Metal in Gearbox
Submitted: Saturday, Dec 21, 2002 at 01:00
Paul
All,
Also the mechanic reported alot of metal on the drain plug magnet on the gearbox of our 2000 Patrol.
Would this be something to expect on a car thats done 80000k's
Paul
Reply By: OziExplorer - Saturday, Dec 21, 2002 at 01:00
Paul, what is "a lot of metal"?
No, you would not expect much metal at 80,000k's if any, how ever, it depends on how the vehicle is being driven. Is somebody else driving this vehicle other than you that is thrashing it?
Are you must definitely using the correct oil? Have you had it serviced somewhere where they use un-branded/recycled oil? There is nothing wrong with recycled oil, the trouble is never found anybody that does it properly/professionally in Australia. In overseas countries it is recycled by the majors and right up to spec - better than new.
10031
Follow Up By: Paul - Saturday, Dec 21, 2002 at 01:00
Lot of metal........its what the mechanic wrote on the report and what he told the wife to tell me when she picked it up.
I am yet to speak to him about it. But I just wanted to ask the question to others and get some general feed back on what you feel if you had been told the same things with your cars.
The gearbox feels fine.....just a little loose to me and occassionally have trouble getting it into 1st or reverse.
5243
Reply By: Phil G - Saturday, Dec 21, 2002 at 01:00
Depends on when the oil was last changed and the magnet cleaned. I have always found a fair lump of filings on magnets and I change gear oil every 20-40,000. If your gearbox is fine, then don't worry about it.
Phil G
10033
Reply By: Axel - Saturday, Dec 21, 2002 at 01:00
Paul, is this the 2000 dx patrol ex police ??
10037
sure is.......why?
5242
Reply By: Allyn - Saturday, Dec 21, 2002 at 01:00
Not being smart here but if no filings were ever going to be evident then they wouldn't bother fitting a magnetic drain plug really I would think. I have always found a small amount of filings in diff but can't say as I can recall gearbox.
I'll take this opportunity to wish everyone a Merry Xmas also.
Have enjoyed your company
10048
Paul, the old adage of buyer beware, as you asked in previous posts about buying a ex police vehicle i thought you may soon find out the pros and cons of doing so,, would sugest getting g/box stripped ,,sounds like some abnormal wear for milage,if hard 1st and rev,,
10055
Reply By: Eric - Saturday, Dec 21, 2002 at 01:00
Paul.
The fuel filter and the gear box magnet are doing there job and all is normal, The fuel can suport life if it has warmth and light. the filter has protected the motor and all will be fine, the starting problem will not be related to the filter as the first indication of a blocked filter is loss of power on hills. The gear box plug has colected the metal that is wearing of the spline in 5th gear, don't fix it until you find the niose in 5th is loud enough to bother you. If you reduce the amount of 5th gear use it may last untill trade in time. Eric.
10058
Reply By: Bob Y. - Sunday, Dec 22, 2002 at 01:00
Paul, Wouldn't be too worried about "lot of metal", as long as it didn't contain pieces ie. 1-2 mm in diameter. If they are on the magnet, at least the pieces aren't floating about in the 'box. Change the oil more regularly for a while to keep a handle on it. Toyota's have a large nut on rear of g'box main shaft, inside t'case, that loosens enough to cause major wear on spline of shaft and gear in t'case. In extreme cases the gear will strip the spline off shaft, amounting to extreme case of NO GO. This will cause large amounts of metal sludge on magnet. Haven't heard of Nissan's with same problem.
Driving in 5th gear below 80 kmh is a no-no, as it puts more strain on that gear.
At 80K kms, anything is possible, the vehicle may have done a fair bit in town, with lots of g'box use? Had a 79 series g'box overhauled after only 58K kms, from that experience(syncro on 3rd only, no speedo & grinding noises) feel you will know if your g'box gets any worse.
Don't let it spoil your Christmas. Catch you later.....Merry Christmas.
10084
