duel battery price
Submitted: Monday, Dec 16, 2002 at 01:00
gus gus
Hello,
You'll have to bare with me and use small words because I don't know much. Anyway, I want to get a aux battery installed in my '92 2.8L Diesel Hilux, but I don't want to do it myself. It needs to work, and I don't have time to experiment. So, how much is reasonable to pay for someone else to do it, and is there anything in particular i should ask for. It is to run a fridge, but also a light for
camping and maybe some other stuff occasionally. Mainly the fridge though.
Thanks in anticipation.
Gus
Reply By: OziExplorer - Monday, Dec 16, 2002 at 01:00
If you do some of the running around yourself you can save some dollars.
If you get the extra battery tray, which you could fit yourself if you wanted, then take it to an auto electrician to do the wiring.
The Redarc Battery Isolater is about the best going on a value for money basis:
http://www.redarc.com.au/sbi.htm
Cost about $110 incl GST
Proper deep cycle battery 75 amps - about $130 incl GST.
Fitting - material $40 approx (should be close)
Labour - $80
9741
Follow Up By: Tony - Monday, Dec 16, 2002 at 01:00
I think you will find it's a bit more envolved that that on a 2.8, not a lot of spare room under the bonnet, but it can be done.
Otherwise put the battery in the back Ute or Tray.
5053
Reply By: Member - Sam - Monday, Dec 16, 2002 at 01:00
Gus, earlier in the year I had a Dual Batt system fitted to my 90' Hilux (Dual Cab diesel). I had a Rotronics (RFC12) system fitted (
http://www.rotronics.com.au/ or contact Rod Street on 1800 644 620). They have a wide range of systems for different uses. Rod will be be able to tell you which one is best suited for your needs. I had them ship it down to me (in Syd) and then had my mechanic fit it all up when I had the truck in for a service (I simply didn't have the time to do it myself). I have the 2nd battery situated in a case in the tray. The battery is a Overlander 700 (same as my starting battery) and ran my fridge and inverter for a 2 week trip up around
Cameron Corner, Innaminka, down through Gammon and
Flinders Ranges and had absolutely no problems with the setup at all. But it is a case of each to their own. Different setups suit different people. This one suits and works for me. This may not be the case for yourself. cheers, Sam.
9747
Reply By: Member - Melissa - Monday, Dec 16, 2002 at 01:00
Hi Gus,
We've recently gone through this exercise for our GU Patrol. In the past on other vehicles we've had a simple solenoid system and a manual switching system. Solenoid system worked very
well for us to run the fridge on longish trips, with most stops being 1 to 3 nights with varying amounts of driving in between.
For the GU we were happy to go with solenoid system again but due to sensitive system management systems in cars these days, we were advised to fit only a ARB smart solenoid or a fairly new type of solenoid available through auto electricians, both with surge protection.
As far as batteries go, your choices are to fit a heavy duty or deep cycle battery. Without getting too technical, deep cycle batteries are really designed to be fully discharged, then fully recharged. Failing to do this will drastically reduce the life of the battery. In simple terms, this means that unless you intend stopping for at least several days at a time and running your fridge and lights enough to fully discharge the battery, then driving for say 8 to 10 hours to fully recharge the battery, this type is probably not suitable.
A heavy duty battery, on the other hand can be drawn down a bit and recharged bit by bit without causing any problems. So if you are planning 1 or 2 night stops with a bit of running around, weekend trips away etc, a HD battery is more suitable.
There are hybrid/gel based batteries around that can also complicate the mix and all have their place and application, but what I have given you is the basics. Rotronics and Pirhana have battery management systems that offer a bit more control and flexibility but you need to talk the experts to figure out the nuances. If you intend to use solar panels at a later date, you might be better off to go with one of these systems.
My last piece of advise is to
shop around. We found a big variation is prices for all systems both fitted and unfitted. The biggest difference was from two auto sparky's to supply and fit a solenoid system; one quoted $450, the other $660!!!!
Shop around...
:o) Melissa
9753
Reply By: gus gus - Monday, Dec 16, 2002 at 01:00
Alrighty! Thanks a lot everyone. You've been really helpful, and now at least i know a little bit about it. Now I'm only part sucker and easy target. I'll start shopping around tomorrow. Much appreciated.
Gus
9795
