heavy towing with Patrol 3 litre diesel auto
Submitted: Friday, Sep 09, 2005 at 05:15
ThreadID: 26289 Views:10376 Replies:8 FollowUps:4
Hi all,
Wonder if anyone have experience towing 2.5 tonne caravan with a Nissan Patrol 3 litre turbo diesel auto ?
Been told it goes like a snail especially during take-off !
Appreciate any comment
Sanga
Reply By: hl - Friday, Sep 09, 2005 at 06:53
Well... you got an all up weight of over 5 tons....
What do you expect, Ferrari take offs?
Get real!
AnswerID: 129219
Reply By: traveller2 - Friday, Sep 09, 2005 at 08:01
Right on max towing capacity so could have a big effect on drivetrain longevity if doing it for any length of time. The auto will help getting it moving off the line but the accelerator would be well down I'd imagine to kepp things on the boil.
AnswerID: 129226
Reply By: vitara - Friday, Sep 09, 2005 at 08:34
Buy an F250 V8 turbo diesel 4x4 . Then you will have no problems, trying to move 5 tonne with a 3L your got to be kidding. My commodore towbar is rated to 2100kg I'v have nothing left of it if I towed that weight with it let alone trying to pull up when I needed to stop, I can just hear the tranny now cooking between me and my wife.????? Dont do it !!!!! Regards Vitara
AnswerID: 129235
Reply By: Chaz - Friday, Sep 09, 2005 at 08:56
Sanga,
I have favoured autos for towing for a long time and although they have some limitations, there is a lot of room for improvement. The Nissan auto’s are strong enough, but will overheat if you tow heavy loads, especially in overdrive. This is because they have a lot of slip built into them, which gives you a nice smooth ride and gear change, but does you no favours in heat build up.
If you have an auto, and need to tow heavy loads, you should get a “Shift Kit” fitted and fit the largest oil cooler to the trans that you can. Also a manual converter locking switch will help it run cooler.
Check THESE guy’s out, because they have the goods to beef up a Nissan auto.
With the right modifications to your gearbox, you should be able to tow heavier loads with less wear and tear.
Chaz
AnswerID: 129243
Reply By: fourstall2000 - Friday, Sep 09, 2005 at 10:54
I have a 17 ft van and the 3.0 litre auto tows it much better than my previous gq 4.2 turbo.
It has more power and torque plus a quicker pick up for passing.
I never tow in overdrive.
AnswerID: 129269
Follow Up By: angler - Friday, Sep 09, 2005 at 22:32
I tow a tandem about 2 tonnes with my auto 3 litre with no probs. I try and always keep the box locked up. If it starts shifting up and down I turn the O/D off.
www.bycompass.com
FollowupID: 383865
Reply By: Motherhen - Friday, Sep 09, 2005 at 22:49
Like Fourstall we are towing with 3 ltr td auto 1/2002 model. Rarely use overdrive - only a very easy run - generally leave o/d off. Even at current prices, the extra diesel is cheaper than doing the gearbox out in the never never. Van is 2.2 tare, so fully loaded would be over the weight for the auto. Powers that be tell us that the engine is exactly the same in the manual 3 ltr which can tow 3.5 t. Goes really well in normal conditions, but did snail up a narrow winding dirt road from a standing start once - had we known the area, we would have done it in low range. Got a exhaust temp gauge fitted to watch we don't cook the motor. We'd get an F250 if we could, as we would not have to worry about loose sand and other towing hazards. Rumour has it that the 3 ltr pulls better then the 4.2. As it seems ours is just into the upgrade since the model that blew motors, we are going to stick with it - cheaper to replace a blown motor than upgrade the vehicle. Watch for posts by Macka (Macka176 on caravanners forum) - he won't go past the 3 ltr and tows a bigger van with same tare weight as ours. We do drool when we see a nice Effie though - now if i win Lotto - - - -
AnswerID: 129410
Reply By: jdpatrol - Saturday, Sep 10, 2005 at 07:37
Sanga
I was bemused at the first few responses. Like fourstall, angler and motherhen I also have an auto 3l GU TD and tow a caravan with weight over 2T. O/D off also. Performs fine. Worst mileage Ive had was 20 l/100km into a strong headwind.
But the thing about the Patrol is that you have a vehicle that can do some serious off-roading when you get to your destination. [What was the ramp over angle for the F250 again, 130deg?? Not for me]. As always i guess it depends on your needs (and your means).
AnswerID: 129430
Follow Up By: sang - Monday, Sep 12, 2005 at 09:37
Hi jdpatrol,
I am presently towing the van with a non-turbo 4.2 troopy. Whist the stability of the setup is near perfect, a lot has to be said about the snail pace whenever any grade is encountered. And also the ride !
Am seriously thinking of changing to a patrol.
What about going off from standing start before the turbo cuts in, especially on an incline. Do you think its adequate ?
Sanga
FollowupID: 384107
Follow Up By: Leroy - Monday, Sep 12, 2005 at 09:57
It's not going to be an issue with an auto and with the manual make sure the turbo is a spinning before take off. I'm sure others may suggest the use of a dtronic to get a bit more low down torque, and the turbo comes in a bit earlier so you don't have to slip the clutch as much.
Leroy
FollowupID: 384112
Follow Up By: jdpatrol - Wednesday, Sep 14, 2005 at 19:54
Sanga
Just a thought, you know how the troopy feels. Therefore I thought it might be useful to compare the torque figures of your vehicle and 3L TD PAtrol (340Nm?).
Also, why dont you just hook on your caravan on a dealer's Patrol and find a hill / run around a block. Whilst you wouldnt want to do it over any distance, in our case Patrol is ok without stabiliser bars. Depend on the balance of your caravan too I guess. This would make it easier to try out, and hopefully put your mind at rest one way or another.
Best of luck
JD
FollowupID: 384582
Reply By: Redback - Monday, Sep 12, 2005 at 11:34
I maybe wrong here but is'nt the auto 30lte Patrol only have a max tow rate of 2.5 tonne and the manual has 3 tonne, i don't think towing the max tow rate would be good for any vehicle, i'd turbo your Troopy seeing as you like what you have except for power, and then you'd have the perfect tow beast and it would work out cheaper too.
Baz.
AnswerID: 129630
