Waeco CF-80 will not turn off above setting two
Submitted: Thursday, Sep 08, 2005 at 18:09
Member - Bruce and Anne
Getting ready to set off on a couple of weeks holidays, loaded up the Waeco with the meat this morning and find tonight that it is all frozen, keeped an eye on the voltage and find with charge on it is going down. Checked all normal faults, emergency switch is off, outside temp 23o, but if I have it on above setting 2 it will not stop. Anyone had this problem, would be nice to know what it is before taking it back.
Cheers Bruce.
Reply By: Notso - Thursday, Sep 08, 2005 at 18:33
Haven't had the problem but I would suspect that the system is low on Gas. Either that or a faulty thermostat.
At ambient 23 she wouldnb't have to work too hard to freeze the meat. Check what temperature the thing is getting down to. If you want to freeze for any length of time you need to be down around -15 degrees.
129123
Follow Up By: Member - Geoff M (Newcastle) - Thursday, Sep 08, 2005 at 18:44
More likely the thermostat. A shortage of refrigerant would show up regardless of the setting on the stat.
Geoff.
| Geoff,
383622
Follow Up By: Member - Bruce and Anne - Thursday, Sep 08, 2005 at 18:50
Only way it will shut down now is to turn it off.
I wander if Waeco will give me a loaner while they fix this one, can only try or it back to ice, oh no.
Thanks for the info, Bruce
383624
Follow Up By: Nudenut - Thursday, Sep 08, 2005 at 20:04
Geoff M
could be short of gas...a system short of gas will run longer but cannot achieve or make temp to satisfy setting of thermostat.....but could also freeze the product. One needs to know what the cabinet temp is.
Notso
2 weeks before you go....geez they could build you a new one in that time, let alone fix it!!
383633
Reply By: Member - Geoff M (Newcastle) - Thursday, Sep 08, 2005 at 19:03
Bummer that with the trip at hand.
You could always try switching it on and off at regular intervals. Only problem being is it likely to die completely mid trip.
Geoff.
| Geoff,
129127
Reply By: Member - Poppy (QLD) - Thursday, Sep 08, 2005 at 20:10
Bruce, I had same problem with my Auto Fridge, fitted a new thermostat myself in about 30 minutes, problem solved and I am no Fridgy let me tell you.
If you have the same problem it should be an easy fix
Cheers Poppy
129148
Follow Up By: snailbate - Thursday, Sep 08, 2005 at 20:54
hi
great fridge the auto fridge
383650
Reply By: theanimal - Friday, Sep 09, 2005 at 07:35
check the emergency switch, a small red slide located near where the power cord enters the fridge, if it is turned on, the fridge will freeze all the time.
129221
Reply By: Member - Bruce and Anne - Friday, Sep 09, 2005 at 17:17
Talked to the people at Waeco this morning and was told it probably the temp sender unit which is in the casing, but in the 80/110 they put a spare in , so only a 1/2 hour job. Seems it a bigger problem in the 50's so all units now have a spare.
Heading down to the
Gold Coast for them to fix, was going to be down that way a later but thats not a problem. Anyway hope that the trouble.
Cheers for now Bruce
129348
Reply By: lazylcd - Friday, Sep 09, 2005 at 22:15
try the emergency switch first, bound to be that. flick it across or is it up or down , i think u can work it out :o)
129401
Reply By: Alloy c/t - Saturday, Sep 10, 2005 at 00:08
Bruce as you said , your heading to the coast , Fridge
shop will fix I,m sure in no time at all , try getting that from Engle [and I own both] ,,,,
129423
