De gaussing, and stuff of science.
Submitted: Saturday, Sep 24, 2005 at 19:33
ThreadID: 26728 Views:2793 Replies:13 FollowUps:10
When you place one of those small round liquid filled gimbal type compasses on your dashboard of your car, or boat, you have to take into consideration all of the steel content surrounding it.
Some compasses that are sold for cars, don't seem to be overly bothered by the mass of metal surrounding them, yet when I approach my Honda with the kayak compass, it goes haywire, why is this so?
Which brings me to the second part of the question...
Say, in the late 60's, and early 70's, before satellite communication became the norm, how did the BIG container ships manage to reset their compasses, after they had left port with a heap of cars, or containers on board?
And now, the third part of the question...
Do you think that a compass would work whilst orbiting the earth in the Space Shuttle? Not to navigate with, but do you think it would always point to magnetic north, from space? I know they operate from aircraft, but space is a long way off, and I'm wondering as to whether you would simply start to pick up the eddies which surround the earth, instead.
And finally, the fourth part...
Do compasses work in REALLY deep mines? I know you can navigate caves, and underground river systems, but what about the really deep mines?
So, you've got your work cut out for you, those that have elected to stay at home, to try and find the answers, so when the regulars get back on Sunday night, we can show them we've been busy.
Wolfie
Reply By: Member - JohnR (Vic)&Moses - Saturday, Sep 24, 2005 at 19:41
Wolfie, have a look at gyrocompasses here for the shipping question for the up to date answer. You obeviously need another room in your Kayak for a bigger compass.
AnswerID: 131652
Follow Up By: Lone Wolf - Saturday, Sep 24, 2005 at 19:52
Whoa!!!
How cool is that?
I had no idea that precession was sensitive enough to record the Earth's rotation.
Wicked!!!
Wolfie
FollowupID: 386014
Follow Up By: Member - 'Lucy' - Saturday, Sep 24, 2005 at 21:22
Thank you very much.
You pair of idiots, whackers, boredom creatures have now ruined my evening in that I have no idea whether its a 'precision', 'couple' , dopler, shoomopler. (ROFLMAO)
Seriously, just get a GPS with a big compass in it (Garmin 3006C etc) and forget about trying to get a magnetic compass to work anywhere near/in a vehicle.
I spent a lot of time, effort and dolars - all to no avail.
FollowupID: 386024
Follow Up By: Michael Carey - Saturday, Sep 24, 2005 at 22:45
I get the opportunity to work on gyrocompasses and such things at work quite a bit. They are truly amazing machines. The one I like the best is the fully floating one, there are several brands that use the same technology.
Basically, it has a rotor in a sealed, evacuated sphere which has a conical dimple in the top and a round contact surface on the bottom. It sits in another sphere filled with conductive fluid. The inner sphere is bouyant in this fluid and pushes up against an insulated pin that sits inside the conical dimple. There is a small amount of mercury in the bottom of the dimple to help conduct electricity between the pin and the bottom of the dimple. On top of the mercury is a small amount of a flurocarbon insualting liquid that stops the conductive fluid from being in contact with the mercury. At the bottom of the outer sphere is another contact that completes the circuit to the bottom of the inner sphere using the conductive fluid as the "wire" thus completing the circuit.
There are sensors that monitor the position of the inner sphere in relation to the outer sphere. The gyro rotor inside the inner sphere provides the north-seeking action and the outer sphere follows the inner sphere using the sensors and motors rotate the outer sphere to follow the inner one.
It's hard to explain, but amazing to see in action.
Other gyros are suspended on titanium wires that are finely balanced. I have one on the workbench at the moment, I'll take some photos and post them.
A newcomer to the "gyro" family is the GPS gyrocompass. Not a true gyrocompass, it uses multiple GPS antennas and receivers to work out a heading. If antenna 'a' is here and antenna 'b' is there and antenna 'c' is over there....then we must be facing in this direction!! No moving parts to wear out, and it's surprisingly accurate...
There are also fluxgate compasses that use the earths magnetic field to determine heading, (these are starting to be found in GPS navigators as well), these can also be combined with rate sensors that can sense movement. If the magnetic sensor shows a heading change, BUT the rate sensor doesn't detect movement then it can correct the magenetic error before it gets sent to a display device.
Enough ramble from me for now I think....
FollowupID: 386026
Follow Up By: Member - JohnR (Vic)&Moses - Saturday, Sep 24, 2005 at 23:08
Wolfie, one of the simplest gyros you may have seen was probably at an early age. I had a gyro top I can remember at the age of 10 or so, yes getting on for 40+++ years ago. A childs top is working on the same gyroscopic principle and just as well for the child not in a vacuum. You have also found out Wolfie how hard it is to move a large angle grinder round while it is going.
Michael, it never ceases to amaze me the people that respond on EO. Thanks for that contribution.
Hey Lucy, sorry to destroy your evening. My GPS works still too mate, but it doesn't stop me dreaming of the next one. When are you and Mrs Lucy ready to visit?
