Compressor for ARB Lockers
Submitted: Monday, Sep 19, 2005 at 22:13
Neetas
I've read all the posts on air compressors. I'm getting an ARB Front Locker fitted to a GU IV TD4. Was going to get the ARB compressor fitted while at the
shop to run the locker & provide tyre inflation too, but have read some good feedback on the Bushranger Max Air which has got me thinking. Is there any advantage the ARB has over the Max Air? Does either have a reservoir
tank that I've seen some reference too or is this an option on both/either? Any assistance would be appreciated.
Mike
Reply By: Member - Roachie (SA) - Monday, Sep 19, 2005 at 22:31
G'day Mike,
The ARB unit has it's own integrated
tank of about 0.5ltr capacity which is all you need to activate the locker/s. The MaxAir (and most other compressors) need to have a
tank attached. If you only intend to use the compressor for lockers and tyre inflation, you can easily attach a 1kg fire extinguisher as a suitable receiver
tank. You then need to have a cut-off switch (an ARB one is good) and preferably a one-way valve to stop the built-up pressure from pushing back into the compressor.
I use the MaxAir compressor and have 2 tanks (3 litre and 4 litre) which I keep pumped up 24/7 as the air is also used for the biggish air horns on my roof rack. Having owned an ARB compressor (1st generation) I can vouch for how much better/quicker the MaxAir jobbie is at pumping up the tanks and also for tyre inflation.
Hope this assists
Roachie
130936
Follow Up By: Sand Man (SA) - Monday, Sep 19, 2005 at 22:55
Hey Bill,
Have you upgraded to those big arze TRAIN Air horns yet?
Boy would they get things moving:-)
385326
Follow Up By: V8troopie - Monday, Sep 19, 2005 at 23:49
"you can easily attach a 1kg fire extinguisher as a suitable receiver
tank."
interesting idea, I gather you are talking about an 'empty' extinguisher,lol.
Do they have the correct thread at the top (1/8"BSP?) or does one have to stuff around finding taps or machining adaptors? If the latter it might not be so "easy" after all.
The nice thing about the integrated ARB
tank is that it has provision to attach 3 air fittings ( 2 lockers & cutout switch, etc.) Mind you, the dummy plugs are VERY tightly screwed in, possibly having some sealant glue on the threads.
385332
Follow Up By: BenSpoon - Tuesday, Sep 20, 2005 at 10:00
I had huge dramas looking for the right thread for my extinguisher (some tapered imperial crap that no one could help with)- after all that my brain turned back on. Just use the hose that you get with the extinguisher- they are pressure rated to 300PSI. I cut
mine, and stuck a hose clamp on a barbed to Jamec airline fitting. Sorted.
385351
Reply By: Truckster (Vic) - Monday, Sep 19, 2005 at 22:53
Go with the ARB one for lockers and tires, I do, without issue.
130940
Reply By: Paul - OzRoamer Camper Trailer - Tuesday, Sep 20, 2005 at 08:22
My ARB locker has had problems - all repaired by ARB without argument!!
I am lead to beleive that ARB are only now offering the unt in conjunction with the lockers and are not manufacturing these to be purchased as a normal compressor (for tyre inflation, tools and the like) in the plastic tackle box like previous.
Check first I could be wrong!
130960
Follow Up By: Vince NSW - Tuesday, Sep 20, 2005 at 08:44
At the Penrith (NSW) 4x4 show on the weekend thay still had the "plastic tackle box", so must still be selling.
Vince
385344
Follow Up By: Paul - OzRoamer Camper Trailer - Tuesday, Sep 20, 2005 at 09:05
Sorry, they are not making them anymore - but still selling stock and offering warrantee on items sold!!
so I am told.
385345
Reply By: pjd - Tuesday, Sep 20, 2005 at 10:55
get the arb fitted for the locker & then get the max air for pumping up tyres & keep it portable i have the same set up because the arb is slow for pumping up tyres & 2 compressors is better than 1
130983
Reply By: andrewr - Tuesday, Sep 20, 2005 at 12:09
The ARB is
well set up for lockers - has
tank, cut-out and two additional outlets for front and back lockers. Also, the wiring loom comes ready set up for switches for front and back lockers - no additional wires to run after the compressor is installed. In my opinion (having had an ARB for a few months) you'd have to be into some fairly hardcore stuff and pumping up a lot of tyres a lot of the time before the slower inflation rates would really become an issue.
130997
Follow Up By: geocacher (djcache) - Wednesday, Sep 21, 2005 at 02:15
Agree whole heartedly with AndrewR,
Mate, if you are worried about the difference between 10 minutes to pump up 4 tyres or 15 mins (if it's even that much) you are in the wrong place for the wrong reasons.
Crack a can, light a smoke or something. Kick back and when they're done they're done.
My ARB has never let me down and even if it's not the fastest compressor on the market I couldn't give a rats, and as soon as ARB finish buggering around and put out Part RD123 (Courier/Bravo Locker) which has been in development for ages I'll add one to the compressor.
385483
Reply By: Member - Duncs - Tuesday, Sep 20, 2005 at 12:28
I have the ARB compressor adn am nore than happy with it. I use it only for tyres etc. as I haven't managed to convince the family of the need for the diff locks that I want.
The ARB is a relatively small compressor and some say you can't reseat the beed on tyres with it but I have done it more than once. I made up my own hose to pump up tyres even though the ARB came with the inflation kit at no extra cost.(may have been a special offer). I use
mine because it is longer and larger diameter and will easily reach the trailer. Also the female fitting on the end of the hose is a shut off which allows me to keep the hose connected 24/7 adding to the size of the receiver
tank. I have a short length of hose with the clip for tyre inflation on the end. By disconnecting this short hose while going from tyre to tyre I find that it saves a lot of time over compressors that don't have the receiver, it takes
mine about 3 min to go from 22 psi to 32psi (LT265/75 16) Also a fully presurised hose and receiver is a good size reserve of air and gives the initial hit needed to re-
seat the beed.
I think, you may find that ARB want to sell you the compressor with the air lock anyway.
130999
Reply By: Member - Bradley- Tuesday, Sep 20, 2005 at 19:24
I was in ARB the other weekend and saw that they are now selling a small chinese made compressor for use with lockers only - no tyres.
But asked and was told that they are still making the aussie built tyre / locker compressors as
??? Hope they keep making the good units here.
131055
Follow Up By: geocacher (djcache) - Wednesday, Sep 21, 2005 at 02:20
Wonder if it's got something to do with the competitions move into the Air Locker market. Maybe to gain a slight edge on price?
Screw China, I'll have the original thanks.
385484
Follow Up By: Member - Bradley- Wednesday, Sep 21, 2005 at 17:16
yeah, it could be to offer a cheaper alternative, or it could be the old story - the ones they make last too long and they dont sell enough new ones, so they are going for a margin grab/ turnover increase.
I might have to investigate this further ;-)
damn straight - screw china
385572
