RA Rodeo
Submitted: Thursday, Sep 08, 2005 at 17:32
millar
Just bought a GME 4400
UHF Radio and want to install it under the CD player of A 2004 RA Rodeo.
Anyone know how to remove the front facia to get to the cradles without breaking anything??
Bruce
Reply By: Member - Peter D M - Thursday, Sep 08, 2005 at 17:46
hi millar,
when i did
mine i started at the bottom and gently lifted it up and the clip in studs pulled clear. i cant remember all the details but it wasn't any trouble and i didnt break anything.
regards peter
129118
Follow Up By: millar - Thursday, Sep 08, 2005 at 19:12
Peter,
Thanks for that, saved me $140.00 getting it installed by the professionals.
regards
Bruce
383627
Reply By: Brad G (SA) - Friday, Sep 09, 2005 at 19:21
Simple mate. Use a medium blade screwdriver and gently pry around the panel until it comes out. First though slide out your ashtray. Once you have it out simply unplug the 4wd and
hazard light plugs and the whole thing will come out. You can probably use the bracket holding in the plastic tray to secure the radio. This is what I did when I fitted my Pioneer DVD player and separate screen. Worked a treat. You can run your power and antenna wires down to the firewall and through one of the plugs on either side of the engine bay. Simply poke a phillips head screwdriver through the plug to make a hole. When the wire is poked through it will seal the hole effectively watertight.
Hope this helps.
Cheers Brad
129372
