Low wattage jug/kettle
Submitted: Tuesday, Sep 20, 2005 at 10:49
ThreadID: 26616 Views:9880 Replies:8 FollowUps:7
Have recently purchased a Kipor generator to charge my batteries if I have prolonged overcast skies. Any ideas were I can get a kettle that is under 1000watts as the gen set is only 1kVa max.
Reply By: Vince NSW - Tuesday, Sep 20, 2005 at 10:58
If the Kipor has a 12v out let, can u use a 12volt kettle. We have one we use as we are driving. Turn on 10 min before morning tea stop and boiling water when you get there. Hate to think what it would drag out of the battery if the motor was off.
AnswerID: 130984
Follow Up By: Austravel - Tuesday, Sep 20, 2005 at 12:12
Thanks, thought of that but not sure what size the 12v units are. Want to boil up water for a shower when charging the batteries.
FollowupID: 385368
Reply By: Tony Shaw - Tuesday, Sep 20, 2005 at 11:27
Have you tried some of the shops like the Warehouse or Crazy Clarks. They normally sell the cheap kettles and they are cheap because they are only the low wattage ones.
Cheers, ToNy!
20/9/05 11:29:28
AnswerID: 130988
Follow Up By: Austravel - Tuesday, Sep 20, 2005 at 12:13
Thanks will check them out.
FollowupID: 385369
Reply By: OLDMAGPIE - Tuesday, Sep 20, 2005 at 13:06
those small 12v kettles are the slowest way to boil water ever. while SHMBO was using one i built a fire put the billy on ,poured out a cuppa,got the paper out & was reading how the West Coast Eagles are going to win the grand final on sat,while she was still waiting for the bloody thing to get HOT!
CHEERS
AnswerID: 131006
Reply By: joc45 - Tuesday, Sep 20, 2005 at 13:37
I bought a plastic Kambrook jug some years ago, which is about 800w. Bought it for the same reasons as you. Not sure if they still make this version. Just scout around the appliance stores, and check the rating of each. Bound to find something.
Gerry
AnswerID: 131008
Follow Up By: Austravel - Tuesday, Sep 20, 2005 at 16:18
FollowupID: 385394
Reply By: Mike DiD - Tuesday, Sep 20, 2005 at 14:10
Not much point running a 1kVA Generator if the Engine is running - my Pajero Diesel has a 1.5KVA Alternator (125 Amps at 12 volts)
AnswerID: 131011
Reply By: signman - Tuesday, Sep 20, 2005 at 16:11
Where do you fit the dishwasher and the TV??
AnswerID: 131022
Reply By: Member - Phil G (SA) - Tuesday, Sep 20, 2005 at 17:49
I'd be guessing that the 240volt jug will end up on the junk heap.
If you want a simple device for heating water in the bush, consider a "Volcano" type jug. They are one of those stainless steel things which are a cylinder on the outside and cone shaped on the inside. You put some paper and twigs in them, light it and they heat up the water in about 10 minutes. Very simple and good. Used to get them at Australian Geographic shops, but there are copies available at the good camping shops now.
Or else, you can use a thermos like we do.
AnswerID: 131033
Follow Up By: porl - Tuesday, Sep 20, 2005 at 20:33
If you want u can buy mine. Great device but after too many beers i boiled some water for coffee and a few minutes later stood barefoot on the remnants of the fire, ouch. It clearly should reside with someone more responsible than I. Used once with original packing.
FollowupID: 385431
Follow Up By: Member - Phil G (SA) - Wednesday, Sep 21, 2005 at 21:18
Hi Porl,
Sorry to hear about your "walking on coals" trick :-(
I've been away with some other people who love the thing. We'll stop for morning tea, and they'll have the thing going in no time.
I'm a bit lazy - thermos does us fine.
FollowupID: 385620
Reply By: Jimbo - Tuesday, Sep 20, 2005 at 21:00
Try this at home with your normal kettle.
I believe that resistance electric products, such as kettles, heaters, hair dryers etc, will be rated at 2000 watts but will accept less. That is to say they will use whatever power is available to power them, although not running at full output.
So whack your household kettle into your 1000 watt generator and see if it works. It probably will, but will take longer to boil than at home out of a household 240 volt point.
I bought a Bunnings $99 650 watt generator for my nephew and he swears by its ability to run a heater and his girlfriend's hairdryer. It is surely not producing enough power to run them at full chat, but it does run them.
Jim.
AnswerID: 131072
Follow Up By: Willb - Tuesday, Sep 20, 2005 at 22:43
Bloody hell Jimbo, I'll have to make sure the wife doesn't see your post.
Just the ammo she would need to make me buy a genny so the hair dryer would go on the trips. Then again maybe I could use that excuse to buy a geny.
Thinking cap on time.
Will
FollowupID: 385453
Follow Up By: Austravel - Thursday, Sep 22, 2005 at 09:46
Thanks Jimbo.
FollowupID: 385683
