sat navs????help
Submitted: Friday, Sep 23, 2005 at 20:32
babs
Hi all, I'm thinking of getting a sat nav but not sure on portable or fixed in 4x4..
These new palm pilots look great and have the advantage of computer options on them, but most important how good are the maps on these things???
They come already loaded or load yourself from your computer with a map of all of Australia, how detailed are they ?
Will they show me minor 4x4
trails or major 4x4
trails, small country towns, I'm not interested in the main towns and roads, I can read the street signs for that and save myself around 1500k..
If any one has already experienced from these things, made the mistakes of getting wrong set ups, or are happy with there set up please can I hear your opinions..
Hopefully it will shed some light and help me make the right choice...
Babs.
Reply By: Sand Man (SA) - Friday, Sep 23, 2005 at 20:55
Babs,
Any device is only as good as the informations supplied to it.
Having said that, any GPS will provide a reasonably accurate location and has the ability to maintain a track.
So what you need to determine is for what uses you require a "sat nav" and how you will run it.
One way is to download maps to the GPS unit and in this way you have a self contained and portable unit you can use both in and away from a vehicle.
The downside of these is the relatively small display screen which may present problems if you are using it for navigating whilst driving.
Another way is to connect the GPS to a laptop computer running something like OziExplorer. This is very good with the digital maps available which must be loaded separately to the PC. The downside of this solution is the "bulkiness" of the Laptop, however some people connect a smaller "touchscreen" and shove the laptop under the
seat, etc.
Still another way is to purchase a PDA unit with a GPS card inserted into its card slot and which also has the ability to run OziExplorer, etc.
I haven't had personal experience with these, but people who have say they get the best compromise. A screen with a reasonable sized display and portability when you wish to use it away from the vehicle.
There are several solutions to choose from, you just need to research each option and choose the one that best suits your needs and budget.
131577
Reply By: Willem - Friday, Sep 23, 2005 at 22:35
I had always used paper maps
The time came along however to spend some money on toys to keep up with everyone...lol
Through this
forum I sourced all the info I needed.
My setup, now three years old, is a Magellan Map330 GPS, hardwired to the aux truck battery. I run Oziexplorer software on a Notebook which I power by means of a Kerio DC charger through the cig lighter socket. I utilise Hema Great Desert Tracks maps and Natmap Raster Mosaic 1:250,000
I only use my Notebook if I am travelling through a remote area as normal road maps are good enough for the mundane things.
I have tried all ways to fit the Notebook inside the cabin but my vehicle is not conducive to easy storage. Friends have tried to make me a laptop carrier and I have made some wonderful unworkable units. These days I pull the Notebook out when I need it and rest it on the console next to me and look at it ocassionally if I am bushtracking somewhere..
A friend has a PDA setup but as much as I would like one I find them too small to read.
There are lots of more modern and convenient setups so hopefully you will get lots of advice here.
Good luck!
131598
Follow Up By: Blaze - Saturday, Sep 24, 2005 at 01:22
I believe you nearly have the best setup Willem, Most
places you only need the GPS alone and its only of the beaten that Oziexplorer stands alone, the only thing I would add is a seperate screen so the notebook can stay closed under your
seat or somewhere and you can view the aux screen mounted on the dash, console or where-ever. A few of us in and around the Riverland S.A. use this with no problems at all, and lets face it if your lost you should stop and have a close look maybe at the laptop screen which is in a larger format.
385967
Reply By: Member - Alan H (QLD) - Saturday, Sep 24, 2005 at 08:25
I always carry paper maps of course as backups
I have a PDA running Oziexplorer and not running but available is a laptop.
I find the PDA while small is great to just keep track of where you are or when turnoffs are coming up which is helpful when towing on narrow tracks and missing turnoffs is a problem.
The PDA is solid state (no moving parts) compared to a running laptop which could suffer hard drive damage from bumps while spinning.
I use the PDA mostly and if I am in real trouble I pull up and start the laptop and have a large map to get my way out of the problem.
The PDA is positioned very close to me on the dash stuck onto the windscreen.
PDA is a HP 4700 mounted in a Arkon mount which has GPS incorporated into it so only one power wire to the cigarette lighter is required and the whole gadget can be quickly unstuck from the windscreen and removed for security or swapped to any other vehicle with a cirgarette lighter socket.
131612
Reply By: ThePunter - Saturday, Sep 24, 2005 at 13:54
I use a Mitac Mio 168 and I am happy with it. Mio 168t
I use it with CoPilot around
Melbourne but for the bush I use OziExplorer CE which also runs on the 168.
Refer also to Post 26568 for more information on this subject.
131630
Reply By: Mike DiD - Sunday, Sep 25, 2005 at 09:15
If you want digital topographic maps at a reasonable price forget any GPS - get a PDA running OziExplorer CE.
The 25,000 and 50,000 Top maps of NSW are now FREE in Ozi format. These are much better quality than the previous version that were scans off the paper maps.
131690
Follow Up By: babs - Sunday, Sep 25, 2005 at 19:32
Hry Mike do you know what tipe of reception the pda has, I have been told an in car set up is stronger signals....
And the Oziexplore ce is that for NSW only or Australia wide?
Thanks,
Babs.
386083
Follow Up By: Mike DiD - Sunday, Sep 25, 2005 at 21:25
PDA reception depends totally on the type of GPS Aerial you use - most of them will take an external aerial.
OziExplorer CE has no maps - there is a huge amount of mapping available to it. If you have a PDF map you can convert it, if you have a paper map you can scan it.
386109
Reply By: rolande- Monday, Sep 26, 2005 at 17:52
G'day,
Some people are now running pc's in their vehicles with a touch screen mounted into the console, that way you can run any mapping you like
Rolande
131864
