DIFF LOCKS - factory Toyota or ARB
Submitted: Tuesday, Aug 30, 2005 at 15:19
Cruza Ute
I'm currently pricing a 79 Series RV TD ute I plan on setting up for long distance touring. I chose this vehicle for it's robustness, load capacity, parts availability and off-road ability in relatively standard form.
Before I place my order I'm considering the option of Toyota factory diff locks.
Can anyone that has/had them give me some feedback.
I have some experience with ARB lockers that has been resonably positive. I've already got an ARB compressor withe pressure switch etc. capable of engaging lockers. Does anyone have experience with both ARB and Toyota lockers.
My main concern is losing the standard LSD for on-road use especially in the wet.
Reply By: Member - Luxoluk - Tuesday, Aug 30, 2005 at 16:19
You could probably have a bob each way on this choice. I elected for the factory lockers to ensure warranty matters were
well covered off and to avoid any potential disputation as to whether the aftermarket items contributed or caused a differential failure. Had I gone for the ARB items I may have also contemplated changing the diff ratio or electing for higher profile tyres (have 265/75 fitted) for better highway cruising........about 2500 at 100 kph. A front locker alone may serve your needs?? Too many choices!!! Cheers
127462
Follow Up By: Cruza Ute - Tuesday, Aug 30, 2005 at 17:55
Thanks for the info Luxoluk. How do you find your factory lockers? In particular do you ever have trouble getting them to engage. I've been told it sometimes takes time for them to indicate they're in. Do you mean to say that the 265/75R16 tyres are better or worse for highway cruising? Do you find the rear end a bit slippery in the wet on-road with lockers disengaged?
381990
Follow Up By: Member - Luxoluk - Tuesday, Aug 30, 2005 at 18:12
Have not had to use the lockers in "anger" to date but I have engaged them on a couple of occasions as a precautionary measure. They do not engage quickly like the ARB items. The open rear diff is not a problem for ordinary driving in the wet, in fact it may be preferable to the LSD given things can get exciting when both rears let go at speed. As for extreme bush stuff I will let others comment on that! The gearing from my perspective is about 10% underdone and a set of 285/75 or 255/85's would have better suited my purposes however getting spare tyres may create a problem in some areas. To do a desert trip I have atleast 1500 to 2000kms before I hit the dirt so cruising speed is a consideration for me...not everyone however!! Unfortunately I have got too used to loping along in V8's and have yet to accept it's ok to drive a diesel at a squillion rpm??? Cheers
381994
Follow Up By: Cruza Ute - Tuesday, Aug 30, 2005 at 18:35
Good point about tyre availability. I supose 265/75R16s are a resonably common size. Ever worked out your fuel economy at cruising speeds with them?
382001
Reply By: See You - Tuesday, Aug 30, 2005 at 16:31
I run 5 cruisers in
the desert for my business and they have all got factory LSD's. They are 79 series and 100 series troopies and wagons. I have put in front arb lockers and have had no problems. I find that th efactory LSD/front lockers more than adequit for my application. I would not bother with rear lockers as the LSD seems to work fine up here. They work mainly in the northern desert and
Cape York pen.
127466
Follow Up By: Cruza Ute - Tuesday, Aug 30, 2005 at 18:00
Thanks 'See You'. Do you mean factory locker in the front only? My Toyota dealer led me to believe it was both front and rear or none.
381991
Follow Up By: See You - Tuesday, Aug 30, 2005 at 19:02
ARB aftermarket up front.
I have been told by Toyota that they only do a duel difflock instalation like they do in some Saharas. I believe that they are a mainly Eoro and Canada option on the 75-79 series.
Checkout the price ARB vs Factory. Also make sure that the ARB ones do not void your warranty on the diffs.
I still have never needed anything more than a rear LSD and front locker so it may be better to save the money and spend it on a winch.
382004
Reply By: Member - DOZER- Tuesday, Aug 30, 2005 at 17:13
Buy the factory lokas, the lsd for on road is not as beneficial as the lockers for off road....and it i going to be a cheaper option than the ARB's.
There are
places where an open diff can be a good thing too....like slippery mud where you need one wheel to have traction each end....to keep it straight.
Andrew.
