Chaz,r u there???
Submitted: Thursday, Sep 08, 2005 at 12:25
ThreadID: 26261 Views:1940 Replies:3 FollowUps:1
got a question re lockup switch gu patrol (post 23246).i'm buying the gear for your circuit diagram, is the relay a narva 68028??. also what does the foot switch actually do and is it essential to the system.
Reply By: chump_boy - Thursday, Sep 08, 2005 at 13:11
Chaz isn't here, dude.....
AnswerID: 129055
Follow Up By: DEANO WA - Thursday, Sep 08, 2005 at 13:43
the name says it all
FollowupID: 383557
Reply By: Chaz - Thursday, Sep 08, 2005 at 16:16
Deano WA,
I'm sorry I can't remember the part number for the relays, but I used the ones with suppression resistors across the coils and they need open and closed contacts. The little diagram on the side of the relay shows if they have normally open and normally closed contacts. I'm sure the salesman should be able to help you there because he will have the catalogue.
The foot switch is used to turn it on while driving, leaving your left hand free to use the shifter. I only switch the dash switch off when I take it in for a service, so if the mechanic drives it and presses the foot switch, it won’t work. To switch it off, you just have to touch the brake pedal.
This system works well for me
Chaz
AnswerID: 129102
Reply By: DEANO WA - Friday, Sep 09, 2005 at 09:30
thanks mate, im dealing with teenagers in repco that didn't no what a relay was, i'll try narva direct. cheers for the info
AnswerID: 129250
