Snorkel Sealed?
Submitted: Saturday, Sep 03, 2005 at 14:00
ThreadID: 26099 Views:2958 Replies:9 FollowUps:5
Post 25902 is about sealing snorkels and ways of checking seal. One suggestion was to pressurise it and check with soapy water.
I took one of the other suggestions - to take the ram off and put my hand over inlet (carefully). This stalled the motor (patrol 3l TD) readily. Is this enough to say my snorkel is well sealed?? In post 25902 no one said this method was ok or not.
Any comments appreciated.
Reply By: Richard Kovac - Saturday, Sep 03, 2005 at 14:16
jdpatrol
Not a smart thing to do putting your and over the inlet,
You can cause a lot of damage to your hand drawing blood to the surface
If you need to test in this way I would suggest using some heavy cardboard or a like
I also think the engine would stop long before all air supply was cut off
Richard
AnswerID: 128108
Follow Up By: Rosco - Bris. - Saturday, Sep 03, 2005 at 20:20
Bloody big sook ... obviously you've never copped a decent hikkey .. :o)
FollowupID: 382751
Reply By: at4x4 - Saturday, Sep 03, 2005 at 15:04
easier still, put a plastic shopping bag over the snorkel head.
You will hear any leaks very easily then, because of the amount of air the engine tries to draw through the leak.
AnswerID: 128114
Reply By: Haza - Saturday, Sep 03, 2005 at 16:40
The air will take the path of least resistance, by doing any of the above methods I'd be confident that it is sealed correctly. If you have a frog mouth (oneway valve) on your Air box just make sure it is cleaned out and working properly.
AnswerID: 128122
Reply By: Exploder - Saturday, Sep 03, 2005 at 17:30
Pressurise it, just be careful how much pressure you pit into it as you may damage the seals you just made or create new leaks. Also you will be surprised at how much air can escape.
Was testing a new hydraulic system the other day before we did the flushing and fully pressurised it, with just pressurised air at 7 bar ( 73 Psi) we were finding pinhole leaks in welds and fitting’s, and this system operates at around 3500 PSI!!!.
I think you may find more leaks in the snorkel set-up than you want to know about but 90% of them will be so small they will not case any problems anyway.
AnswerID: 128131
Follow Up By: G.T. - Monday, Sep 05, 2005 at 17:54
7 bar = 73psi ???? therefore 1 bar = 10.43 Psi ???? My info gives one bar = 14.5 Psi. Regards G.T.
FollowupID: 383036
Reply By: Member - Nick (TAS) - Saturday, Sep 03, 2005 at 20:48
I was testing our vehicles snorkel for leaks before we headed away to Cape York a couple of years ago with a plastic bag over the ram.All was good,motor was starting to die,couldnt hear any leaks(head close to engine) when all of a sudden"BANG",nearly fell over backwards.Shut off engine and started to worry a little until I realised the plastic bag popped.PHEW
AnswerID: 128158
Reply By: jdpatrol - Sunday, Sep 04, 2005 at 11:17
thanks all
will check using plastic bag over ram.
jd
AnswerID: 128214
Reply By: D-Jack - Monday, Sep 05, 2005 at 15:02
The correct way to do it would be to put your face of over the intake - if your eyes are pulled out of their sockets and you have to pull them out to the intake by the nerves at the back, then .... well... still got no idea if the snorkel is sealed .
AnswerID: 128375
Follow Up By: jdpatrol - Monday, Sep 05, 2005 at 15:08
Never imagined this post would generate a bit a humour, what with Neil's post as well.
Intending to position SWMBO under ram when I try plastic bag method..........
JD
FollowupID: 383018
Reply By: Billowaggi - Monday, Sep 05, 2005 at 16:36
Hi all .The best way to check for any induction leaks on a diesel is to spray a little Aerostart around all the joints with the engine running a change in engine sound or speed will indicate a leak,do it sparingly though.
Regards Ken.
AnswerID: 128383
Follow Up By: jdpatrol - Monday, Sep 05, 2005 at 16:48
thanks Ken
Will that result in oil (?) getting on the air filter?
That worries me a bit because Patrol filter element is not oil impregnated.
JD
FollowupID: 383027
Reply By: Billowaggi - Monday, Sep 05, 2005 at 17:58
should be no problem JD Aerostart is mostly ether and you are only puttig in a bit of vapour. I yous' to pre deliver new Ford tractors this was the method recomended by Ford to test the air induction pipes and joints between the air filt and engine. Ingress of dust was the main prob we were looking to prevent ,this is critical with a 4wd as well
Regards Ken
AnswerID: 128407
Follow Up By: jdpatrol - Monday, Sep 05, 2005 at 18:12
thanks again Ken
FollowupID: 383041
