2002 diesel courier overheating
Submitted: Sunday, Sep 25, 2005 at 21:26
hillsy
have a ford courier 2.5 just started overheating when towing ok on the flats but the slightest
hill makes the temp guage rise quickly and right into the red if you back off it cools off just as quickly.can anyone help???hillsy
Reply By: Derek - Sunday, Sep 25, 2005 at 22:54
Hillsy
Just had the same prob with my cruiser (which gets its coolant changed every 2 years) and it ended up being a build up of sludge in the core. The core had to come out so as a proper clean out could be done. No more problems now.
Derek
131763
Follow Up By: hillsy - Tuesday, Sep 27, 2005 at 14:07
have taken in to local dealer they are checking it out now, they said it was probably the viscous fan clutch when i dropped it off , will advise everyone the results soon thanks to all who replied hillsy
cairns.
386320
Reply By: vitara - Monday, Sep 26, 2005 at 08:38
Hi there hillsy, could have been caused by using 2 different types of coolants, what the car come with when it came from japan and what we use here in aussy, mix the 2 together and they coagulate forming a jelly like substance blocking the radiator. We had this problem alot when I worked for toyota. You would think they would use some thing compatible but that would be 2 smart for a car yard. Is it still under warranty? if so get them to fix it, otherwise take to a radiator place and get flushed out, also check that the fan coupling is locking so the fan pulls the cool air through when required eg pulling up hills with a load but I would'nt imagine it to be that with the low klms you have, if not make sure the thermostat is opening right up. Regards Vitara
131787
Follow Up By: Member - Marquis - Monday, Sep 26, 2005 at 11:29
Make sure you flush the complete coolant system if this is the problem.
Radiator, Engine, Cab Heater, etc
Don't muck around, the longer you leave it the worse it gets... (particularly gelling inside the engine)
386149
Follow Up By: hillsy - Wednesday, Sep 28, 2005 at 20:13
dealer has advised the viscous clutch is ok they advise radiator is blocked internally as has been suggested and to get stripped and cleaned i am still struggling with this as car is only 3 yrs old and has been DEALER serviced since new will advise outcome thanks again guys hillsy
386477
Reply By: cokeaddict - Monday, Sep 26, 2005 at 10:51
Apart from the suggestions above, have you done any MUD driving lately ? if so, make sure your radiator isnt 1/4 blocked from the outside with dry mud. The onlyw away to clean that is to remove radiator from vehicle and geta high pressure cleaner to get the mud out. People often forget that after a bit of fun in the mud, we need to clean out our radiators. I std hose wont do it properly, you need pressure to clean it ALL out and having teh radiator out fo the vehicle also stops that washed out mud to run down into your chassis rail and other parts of your car where rust can start.
Ange
131801
Reply By: Ian from Thermoguard Instruments - Monday, Sep 26, 2005 at 11:39
Hi Guys,
I agree with all the previous about checking the radiator inside and out. But while you at it, spare a thought for the intercooler too. On the Ford Courier/Mazda Bravo, the intercooler is front-mounted, very low down below the radiator - and as such it's very vulnerable. If it's externally clogged with mud or bugs or if the fins have just been battered flat by bugs and stones it will not be working at all
And towing is when you need it most. You'll be on full boost and full/near full throttle for long periods. An ineffective intercooler will cause combustion chamber temps (and exhaust gas temp, of course) to rise
well above 'normal'. This not only puts extra load on the cooling system but can have very detrimental effects on piston crowns, valves and turbos in the long-term (or even the short-term, in the case of early Nissan ZD30 engines?! and Jackeroos??). So be sure to have a good look at it too.
Ian
131808
Reply By: MATT.D(WA) - Monday, Sep 26, 2005 at 19:20
Hi Hillsy,
My old man has a 2000 Bravo with the same motor. From brand new when travelling at about 120-125kmh the engine would overheat in summer. When it backed off to about 110-115kmh no probs. Only towing done was at night time occasionally so no dramas. Mazdas reply to it when asked was not to speed. Still to this day it does it but he doesn't tow much so its not a drama. I think the factory radiator in these vehicle is a little on the small side. Not much help but thought you might be interested.
cheers.
131880
Reply By: OLDMAGPIE - Tuesday, Sep 27, 2005 at 00:59
hi hillsy,
i have the exact same vehicle & have absolutely flogged it while towing trailer temp gauge is allways below half level. there is definetely something wrong get it serviced
131931
Reply By: OLDMAGPIE - Wednesday, Sep 28, 2005 at 08:13
hi hillsy,
how did it go? i forgot to mention that i knew a guy with the same symptoms & they found his clutch plate was slipping, replaced clutch & pressure plate, flushed engine.
132121
Reply By: OLDMAGPIE - Wednesday, Oct 05, 2005 at 19:25
hillsy, how did you go, did they tell you what the cause of the blockage in the radiator was?
133163
Follow Up By: hillsy - Monday, Oct 10, 2005 at 21:05
sorry guys been in
adelaide for a week just replying to all emails now the radiator was over 50% blocked with a white powdery substance havent tried it up the range yet but i think it will be ok now.regards hillsy
388122
