12V cooler ventilation
Submitted: Wednesday, Sep 07, 2005 at 08:48
Member - Tonester (VIC)
Got a 240V/12V cooler as a present on the weekend, and I think its a simple question. The thing has an intake fan at the rear, and two heat outlets on the side.
I presume that people usually plug these these things in while driving to keep it cold until the destination? But you can't block the inlet/outlets, which means 3 of the 4 sides need to have space. And that makes it difficult to keep it stable, esp around corners, or if 4wd'ing. (unit is about 1ft x 1ft x 2ft).
I have managed to wedge it in a bit, but on a big trip it will get smothered or knocked around.
Any tricks to it? My first car cooler, I've always used ice in eskys so far.
Reply By: Member - Blue (VIC) - Wednesday, Sep 07, 2005 at 09:05
Hi Tonester,
my step father has a waeco unit which he built a timber(craft wood) box for. It's about 8" high and about 2" longer and wider than the cooler. He has it fixed behind the front seats in his troopy and uses a couple of chocks of wood to keep it secure in its box with the extra length & width for ventilation. The box is secured to the vehicle and the cooler just slips in and out as required. They use it in conjunction with their fridge to keep drinks and snacks handy as the fridge is secured way down the back out of reach from the front seats.
128806
Follow Up By: Member - Tonester (VIC) - Wednesday, Sep 07, 2005 at 09:15
Thanks Blue.
Forgot to mention also this unit is vertical, ie. the 2ft is the height, on a square base. The door & handle is on the 4th side
383374
Follow Up By: HelenWheels - Wednesday, Sep 07, 2005 at 09:24
will it be permanant in the vehicle Tonester?
383377
Follow Up By: Member - Tonester (VIC) - Wednesday, Sep 07, 2005 at 09:29
HW, nope, very portable.
383378
Follow Up By: HelenWheels - Wednesday, Sep 07, 2005 at 11:33
This might sound dumb but ... velcro?
There is this stuff called "super velcro" or "monster velcro"
Place a bourd like ply on the flood of your vehicle semi permanamtly and some strips on the bottom of the fridge and ... bobs your uncle.
It alows for a little movement but its a start. Its an idea...
383394
Follow Up By: Member - Tonester (VIC) - Wednesday, Sep 07, 2005 at 11:39
HW, thanks. Velcro would help keep it still, but still have to keep all the sides clear of obstructions still I think.
383396
Reply By: Mike DiD - Wednesday, Sep 07, 2005 at 11:38
Make a "chimney " out of 4" by 2" PVC downpipe so air can in/out of the vents while things are packed around the fridge.
128831
Follow Up By: Member - Tonester (VIC) - Wednesday, Sep 07, 2005 at 11:40
Thanks Mike.
383398
Reply By: Spade Newsom - Wednesday, Sep 07, 2005 at 18:05
It sounds like one of those 15litre fridgemasters (green or blue I think). I have a green one.
Because it is an upright you are pretty limited to what you can do.
Mine sits in the shed with a couple of coldies in it. That is about all I could find to do with it.
128911
Reply By: Member - Jeff M (WA) - Wednesday, Sep 07, 2005 at 21:20
My Waeco Cooler has both vents on the lid, in fact all the electonics are in the lid which mean you can chuck ice in it as
well which is cool.
You would need to keep the vents free so it can exaust the heat. These coolers are ineffeciant and produce about the same amount of heat as they move. ie if it cools by 5c it generates 10c of heat.
I use
mine as a fridge, I modified it by putting bigger faster fans and put fans on the exaust as
well as the intake, I upgraded the peltier chip to a 6 amp instead of a 3 amp, sealed it better (with siliocne) and put a digital thermostat (off an air con) in it so I can pre set the temp and it cycles like a fridge.
You'd be amazed how much better they perform with a little tinkering, if you're any good with basic electronics it might be worth a play.
Mine will actually freeze now if I set the thermostat so, but I normally leave it at about 4c and it cycles about 50/50. Mines a 45L. I run it off the dual batteries while we are
camping and with the new calcium batteries (2 x 105 amp hr) it'll run all weekend with the stereo, lights and
water pump without a problem.
128956
Follow Up By: Member - Tonester (VIC) - Thursday, Sep 08, 2005 at 08:06
Not worried about efficiency or quality, it works and its my only one. Will last longer than ice, but won't be playing with the internals, I'd just break it!
383513
