth and have done so for years and never had a problem.
I would like to know how anyone would know if they had a problem or not because as has been pointed out above, there are so many things that can cause problems that don’t necessarily show up straight away but can cause major problems down the line if you use the body as the earth return for anything that uses more than 1 or 2 amps max.
In a worst situation, when using the body as an earth return, you can get a resistive joint in the vehicle that can be so bad that it eventually causes a fire.
If you ask a professional installer of electrical equipment, they will tell you they always run both the positive and the negative wire to the point where the new accessory is to be installed.
Willem, correct me here but what you were saying is that “ all earth wiring goes to the body near the battery “ and the bit you left out was that you have the earth from the battery bolted to the same point of the body, is this correct.
Terryfirma, this is a good way to get around the problem of trying to hook up all your earth wires to the negative terminal of the battery. Simply mount a bolt through the body, run a cable from the battery negative terminal to the bolt and then run all the other earth return wires to the same bolt.
The only thing I would suggest is that you work out what the current requirements will be for each wire you are going to run and make sure you use cable that is at least twice the current rate. This will reduce the voltage drop that will occur and the use a fuse with a current rate about 50% larger the the intended current requirement for the accessory. The reason for the larger fuse is to stop the fuse melting.
If you are going to power a driving light that draws 10 amp and you use a 10 amp fuse, you will not blow the fuse but in a very short time you will melt it.
This is an example of what I mean, You want to power a fridge that draws 10 amps. Use cable that is rated at at least 20 amps and fit a 15 amp fuse. This will give you a safe and efficient install.
You can use this as a very basic formular to workout each wire circuit you are going to install.
Cheers.
AnswerID: 127347
Follow Up By: Terryfirma - Wednesday, Aug 31, 2005 at 08:35
Thanks drivesafe,
Some great info. Ready to start the project this week end. Some sound advise about the heavier wiring and fuses.I will be using the single sheath wiring to cut down on the number of wires, and running both + and - back to the battery.
Have located a perfect position for my "earth bolt" close to the auxilliary battery.
Will have to report once everything is installed and running.
Once again thanks
Terry
FollowupID: 382114
Follow Up By: drivesafe - Wednesday, Aug 31, 2005 at 15:54
Hi Terryfirma, if this is your first attempt at wiring your own vehicle, by the time you are finished you will probably come to one of two conclusions.
1) You will never attempt it again
or
2) Why didn’t you try this years ago and what can you wire up next.
I will be very surprised if the later is not what you decide on.
Cheers and have fun.
FollowupID: 382200
Reply By: Mike DiD - Wednesday, Aug 31, 2005 at 09:49
Here are results from ACTUAL TESTS in an NP Pajero.
If you are putting a power connector in the back of the vehicle and you plan to use wire to the battery for the Earth/Black side, then you will need to use AT LEAST 10mm OD 4G (21mm sq) to get LESS voltage drop than using the bodywork.
Using 6mmOD 8G (7.5mm sq) cable I measured 0.3 volts drop at 10 amps. Between Battery Negative and the bodywork at the rear I measured 0.13 volts drop at the same current - nearly 1/3rd.
In the days of screwed and rivetted bodies, there was a valid reason not to use the body for Earth Return - in today's spot or seam welded bodies you have a huge conductor from front to back - why not use it.
AnswerID: 127590
Follow Up By: drivesafe - Wednesday, Aug 31, 2005 at 12:21
Hi Mick, actually the opposite is correct. More and more now, newer vehicles, particularly 4x4s are using monocoque construction techniques, plus there is a load of plastic used in there construction and they also use sealant for anticorrosion purposes. All this adds up to making a good earth through the body highly questionable.
I do this sort of work as my trade and I can assure you that no professional in this field would even contemplate using the body as the earth return for anything but the lightest of loads EG for a small light.
There is no satisfactory way of determining if the body could SAFELY be used for the earth and no matter what you or anybody else whats to do, Safety First is just that.
By running the earth back to the battery you have a known safe operation.
There is a way that if someone really wanted to use the body as an earth then this test could be carried out. The problem is and the reason I am not going describe the test, the test itself can cause a fire in worst situations.
For my own piece of mined and for the safety of my customers, there is only one way to do this type of wiring and that is as explained above, run a separate earth wire as you run the power wire.
Can’t go wrong then.
Cheers.
FollowupID: 382153
Reply By: Mike DiD - Wednesday, Aug 31, 2005 at 12:46
Yes, if the Battery Earth lead breaks there will be damage to anything that is directly earthed to the body - but if you check a modern vehicle that is just about every bit if electrical equipment in it.
Yes, if a fuel line breaks fuel will spray everywhere - but no-one puts a jacket around every fuel line - just in case.
Yes, if a tail shaft breaks it can cause serious injury - but when did you last see a tail shaft restraint on a car / 4WD - just in case.
In a monocoque construction the strength of the body is dependant totally on the metal-to-metal welds - which also provides the most reliable form of electrical connection.
AnswerID: 127617
Follow Up By: drivesafe - Wednesday, Aug 31, 2005 at 14:03
This has nothing to do with a battery earth lead breaking, it is do with common sense safety or are you saying that it is worth risking someone's life just to save few lousy dollars.
Modern vehicles are notorious for having bad earth paths through the body and if you care to take the time and look at how most vehicles are wired these days, you will find that the manufactures wire the earth return for SMALL loads back to a given point, a point that they know works.
For someone adding wiring to a vehicle, there is no way of knowing whether these earth points can handle any form of heavy load.
Now as I said, the only way to know you have a safe wiring set up, is to run an earth wire with the power wire.
Mike, if you want to use your vehicle body as the earth return all just to save a few dollars, go for it, but this is neither safe nor a professional way to do it.
There is no way of telling to the point of being 100% sure that there will not be a problem with using the vehicles body as an earth and unless you are 100% sure, thats not 99.99% sure, but 100% sure, there is no way that anybody would willingly risk their own life, let alone what damage they could do to their vehicle, for the sake of saving a few dollars.
FollowupID: 382179
Reply By: Mike DiD - Wednesday, Aug 31, 2005 at 15:26
"For someone adding wiring to a vehicle, there is no way of knowing whether these earth points can handle any form of heavy load. "
- a good point. There is lots of metal under the Dashboard that is not connected or poorly connected electrically to the bodywork.
It may appear to give an connection but then be intermittent when moving or with aging. I was thinking only of solid points like seat mount bolts.
AnswerID: 127641
Follow Up By: drivesafe - Wednesday, Aug 31, 2005 at 15:48
Mick, perhaps I have not explained this clearly enough, this is not about convenience, it is purely and simply about safety.
Whether a given point is going to be a good earth or not, does not come in to it.
It is whether this point can be guaranteed to be 100% safe.
I can’t give that sort of assurance and I’d be very surprised if anybody in this business would be willing to go out on a very hazardous limb and say that this type of earth is safe and as there is an alternative that is safe why both.
Using the body, any part of the body of a vehicle as an earth is just playing Russian Roulette with people’s lives and their vehicles and again, there is a simple alternative that works and is safe.
Cheers.
FollowupID: 382199