FollowupID: 386028
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Sep 26, 2005 at 22:31
Wolfie, I think you better go to that magnetic hill North of Willie and see which way your Delica goes. With or without a compass.
FollowupID: 386251
Reply By: Shaker - Saturday, Sep 24, 2005 at 19:53
Compasses do work in steel vessels, although they need 'correctors' aptly named "Flinders Balls" which are positioned either side of the compass & adjusted to compensate for the surrounding steelwork.
With a normal compass you have either a Northern or Southern hemisphere model as one does not do both, as discovered by people buying them of ebay ... lmao!
I believe that they would work in mines, but not in space.
AnswerID: 131653
Follow Up By: theshadows - Sunday, Sep 25, 2005 at 10:03
in the old days you had to "swing" correct the compass evey 6 months.
shadow
FollowupID: 386049
Reply By: Willem - Saturday, Sep 24, 2005 at 19:54
Why is it so...Pity ole Julius Sumner-Miller isn't around any longer....but there must be lots of luminaries around.....lol
1. Dunno....... Most cars are built of plastic these days. Maybe it is picking up forces from the engine compartment.
2. JohnR answered the question
3. I would guess that once you left Earth's gravitational pull the compass would be of little use to you
Mostly guesses so early on a Sat eve.........
AnswerID: 131654
Reply By: Kiwi Kia - Saturday, Sep 24, 2005 at 20:22
So many words, so little time..... Ships used to carry out an exercise known as 'boxing the compass'. Sightings were made on known points and and a chart of the errors made. With any errors plotted, large chunks of iron (usually in the shape of a ball) located on bars each side of the compass box were moved closer or further away from the compass to counteract the effects of the mass of iron in the ship. On an old aircraft type compass, small screws were adjusted on the side of the caseing. Then along came the fluxgate compass and the RMI (remote magnetic indicator) A very sensitive compass was situated at some place on the vehicle / plane / ship well away from engines, electrical generators, radios etc. and the position of the compass pointer was relayed electronically to a read out at the navigating position. Most Japanese vehicles that have a built in compass use a fluxgate compass.
A compass needle simply points along the direction of the earths magnetic field at that point on the earth. As the magnetic lines of force travel around the globe and dive into the earth at the poles then as you aproach the magnetic pole the needle will tend to point downwards (the z component). This 'dip' effect and the unbalanced compass needle makes a magnetic compass rather useless as you approach the magnetic poles.
To counteract the downward deflection of the compass needle a small weight is added to one end of the compass needle. This weight adds a small mass to the needle which has inertia so when accelerating or deaccelerating the inertia turns the compass needle even though you are not turning. Try facing east or west and move a compass forward or back and watch the needle move even though you are pointing straight ahead and not turning.
Will a compass work in a mine? Depends how much shielding of the earths magnetic field there is arround the compass, same as being in a wooden box or a metal box.
How much more do you want (trying to keep it simple) ? Space gets a bit technical - short answer is no it will not work unless you are in synchronous orbit, stationary in relation to a spot on the earths surface, and then the compass needle should align it self with earths magnetic field.
AnswerID: 131659
Reply By: techie - Saturday, Sep 24, 2005 at 20:31
Part the three:
The earth's magnetic field does venture into space but diminishes with the square of the distance.
If a compass is sensitive enough it will continue to work.
The earth's magnetic field in space is indicated by the aurora lights.
Part the fourth:
Really deep mines - of course! The magnetic field is not stopped by earth. metal bearing earth will concentrate the lines of force but will not stop it.
AnswerID: 131661
Reply By: Mad Dog (Australia) - Saturday, Sep 24, 2005 at 20:44
wOLFIE, a DECENT CAr compass will have adjusting screws so you can compensate for the affects of surounding metal. If it doesn't then it's not a car compass irrespective of what the manufacturer calls it.
AnswerID: 131662
Follow Up By: Mad Dog (Australia) - Saturday, Sep 24, 2005 at 20:52
And how does one correctly align a compass ?
Use your GPS :)
FollowupID: 386021
Follow Up By: Nudenut - Sunday, Sep 25, 2005 at 10:58
so why have a compass?...to make sure the gps is correct?
FollowupID: 386055
Reply By: Eric Experience. - Saturday, Sep 24, 2005 at 22:19
Wolfie.
A compass has a small magnet attached to the needle, if the pivots are good quality that small magnet can be very weak, conversely if the pivots are crap the magnet has to be stronger, a strong magnet is more inclined to lock onto any bit of steel.
Eric.
AnswerID: 131669
Reply By: Footloose - Saturday, Sep 24, 2005 at 23:36
And in the ruuly early days, people used to get stuffed because they had their small ships compass sitting next to the radio speaker.
AnswerID: 131678
Reply By: Mike DiD - Sunday, Sep 25, 2005 at 08:55
The Fluxgate compass sensor in the Pajero is located on top of teh dash in the centre - well inside the steel shell.
It is useless without calibration - just drive in a circle twice.
