80 series diesel primer pump problems
Submitted: Wednesday, Sep 14, 2005 at 10:59
ThreadID: 26444 Views:12177 Replies:9 FollowUps:1
Has anyone ever experienced problems when trying to prime the diesel pump after replacing the fuel filter?? Last time I replace it I couldnt get the primer to re-pressure. I was wondering if I need to replace the whole unit or if there is a cheaper solution??
Drew
Reply By: vitara - Wednesday, Sep 14, 2005 at 11:30
Hi there drew, not sure if you have the same set up as my hilux, pretty sure it is but my'n takes at least 05/10 mins of continuos pumping until it gets some pressure in it. I leave the fuel line off on exiting point on the primer pump until it starts to squirt through then I put the supply line on and clamp it up. I do this procedure every time I replace the filter. It has always taken this amount of time to get the fuel through since I'v had it. Had my mate look at it cause I didn't think it shoud take so many pumps and he said it's fine. You have to remember that you are only priming with some thing that moves up and down about 2cm. Unless you normally don't have a problem. Not sure wether you have done this before or is this your first time ???. Regards Vitara
AnswerID: 130040
Follow Up By: Drew - Karratha - Wednesday, Sep 14, 2005 at 11:37
Thanks Vitara
I have replaced the fuel filter a number of times before and it has never taken more than a minute or so to build up pressure. This time I was pumping for at least 10 mins with no change in the pressure of the primer pump. I ended up having to turn the motor over while getting someone else to pump and this took a few minutes of the car spluttering before it started running properly (I believe this isnt very healthy for the injector pump...)
Drew
FollowupID: 384497
Reply By: Outnabout David (SA) - Wednesday, Sep 14, 2005 at 12:43
i think you answered your own question. If it took longer to do than before then obviously something is not right. Sounds like you may have some air getting in or something so it would pay to check your connections.
AnswerID: 130050
Reply By: Member - DOZER- Wednesday, Sep 14, 2005 at 17:38
The pump itself can get a stuck valve.
AnswerID: 130086
Reply By: ToyMotor - Wednesday, Sep 14, 2005 at 17:56
Best solution is to get an aftermarket pump and filter assembly, for about $140. They use 296 filters which at around $5.00, are a lot cheaper than Toyota ones.
AnswerID: 130089
Reply By: crfan - Wednesday, Sep 14, 2005 at 18:37
The best thing to do is fit a primer bulb from a marine shop about $20 just cut the hose fit it in and pump it up its what some bobcats use I have fitted the to the rodeos because they are hard to prime using there primer pumps havent had a prob with any other diesels .
AnswerID: 130092
Reply By: Peter 2 - Wednesday, Sep 14, 2005 at 18:53
Most diesels will prime better with a full fuel tank, my troopy used to prime much easier with a full tank.
AnswerID: 130096
Reply By: HJ60-2H - Wednesday, Sep 14, 2005 at 20:50
There is a shop on Ebay, search under "Landcruiser" that sells the primer pumps cheaply.
AnswerID: 130124
Reply By: 120scruiser - Wednesday, Sep 14, 2005 at 21:12
As said prior make sure you have a full tank and stick some compressed air into the tank at the filler sealing it with a rag while somebody else pumps. It should prime up in no time at all. You have to get the fuel moving. Some times all you do is move air back wards and forwards. Try also to clamp off the supply line before you disconnect it. That way it will stop fuel running back to the tank as the filter is usually right up high.
AnswerID: 130133
Reply By: Billowaggi - Wednesday, Sep 14, 2005 at 23:30
Hi all, I am a diesel mechanic, I do two or three of these type of filters/primers every week only about 50% work OK I think little bits of crap get stuck under the reed valve and they wont pull the fuel through, I carry one of the marine type primer bulbs, as mentioned above , connect into the rubber lines, fuel up in a few seconds.Also great for finding an air leek in the system, just pressurise the system at the tank end the air leek becomes a diesel leek.
Regards Ken.
AnswerID: 130161
