Rear suspension for 62 series Cruiser.
Submitted: Tuesday, Sep 20, 2005 at 21:19
62Cruza
Hi All,
I am soon to be in the market for upgrading the
suspension in the back of my 62 Series Petrol Cruiser. It permanatly has a set of drawers in the back, and will also be carring a spare wheel/jerry can holder off the back of the vehicle. The current springs in it are pretty sagged and original equipment.
I have had a number of people telling me to simply whack in an extra leaf and get them retensioned? however I am wondering if I would be better off just putting in a new set of springs. Can anyone give me an idea in the diffrence in cost between the two. I have been looking at the rockcrawler leaf springs, which retail for about $200 each plus fitting, and provide an inch or two of extra lift, which could also mean replacing shocks, so this is another factor to take into account.
Any suggestions/advice would be greatly appreciated.
62Cruza
Reply By: Member - Davoe (Widgiemooltha) - Tuesday, Sep 20, 2005 at 22:29
With no personall experience I have heard that reset springs are a distant second best to new and dont retain their spring anywhere near as long. I would imagine the rockcrawler springs as per their name would be built for rear articulation hence may not have the load carrying capacity you are after
131089
Reply By: Tim HJ61 (WA) - Tuesday, Sep 20, 2005 at 22:58
I loaded up my HJ61 the day before my first big trip and found I had about 10mm to the bump stops - not the best scenario.
With no time to look around or consider option, Pedders fitted a set of heavy duty standard height springs all round. This meant I kept my shocks, and also kept my 7mm of clearance between the high roof cruiser and my garage door - I couldn't risk any increase in overall vehicle height.
New springs performed brilliantly carrying heavy load over 3000k dirt road. Bit bouncy now it's empty and I could probably do with carrying a set of drawers like yours to smoothe things out a bit - or a coupla bags cement!
If you can get a set of good quality heavy duty springs for $400, sounds like a good way to go to me. Pedders reminded me of the forces on cold spring steel on a desert morning with a heavily loaded vehicle- as soon as you move you are pounding them whilst still cold, frozen in fact. You can't warm up springs like you can engine oils. The risk of snapping old springs is great in these situations.
Tim
131100
Follow Up By: Member - Davoe (Widgiemooltha) - Tuesday, Sep 20, 2005 at 23:35
snapped leaves are common in mining vehicles far less so in private vehicles but should still be part of any prestart check
385468
Reply By: mfewster - Wednesday, Sep 21, 2005 at 05:49
Its also worthwhile having a look at Aussie Super springs. I got them from TJM for my 60 series and it has transformed the heavy load handling,. Difficult to explain how they work and I can't post photos, so have a look at them at TJM.s A sliding spring is fitted above the shackles and tensions in the opposite direction controlling the rear spring movement. Has added a bit of height, while keeping cornering much flatter.
131126
Reply By: banjodog - Wednesday, Sep 21, 2005 at 06:00
Reply By: Member - Phil G (SA) - Wednesday, Sep 21, 2005 at 08:56
I'd go the new springs all round too, but having the old springs reset and an extra leaf added is a good option if its done by a good company.
Industrial springs in
Adelaide have been doing this since the year dot. My father in law had them do this to the saggy springs on a 1980 HJ60 and today, 20 years after the reset,
the springs have not sagged a bit.
131148
Follow Up By: Member - Davoe (Widgiemooltha) - Wednesday, Sep 21, 2005 at 19:50
Went past them when I was back in
adelaide and they are still going. Years ago i approached them about heavier torsion bars for a valiant - but they couldnt help me
385595
