Turbo Diesel 80 series Landcruiser
Submitted: Thursday, Sep 08, 2005 at 17:33
ThreadID: 26271 Views:3834 Replies:5 FollowUps:2
Hi to all! Thanks to all who replied to my questions about the T/D landcruiser. Due to the age of the 80 series, would you think that most of the 'big ends' would have been replaced by now? At what sort of kilometres does the problem seem to occur? Would we be able to find a good T/D between $16000 - $20000? Hope you've all experienced a beautiful springs day as we did here in S.A!
Reply By: See You - Thursday, Sep 08, 2005 at 19:27
You may find a crap one between 16 and 20K. Most early - mid 90s mode;ls that I have seen advertised have all got over 200,000 kms on the clock. You start needing a lot of repairs on these if they have been operation in high temperature locations or used for towing vans, boats etc... Things like alternators, starter motors, radiators, air con, gearboxes, bearings and the like just break. An alternator rebuild for this car is around $800-$900. A turbo rebuild would be around 3K. The engine in these should last for upwards of 350,000kms but it is all of the ancilliaries that will cost you money.
I recently (last week) saw a 96 Turbo 80 series with 160,000 kms on the clock for $32000 Low kays ones are quite rare nowdays. This seems to be about the price for a really good one.
I reckon if you are in the $16-20000 mark you will be buying a dud. Go the $25-30000 and get a good one.
AnswerID: 129132
Reply By: snailbate - Thursday, Sep 08, 2005 at 21:01
hi
most toy engines are not treated right the thing to do is have the junk flushed out of the engine this is a problem with owners not change the engine oil at 2500 ks the carbon junks up the old fasion engine there is a oil clearner that is available when you read the 4WD MONTHLY it is about $99-00 per 20 ltres and will drive out the carbon and clean out the carbon from the piston rings
Life MEMBER snailbait Oberon HF RADIO CLUB VKE237 mobile 7661
AnswerID: 129159
Follow Up By: muzzgit (WA) - Friday, Sep 09, 2005 at 00:25
WHAT???
""the carbon junks up the old fasion engine""
What are you trying to say?
FollowupID: 383678
Reply By: muzzgit (WA) - Friday, Sep 09, 2005 at 00:16
I don't beleive what I've just read here. Change the oil every 2500 K's....you are joking mate!!!!
JohnnyP, The only 80 series T/D's that had big end problems were the first release with the older style engine. This was fixed under warranty by Toyota in most cases. In some cases the owners had to pay for it themselves but it is not a huge cost. The engine doesn't need to come out, as it was only the big end bearings that needed replacing.
The thing is, these engines were doing less than 80,000 K's before the problem was evident, so as mentioned in a response to your earlier post, any motor with more than 100,000 K's on the clock will have been fixed.
Price wise, no! If you find one under 20 grand, leave it where it is.
AnswerID: 129210
Reply By: Outnabout David (SA) - Friday, Sep 09, 2005 at 14:10
if there was a problem it was usually around the 100K mark. Mine has never had the bearings go or changed but was looked after and well maintaind from new and has now done 220K. Not all of them went and the jury is out abouyt why some fail and others don't. I know of some at 500K and the bearings have been OK. The cost to replace and piece of mind is about $600 and the bearings from Toyota now supersede to the better type as fitted to the later multivalve engine.
As far as price goes I have seen some good ones in SA around those prices. For thje later multivalve engine late 95 on your looking in the low $30 K.
The original turbo's were excellant vehicles so don't let the bearing issue put you off. I would try to find one after late 92 though because of the 16" wheels ande bigger brakes.
AnswerID: 129313
Follow Up By: Member - Terry B (NSW) - Friday, Sep 09, 2005 at 16:27
hi all
I run a fleet of 40 vehicles and inn the fleet there is three toys and they are HYLUX 14 SEAT COMMUTER 2005 x 2 and a 21 seat bus 2004 these engines are simlar to the diesil engines in the 4wd the 21 seater is Turbo, The service book says 5000 ks chainge oil and filter if it has done city running ie stop start toyota recomend change oil at 2500ks the flushing of the engines for diesel is still the way to go as the rings get bound up and the engine loses power if you do not treat the engine as toyota recomends
FollowupID: 383812
Reply By: bollo - Friday, Sep 09, 2005 at 21:15
have a look in the trader section ,,I have one in there a '97 multivalve turbo diesel GXL with only 172,000kms on it...........don't want to sell at all but the "X" has different ideas about that...........I have owned it since new and looked after it as I planned to keep it for life but must go this weekend or it will be wholesaled on monday, a cheaper one I don't think you will ever find....$24,500 ono ......0427 644717,,,,,, only problem is I live in Griffith N.S.W.
AnswerID: 129392