AnswerID: 131688
Reply By: Nudenut - Sunday, Sep 25, 2005 at 11:02
wolfie, its bloodyamazing that inquistive mind of yours...do you stay awake all night thinking what makes things tick?
AnswerID: 131702
Follow Up By: Lone Wolf - Sunday, Sep 25, 2005 at 12:51
Some people would accuse me of not having enough toys when I was a kid!
I really get a buzz seeing how stuff works, always have.
Thank you all who contributed, I can sleep safely now, in the knowledge that I won't get lost... much...
Wolfie
FollowupID: 386060
Follow Up By: Nudenut - Sunday, Sep 25, 2005 at 13:16
mmm a GPS with ozie explorer and note book eh?
FollowupID: 386063
Reply By: Alan Southport QLD - Sunday, Sep 25, 2005 at 18:25
Guys,
I think you should give Michael Carey's post another read.
Dont know what he does for work, but, i'd love to work in 'that' field.
If you were at the the center of the earth, you would be weightless, free to move around but a little uncomfortable (Squashed and Cooking), so where would be your North and South then?
Answer: Nowhere.
To MC, does the Sun have polarity? If so, then do other 'Stars' have polarity? If so, then does that mean the Solar system has a universal sort of Norths and Souths?
If so, does that mean that there is after all a UP and DOWN to the whole universe?
Holy crap!, sorry i got carried away there, this a 4x4 forum....
Love forums....
Alan.
AnswerID: 131722
Reply By: Graham- Monday, Sep 26, 2005 at 19:22
I showed this post to my father-in-law and, well, he has a b it of a background in this area and thought you guys might be interested in his repsonse.
Graham
Answer.
First part
The subject is a complex one and in terms of marine magnetism (Ships Compass) involves some 10 weeks of lessons for people completing the Master 1 Certificate. Total course 11 months at TAFE Sydney, NSW
We can equate a compass in a car to that placed in a vessel
The compass is placed in the middle on the fore and aft line of the vehicle.
This ensures that the permanent magnetism (hard steel) used in the construction gives the compass a permanent error equal 9all most) on either side but of an opposite pull.
The soft iron has a variable value as the car/vessel moves to various latitudes; this is strongest at the magnetic equator and lowest towards the magnetic poles. (Dip). This means that there is a variable error as the car moves being the combination of the permanent and variable errors.
We know the positions of the earth’s magnetic poles, checked daily by US and Britain,
From these positions we can draw the lines of direction of the earths magnetic fields, known as lines of variation. Named east or west of true north.
On vessels we can determine the deviation of the compass caused by the soft iron of the vessel (one way) by taking bearings of celestial bodies and comparing to the known true bearing. This error is called deviation.
The car/vessel is seen as a total magnet and there will be a certain field on one side (red say) and therefore (say blue) on the other, these will cancel each other out. (think about it). So there will, usually a low value error in the compass when placed in the middle (fore and aft). If the compass was place on one side or at the extremity there will be a large value error. A magnetic compass on one side as in an aircraft carrier (bridge on one side usually starboard) will have a large value error on two opposite quadrants.
If you approach a car with a magnetic compass, you are approaching a magnetic, and therefore you will great changes of magnetic influence. Go to one end on the centre line and see what is the fore and aft direction.Then go to the other, your will see a different direction shown. Similarly check along the sides.
Second part.
Prior to or on departure, the ships magnetic standard compass, (there are two compasses placed on a vessel for navigation, the standard which the accurate one and the steering which is for steering only), is checked by taking a bearing and comparing that bearing to a true bearing or compare the magnetic heading to the gyro heading, the error of which is known.
There is usually little error from container position allocation or their contents. Vessels loading steel, particularly steel beams loaded for and aft and or across the vessel can caused dramatic errors.
Remember a ship’s magnetic compass (standard) is checked at least once a watch or when there is a major change of course during the watch. All of which are recorded in an official document.
Third part.
Satellites orbiting the earth are subject to earth’s magnetic field, but there are complex arrangements of gyrocompasses fitted to give accurate direction indications. The moon is a magnet and therefore when satellites approach they will induce its field on a compass should they have one.
Fourth part.
Compasses do work in mines but are subject to induced magnetic influences cause by the nature of the surrounding material eg hard rock soft rock, minerals etc. For those people lucky to have been near the Flinders Ranges in South Australia and walking with a magnetic compass, as one might do, will see great variations of direction. These ranges record the various changes of the earths polarity, remember about each 9 million years the polarity of the earth changes, north becomes south. In terms of these change we are again close to such a change.
The south magnetic pole (near South Africa) has been recording noticeable changes in recent years.
I suggest that you obtain a book on ships magnetic compasses from your library; they may have to order it in.
Happy attractions and repulsions! Mick Costelloe. (Mariner) (Licenced Compass Adjuster)
AnswerID: 131881
Reply By: Kiwi Kia - Tuesday, Sep 27, 2005 at 07:54
And not a word about presession ! :-))
AnswerID: 131942