127472
Reply By: Rock Crawler - Tuesday, Aug 30, 2005 at 18:38
If you buy factoru lockers , they wont knock back your warranty clain when you brake your first crown wheel and pinion
127493
Follow Up By: Member - John (Vic) - Tuesday, Aug 30, 2005 at 21:38
Thanks Mate. LOL
382031
Follow Up By: Truckster (Vic) - Tuesday, Aug 30, 2005 at 21:51
do u have it mounted yet?
382040
Follow Up By: Member - John (Vic) - Tuesday, Aug 30, 2005 at 21:56
Bruce I have to get the broken bits back from Mr Rocky Crawly listed above here if he still has them???
Then I might just take a photo or two and post them on here for a trophy. LOL
382043
Follow Up By: Truckster (Vic) - Wednesday, Aug 31, 2005 at 09:02
come on John, trophy for the club! We did similar in the bike club with a bent crank award
382118
Follow Up By: Member - John (Vic) - Wednesday, Aug 31, 2005 at 12:35
Hey Bruce thats a great idea.
Eric you still got the bits?
382156
Reply By: at4x4 - Tuesday, Aug 30, 2005 at 18:49
The front diff in the 79 is the same as the 100/80, and can be prone to breakage in reverse, or shockloaded, and when we fix this issue , one of the many things we do to the diff , is we fit an ARB locker, as the carrier is alot stronger with no hole for the side gears to be fitted, which helps stop the crownwheel being able to flex away from the pinion.
Just foood for thought, along witht he 3 month wait normally from mr yota for a specific order vehicle.
127495
Follow Up By: Member - John (Vic) - Tuesday, Aug 30, 2005 at 21:48
Darren I
mine busted with with an ARB locker.
Problem appears to lie with teeth that are not up to the task.
382038
Follow Up By: Member - John (Vic) - Tuesday, Aug 30, 2005 at 22:40
$hit!!! Should read "I Busted Mine" not "I
mine busted"
Sheesh!!! I must proof read before I send. LOL
382051
Follow Up By: at4x4 - Tuesday, Aug 30, 2005 at 23:14
The locker is only a small part of fixing the front diff, to be stronger, we have about 30 odd out there now, starting with
mine back in 96 in my 80 with 400hp and 36" swampers , and we havent had a fixed one back broken again yet, but have had 3 of them back with broken cv's.
Did a 100 2 weeks ago which is now on its 5th cw & p in less than 100k.
382066
Follow Up By: Member - John (Vic) - Tuesday, Aug 30, 2005 at 23:19
So in your view why they are stripping teeth of the crown wheel?
Is this the same type of failure you have seen in other models or are they breaking something else?
382068
Follow Up By: Member - Davoe (Widgiemooltha) - Wednesday, Aug 31, 2005 at 01:00
I would reeeely like to know what these guys do to bust the front diffs The vehicles at work get driven underground in low range getting more 4wd time in a week than alot would get in a year and do more reversing (alot of hard reversing foot flat in reverse up declines out of drives etc) in a shift than alot would do in a year ................................... And Ive never seen one bust
382084
Follow Up By: Member - Davoe (Widgiemooltha) - Wednesday, Aug 31, 2005 at 03:42
ah hang on "back in 96 in my 80 with 400hp and 36" swampers" -
yea that would probably do it
382085
Follow Up By: at4x4 - Wednesday, Aug 31, 2005 at 08:45
I dont think to many 4wd's have broken on reasonable level surfaces during day to day duties.
382116
Follow Up By: Truckster (Vic) - Wednesday, Aug 31, 2005 at 09:03
u still got that vid clip of ya blue 80 revvin its norks off in that winch comp I think it was??
382119
Follow Up By: at4x4 - Wednesday, Aug 31, 2005 at 09:08
I have afew vids somehwere, but most have probably seen "stormin Norman" in the dark blue 80, which was my truck, just after I sold it to him.
382122
Follow Up By: Member - Davoe (Widgiemooltha) - Wednesday, Aug 31, 2005 at 19:54
mmm Obviosly havnt been down to many mines?
382235
Follow Up By: at4x4 - Wednesday, Aug 31, 2005 at 20:15
standard trucks loaded, with standard tyres, dont kid yourself how difficult you think mines are, vs what breaks them playing on weekends.......
