Hole in wheel arch
Submitted: Friday, Sep 16, 2005 at 20:08
ThreadID: 26514 Views:1913 Replies:6 FollowUps:2
Went searching for the source of my dust leak this arvo, and after removing one of the rear wheel arch trims I found it. Much to my dismay a very large, sharp Pilbara rock has perforated the wheel arch leaving a slit about 3mm wide and 10 mm long.
Vehicle is a 2002 90 series Prado.
Now the question is, short of welding how would you recommend sealing it up?
All suggestions greatly appreciated.
Many thanks
MarK Smith
Reply By: Willem - Friday, Sep 16, 2005 at 20:27
A generous dollop of clear silicon should suffice. Do both sides of the slit, if you can get to them. Once that is dry you could cover the repair with some duct tape. I presume the slit is under the carpet? Or is it in the wheelarch cavity behind the trim?
AnswerID: 130461
Follow Up By: SmithyWA - Friday, Sep 16, 2005 at 22:08
Willem
It is up high in the wheel arch and is covered by the plastic trim well above the carpet level.
FollowupID: 384921
Reply By: japmel - Friday, Sep 16, 2005 at 20:31
Smithy,
Fibreglass is what I would use Good strong flexable and you can paint over it.
japmel
AnswerID: 130463
Reply By: Sarg - Friday, Sep 16, 2005 at 20:57
Sikaflex 291
AnswerID: 130466
Follow Up By: SmithyWA - Friday, Sep 16, 2005 at 22:15
Sarg
Just did a google on Sikaflex 291.
This stuff sounds heaps better than regular silcone as it is for marine applications. Will drop down to Whitworths tomorrow and grab some.
I think I will seal it up from undernieth and put a tape patch over it from inside for extra security. Might Sikaflex a few other suss grommets while I'm at it.
Cheers for the replies everyone.
Mark
FollowupID: 384923
Reply By: eerfree - Friday, Sep 16, 2005 at 22:13
Bondcrete!!!
eerfree
AnswerID: 130485
Reply By: Member - Matt Mu (Perth-WA) - Sunday, Sep 18, 2005 at 11:43
KNead it Putty mix, you just snap off a piece and knead it till its uniform colour and force into the slit and then smooth out. This stuff sets in minutes and it can then be filed or carved with hacksaw etc!
I have used it to seal a hole in an exhaust, still there I believe!
Five minute PERMANENT fix!
Matt.
AnswerID: 130658
Reply By: Member - Tonester (VIC) - Monday, Sep 19, 2005 at 09:14
Builders bog and Porion work wonders. Porion sets as hard as nails.
AnswerID: 130756
