Triton Suspension
Submitted: Sunday, Sep 18, 2005 at 22:09
ThreadID: 26574 Views:3534 Replies:3 FollowUps:4
I am looking at buying a triton twin cab and have heard that they have front end suspension problems. Has anyone found this or had experiance with it. What is the problem if anyone knows and is it easy to fix.Thanks
Reply By: sudsy - Sunday, Sep 18, 2005 at 22:55
What year is it?
My first 4by was an 87 single cab Triton. The front ends are basically the same up to 95. the only prob was the wearing out of the idler arm nylon bushes. They take a fair bit of stress like all steering components but are bleep easy to replace.
Suspension wise I just needed to replace the stuffed shockers which were cheapies anyway and put Monroe GT Magnums on.
Wound up the T/B's all the way for a bit of lift and got a wheel alignment but didnt experience any susp. or steering "problems" at all.
This is probably no help to you at all though cos I've got no idea what you're talking about.
Try the mitsi tech section on outer limits. There's heaps of triton stuff there too.
AnswerID: 130742
Follow Up By: Member - Ratty (NSW) - Monday, Sep 19, 2005 at 11:56
it is a 98 model 3l petrol
FollowupID: 385220
Reply By: bushy04 - Monday, Sep 19, 2005 at 10:10
Ratty, what year are you talking about?
I have had several triton utes 2002 and 2004 and have had no problems at all with the suspension.
My only bug bear is the turning circle, and when you take the comfort factor into consideration it pails into nothing.
AnswerID: 130769
Follow Up By: Member - Ratty (NSW) - Monday, Sep 19, 2005 at 11:57
98 model. it is comfort that I am after, if that means turning the wheel a few times more than be it
FollowupID: 385221
Reply By: Wombat - Monday, Sep 19, 2005 at 11:48
Crap turning circle - If you find out what the problem is with the front end let us all know.
AnswerID: 130781
Follow Up By: Member - Blue (VIC) - Monday, Sep 19, 2005 at 12:54
You can wind in the steering stops, greatly improving the turning circle and without fouling anything.
FollowupID: 385227
Follow Up By: Merce - Monday, Sep 19, 2005 at 21:34
A lot of Tritons came from factory with the steering stops almost all the way out. A simple adjustment can make all the difference.
FollowupID: 385309