382242
Follow Up By: Member - Davoe (Widgiemooltha) - Wednesday, Aug 31, 2005 at 20:57
You miss the point (again) from the way people talk it sounds like a tojo front diff is in mortal danger every time you put it into reverse or take it over some uneven ground. I have no doubt running a 400 bhp donk with huge tyres could
well bust the diff if you try and jump it too often but as I have explained from my experience they will take reversing up declinesfoot flat at 4500 rpm for hundreds of metres and have no problems driving around minesites locked in low 4 because you cant even get them out. This is alot more 4wding than any recreational vehicle would ever get close to so if they were that weak It would show.
Seeing as minesite work is so easy perhaps you could lend me your prado to see how it holds up? I am still waiting to see how far I can drive it cross country with those tyres!
382251
Follow Up By: at4x4 - Wednesday, Aug 31, 2005 at 21:57
I may of missed the point, but at least i dont have selective rmemory on posts to suit what I think.....
I told you what tyres you can try, obviously cant, or wont.
As for the "mortal danger' I think if you actually read the point being made, you will find "shockload" causes the breakage, not reversing uphill for a long way at any rpm, but then, none are as blind as those who wont see.....
382265
Follow Up By: at4x4 - Wednesday, Aug 31, 2005 at 22:00
And if you actually listened occasionally, you might notice I dont have a prado.........
[even though some mining companies are already using them.......]
382266
Follow Up By: Member - Davoe (Widgiemooltha) - Wednesday, Aug 31, 2005 at 22:02
"and can be prone to breakage in reverse" your words not
mine
As for the tyres I actually did try googling them but didnt come up with anything so if you have any other info on them such as are they speed rated, road legal? price? etc etc I will be happy to read it
382268
Follow Up By: Member - Davoe (Widgiemooltha) - Wednesday, Aug 31, 2005 at 22:09
"Having owned one, i would disagree with that opinion. " (prado) your words again I realise after a re read it could mean you used to own one but with that statement along with the picture on your website I hope you will forgive me for the confusion
now if you will excuse me ive got a selector to push into low 4 and some driving to do (some people actually get to 4wd every day - not just weekends)
382269
Follow Up By: at4x4 - Wednesday, Aug 31, 2005 at 22:11
Taken out of context as a small part of a big post it does, yes, but if you read the post properly, rather than selectively, you will see it says stopping the crownwheel being able to flex away from the pinion as pfixing it from happening......
One day, when your a big boy, you will be able to put 2 + 2 together to = 4, saving anything technical having to be explained for you...
382270
Follow Up By: at4x4 - Wednesday, Aug 31, 2005 at 22:17
quote
""Having owned one, i would disagree with that opinion. " (prado) your words again I realise after a re read it could mean you used to own one but with that statement along with the picture on your website "
So we now see you admit your skills of deduction from peoples posts needs more effort from your side to be fully understood.
You assumed [= ass/u/me]I "own' not owned a prado, and the webiste isnt
mine, so the car on ther has no relevance other than on the webpage of where I work, and i owned a 90 series, not a 120.......
Some may get to put a vehicle in 4wd every day, just like some get to see a hunderd or so a week go through the door, used for all different things, by all types of people, with all kinds of accesories, rather than see the same use, by the same people, in the same vehicles, making for a slanted view on the whole world, vs a small portion of it.
382271
Follow Up By: Member - Davoe (Widgiemooltha) - Wednesday, Aug 31, 2005 at 23:06
12 jobs in the last 8 years that required the use of countless different 4bys for varios uses by different people not including my personall vehicles - like you said [= ass/u/me
382283
Follow Up By: at4x4 - Thursday, Sep 01, 2005 at 08:17
I would of thought with so much self proclaimed knowledge, your opinions would reflect that more often....
382301
Follow Up By: Twin Dogs - Thursday, Sep 01, 2005 at 11:12
Sounds like you work in pussy mines Davoe, I've seen the diffs destruct a few times but we treated them hard.
