Uploading to a Garmin Map60cs
Submitted: Wednesday, Aug 31, 2005 at 09:46
Wontok
Good Morning
I have a Garmin Map 60cs loaded with City Navigator and I am trying to load about 24 waypoints from OziExplorer to my GPS. It only loads about 4 waypoints and there is no message or anything to indicate that the memory on the GPS might be full or that the upload has failed. Can any one help me. Thanks
wontok
Reply By: Member - Jay Gee (WA) - Wednesday, Aug 31, 2005 at 10:21
Are you trying to upload via USB or Serial Cable?
If USB - check under "Configuration - COM" - have you ticked "Garmin USB"?
Under "Configuration - GPS" - have you selected "Garmin Map 60"
Jeff
127595
Reply By: Wontok - Wednesday, Aug 31, 2005 at 14:35
Hi Jeff
Have set up OziExplorer as you have outlined, any other suggestions ? Thanks
127635
Follow Up By: Wontok - Wednesday, Aug 31, 2005 at 14:36
Jeff
Yes I am using a USB cable
382187
Follow Up By: Member - Jay Gee (WA) - Wednesday, Aug 31, 2005 at 14:46
Hmmm - most strange
I'm at work right now - I'll have to get to
my home computer - in about 4 hours
382192
Follow Up By: Member - Jay Gee (WA) - Wednesday, Aug 31, 2005 at 21:27
Hi Wontok
I haven't found anything else to try out. If my previous suggestions haven't worked I suggest you send an "SOS" message to OziExplorer at
info@oziexplorer.com
Jeff
382257
Reply By: Wontok - Wednesday, Aug 31, 2005 at 22:52
Hi Jeff
Thanks for that, I have sent an e-mail to Oziexplorer.
Wontok
127698
