This weeks hot topic, fuel consumption....
Submitted: Friday, Sep 09, 2005 at 18:04
guzzi
Now that I have your attention.
My next door neibour owns a V6 rodeo trayback, and have of late been noticeing how thirsty it is, 13.5 to 14 lt per 100ks, more if he gets up it, its also swallowing $100.00 bills each time he fills up.
"They all do that sir, its an undocumented feature" is the usual reply to isuzu v6 fuel consumption complaints, however.........
I remember reading about a mod to the airbox someone had posted on one of the many forums I read, that he claimed decreased his fuel consumption, do you think I can find it again!?? fat chance.
I wasnt paying attention as I have a diesel with a snorkle.
So does anyone else have any airbox mods for thirsty V6's?? or links to them??
The guys a kiwi, needs all the help he can get...........
Reply By: MAVERICK(WA) - Friday, Sep 09, 2005 at 18:36
v6 = fuel guzzler..............no matter what he tries (apart from leaving it at home) it will drink fuel. The engine and gearing and other stuff mean that is the way it is. 13-14l/100kms is good for this type of vehicle...........and no matter what anyone tries to tell you all the other v6 utility type 4wds are the same. just let him bask in the knowledge that unlike his hp diesel cousins he doesn't need to spend a squillion dollars servicing it every 5000kms. for no other reason than i can - this week i used an sv6 commodore (6000kms on the dial) for a quick 1000km run north of
perth - the little computer says we averaged 8.7l/100kms - a fair bit of the time was spent a bit over 2700rpm in d - in my books that is very impressive.
rgds
129362
Follow Up By: Member - Blue (VIC) - Friday, Sep 09, 2005 at 19:24
V6 Triton, 12L/100km at the moment and that's mostly local stop/start driving. Since fuel sky rocketed, we stopped using the second car when possible.
383831
Follow Up By: gramps - Saturday, Sep 10, 2005 at 08:40
V6 Hilux just under 12l/100km again for local stop/start driving. Guzzles if you've got a heavy foot.
383891
Reply By: Ando80 - Friday, Sep 09, 2005 at 19:17
he can't complain, I just refilled and my 80 series diesel with after market turbo is returning only 20.8L/100km.... go figure that one!!!
By the way, if anyone has any ideas on why
mine is using so much, feel free to give me a follow up.
Ando
129371
Follow Up By: Member - Bill S (NSW) - Friday, Sep 09, 2005 at 19:25
Hey Ando, Fill your auxillery to the top and run it till it faulters then check your distance travelled.I just filled
mine which is the same as yours and travelled from shellharbour to
Newcastle and got back to
sydney befor I switched tanks. Compare that to yours?I will keep an eye out for your reply when you complete the test.
Regards BILLS
383832
Follow Up By: Member - Pezza (QLD) - Saturday, Sep 10, 2005 at 16:11
He doesn't want to know "how far", he already knows that, he wants to know "why"!
Pezza
383929
Follow Up By: Member - Pezza (QLD) - Saturday, Sep 10, 2005 at 16:17
Oh, and he doesn't need to be told it's because he doesn't have a bloody 'tin can' in his fuel line!
Pezza
383931
Reply By: wilbur - Saturday, Sep 10, 2005 at 08:25
HI Ando 80 I did get your injector's and pump done asap as
mine was using that much fuel before it blew up cracked number 2 pistion with 160 km on the clock only thing we can put it down to was the over fueling on that cylinder sent pump and injectors away and all were stuffed and get a comprestion test to check for damage to motor
129434
Follow Up By: Ando80 - Saturday, Sep 10, 2005 at 17:39
thanks for that, i was really hoping it was a cheaper fix, oh
well, s'pose i better cough up now before i have to pay for a whole new engine, if thats the reason!!!!!
383940
Reply By: Member - Bill S (NSW) - Saturday, Sep 10, 2005 at 19:38
My 80srs after market turbo has done 500,000 without any problem I wonder WHY??????????????????????????:??
129501
Follow Up By: Leroy - Saturday, Sep 10, 2005 at 19:55
ok....I'll have a stab......because you bars bugs to keep your windscreen clean?
Leroy
383952
Reply By: Member - Bradley- Saturday, Sep 10, 2005 at 23:26
have a squiz over at australia4wd.com in the jackaroo
forum, heaps there on modding the v6 for better efficiency.
If its a manual yep, can improve heaps, but if its an auto then not much will help.
Cheap basic stuff, foam element, cold air intake with removal of heavily restrictive inlet piping, and removal of restrictors in the exhaust.
129511
