Oil Question
Submitted: Tuesday, Sep 20, 2005 at 13:11
ThreadID: 26617 Views:2326 Replies:6 FollowUps:6
Is there really any difference between standard petrol engine oil and oil formulated for LPG engines?
Reply By: TASPAJ - Tuesday, Sep 20, 2005 at 15:51
I know the Mobil branded Super LPG 10w 40 is just Syn S 10w 40 in a diffrent bottle. it's just a marketing thing.
AnswerID: 131021
Follow Up By: F4Phantom - Tuesday, Sep 20, 2005 at 16:13
if you know about other oils such as diesel and petrol, it's damn annoying when you go to buy oil especially for your engine, the front of the package says ""diesel oil" or whatever so you read the back and at the bottom it always says "can also be used in petrol engines, small large, turbo, non turbo, lpg" the lot, its a blanket statment covering every car. I would preferr one oil for one engine type.
FollowupID: 385393
Follow Up By: TASPAJ - Tuesday, Sep 20, 2005 at 16:34
Most engine oils are made for either petrol or diesel. but you can use diesel oils in petrol and vice versa, but only in some cars and 4 x 4s. It's mainly for farmers and others who don't want 14 diffrent engine oils sitting around, they can use the one oil for all engines. But you have to be careful these days because some new diesels now require fully synthetic petrol engine oil when others still use diesel oils. best thing to do is check with oil companies or the dealer whats the best to use for you own car.
hope this helps a bit.
FollowupID: 385396
Follow Up By: F4Phantom - Tuesday, Sep 20, 2005 at 16:38
thanks, probably best to check with manufacturer as the guy selling it at autobahn or wherever always reccommends the oil you are holding at the time!
FollowupID: 385398
Follow Up By: warthog - Tuesday, Sep 20, 2005 at 22:17
The major oil companies have technical advice phone numbers. The staff on these numbers are knowledgeable and unless you are a chemical engineer should be able to answer most questions you fire at them. I have used both the BP and the Caltex advice lines and found them to be helpful.
FollowupID: 385445
Reply By: bushy04 - Tuesday, Sep 20, 2005 at 16:11
I used to work in an engine reco shop, and was told that LPG oil had some form of upper cylender lube in it .
Lpg is hotter and dryer than petrol so it needs an extra lube capacity?
Whether this is true or not I dont really know so dont quote me on it.
AnswerID: 131023
Follow Up By: TASPAJ - Tuesday, Sep 20, 2005 at 16:35
Your right Lpg is hotter but i don't think the oil comanies worry about making a diffrent blend just for LPG.
FollowupID: 385397
Reply By: cmilton54 - Tuesday, Sep 20, 2005 at 18:35
Not sure of brand! think it is penright or valvoline use it in our LPF forklift.
(Shed shut at moment)
Charlie
AnswerID: 131046
Reply By: Brew69(SA) - Tuesday, Sep 20, 2005 at 18:55
I use Shell LPG oil. At $25 for 5 litres i would be interested in knowing if i am wasting money?
AnswerID: 131053
Follow Up By: Member - toohey - Tuesday, Sep 20, 2005 at 19:51
i think the lpg oil would have a aditive to protec the valve seats,in the 69 bony i use flash lube with unleaded petrol.
cheers toohey.
FollowupID: 385427
Reply By: Brett_B - Tuesday, Sep 20, 2005 at 21:32
Just a thought but how about you download the material data sheet from the manufacture, that should or could show the differences if any ?
I haven't looked but usually these are sheets are avalible.
AnswerID: 131077
Reply By: Steve - Tuesday, Sep 20, 2005 at 21:53
how about checking the oil makers web sites ...
AnswerID: 131079