382319
Follow Up By: Member - Davoe (Widgiemooltha) - Thursday, Sep 01, 2005 at 12:18
Maybe |Im not trying hard enough TD :) although the ute we used on the other site has cost 24 grand in 12 months
382325
Reply By: Member - John (Vic) - Tuesday, Aug 30, 2005 at 21:46
I have a 78 series fitted with ARB Lockers front and rear.
Bloody brilliant, having now had lockers would not have a vehicle without them.
No issue at all with open diffs on the road, wet or dry.
But having also stripped 5 teeth off the front crown wheel and had to pay for the repair due to aftermarket fitted equipment (ARB Locker) I will be ordering my next Troopy with Toyota Lockers front and rear next time.
Cost wise they were similar and maintain the warranty.
Quite a few guys in my club have the yota lockers and none have had any issues with activation, IE being slow to engage all are very happy with them.
Go the factory lockers even if you have to wait 3 months for the vehicle.
127541
Follow Up By: Cruza Ute - Wednesday, Aug 31, 2005 at 09:17
Thanks very much John.
Your info has been very helpfull.
My Toyota dealer has been very good to me over the years when it comes to warranty claims despite the hard treatment my vehicles get. It'd be good to have my lockers covered by the same warranty. Even if I have to wait a few months.
Bit off the point if you don't mind but. Is your 78 a TD? If so what size tyres do you run and how do you find the drive ratio with that size eg. highway/off-road? Gotto decide what size tyres I'm going to order it with too.
382124
Follow Up By: Member - John (Vic) - Wednesday, Aug 31, 2005 at 12:46
Cruza 256x75xR16 is what I run.
Yeahs its an RV TD 4.2.
This is the same rolling diameter as the original tyres fitted by yota.
No issue at all with drive issues 100 KMPH = about 2400 RPM fuel wise if not heading into a strong head wind is about 650 km's' per 90 odd litre
tank on the black top obviously changes when in low range.
No issue off road, although I have to admit that sometimes an inch or to more clearance under the diff's and spring hangers would be nice.
I stayed with original diameter tyres as I did not want any potential insurance problems with non standard dia
wheels.
382160
Reply By: chump_boy - Tuesday, Aug 30, 2005 at 22:25
Not meaning to hijack the thread, but does anyone know if it would be worth retro-fitting a factory front and rear difflock in a 98 105 Series?
I am tossing up wether to go down that road, ARB road, or the Lokka road.
The lokka is so far coming out ahead, as it will cost less than $1600 to buy front and rear lockers, and free wheeling hubs, and get it all installed.
But I have not heard much about ex-factory locker retro-fitting.
Chump
127548
Follow Up By: Member - John (Vic) - Tuesday, Aug 30, 2005 at 22:38
Its always worth fitting Lockers if you have the dollars.
In my view spend the extra $ and fit the ARB lockers.
Plenty of info in the archives on here on the pro's and con's do a search and have a read.
382049
Follow Up By: at4x4 - Tuesday, Aug 30, 2005 at 23:17
dont just
shop on price, you cant really compare a locker you cant control, with one you can.....
382067
Follow Up By: Kalgoorlie Escapee - Wednesday, Aug 31, 2005 at 10:37
Nobody has really indicated if factory lockers can be retro fitted. If so where and how much? Does toyota do them on existing vehicles (ie already registered)?
382136
Follow Up By: chump_boy - Wednesday, Aug 31, 2005 at 10:41
Thanks Kalgoorlie for actually reading the question!
I think you are the first one....
382137
Follow Up By: at4x4 - Wednesday, Aug 31, 2005 at 11:07
Isnt that one of the joys of airing your thoughts on a public
forum, that you never know what responses you will end up with.
Especially on a
forum which doesnt seperate "chat" , "tech" or trip information, but perhaps going to www.lcool.org and joining the 100 or 7_ series email lists may get him the technical info he may need.
382148
Follow Up By: Member - John (Vic) - Wednesday, Aug 31, 2005 at 12:38
To the best of my knowledge you can't retro-fit Toyota Lockers.
They are not sold as an aftermarket fit.
382157
Follow Up By: Kalgoorlie Escapee - Wednesday, Aug 31, 2005 at 14:07
Thanks for that
John. That was a simple and consise answer that elliminates the genuine from the choice option.
382181
