Help with a Codan 7727
Submitted: Saturday, Sep 24, 2005 at 22:01
Raster_Man
Hi, I'm new to this
HF radio thing after purchaching a 7727 with the following frequiencies 5300,5360,5455,8022 I was wondering what sort of aerial is required for mobile operation and a base station, also if anyone has a copy of the user gide/manual that I could copy or if it is available in pdf format somewher on the internet oyu help would be very much apprecaited as I live a fair way from any city it is hard to pop down to a
shop and get any help. Thanks in advance
Reply By: Member - Paul P (Bris) - Saturday, Sep 24, 2005 at 22:33
G'day
Try this group Codan Outback Radio
Paul
131670
Reply By: Tim HJ61 (WA) - Saturday, Sep 24, 2005 at 22:57
Hi Raster Man,
I was in the same position as you around a year ago, except my HF is an 8727 - both yours and
mine are old units, but
mine worked fine when I needed it and it was a great companion whilst travelling. Many people use these units. Many other people pay a lot more and are probably very happy with their setup too.
You must visit - and are advised to join - the VKS 737 network which will guide you on everything you need.
Using these machines turns out to be pretty easy once they are set up.
Turn it on.
Select the frequency you want. Make sure your aerial is also set to the same frequency - unless you have a fancy big fat thing called an autotune.
Listen to make sure no one else is talking.
Hold down the transit button on the mike and speak loudly and clearly directly into the mike.
You've got the two most common frequencies used on VKS, (5455, 8022) so don't need to open the box to change anything.
Like the previous post said, go to the Codan Group and ask whatever you want. There's an Exploroz member that provides heaps of useful contributions to that group and outed himself recently!!
An amatuer radio group in
Melbourne area FAMPARC make antenna as club fundraisers to suit VKS frequencies and one of theirs served me
well - although I didn't drive with it in place and screwed it onto the base each time I used the radio. This was to suit my own circumstances at the time, and was not any real extra hassle.
Enjoy your learning curve.
Tim
131672
Follow Up By: Footloose - Saturday, Sep 24, 2005 at 23:31
Oh Oh
386031
Reply By: Raster_Man - Saturday, Sep 24, 2005 at 23:20
Thankyou Tim & Paul for taking the time to help me, I checking out the user group as we speak.
131676
Reply By: joc45 - Sunday, Sep 25, 2005 at 10:24
Hi Raster Man,
I can copy the manual if you like; email me on gezza90 at tpg dot com dot au.
You will need a tapped helical whip antenna; basically a tap for each frequency, tho 5300 and 5360 can share the same tap, being close enough in frequency to not matter. Also you'll need a spring base. Both are not cheap.
Firms like Terlin make a generic antenna, made to work most RFDS and VKS737 channels.
Terlin antennas
Gerry
131695
Reply By: Sarg - Tuesday, Sep 27, 2005 at 21:45
5033 (5301.5) VJN RFDS
Cairns VKF RFDS
Wyndham VH6KU PEARLS P/L
5360 (5361.50 VJQ RFDS Kalgoorlie
5455 VJ6MB Woodside Offshore Prtroleum
Karratha
8022 (8023.4) VN5AY Austin Bluefish Tuna Pt Lincoln
132072
