Problems with Challenger gearbox
Submitted: Wednesday, Sep 28, 2005 at 15:20
peter g
I have a 2003 Mitsubishi Challenger with a manual gearbox. From the day I purchased it new, it had gearbox bearing noise whilst idling which developed into a loud rattle. Afte two years of fighting with Mitsubishi, they finally agreed to replace the gearbox. 8 months later I find the same noises developing as
well as a shudder in the clutch when the engine is cold after standing overnight. Has anyone had a similar problem and if so, what has been the end result? My warranty is nearing expiration and I can see the same battle with Mitsubishi recurring.
Reply By: Member - Reece C (QLD) - Thursday, Sep 29, 2005 at 08:17
Peter,
Is you Mitsubishi Challenger a Diesel engine model? if so it is not uncommon to have a gear rattle at idle and the noise go away after the clutch is disengaged, if it is a gearbox bearing it usally will make a noise in 1st 2nd 3rd go away in 4th and return in 5th, 4th gear is direct drive through the transmission and therfore puts less load on the bearings and hence the noise goes away, as for the shudder in the clutch may due to oil contamation, bad pressure plate Diaphram/ Springs or hot spots on the flywheel and pressure plate.
132290
Reply By: peteC - Thursday, Sep 29, 2005 at 12:16
peter,
A friend had exact same issues. gearbox replaced, and went again. He traded it in on a commodore a few weeks ago with the crook gearbox. Only problem he had was that no dealer was really interested in trading it ( they didnt test drive it either so may not have known of the current status). The dealers must also know of the issues.
132324
Reply By: cookie - Friday, Sep 30, 2005 at 10:58
I have had a 98 challenger for around 3 years now. Bearing noise at idle is common and has been the same the whole time I've owned
mine. Search archives there is some stuff there, common on challenger and triton, noisy thrust bearing which doesn't seem to lead to any problems. A loud ratlle may be a different story. I live in the north west of WA and have given my challenger plenty, recently completed
Gibb river road including
mitchell falls and vehicle performed as
well as any others. The gearbox is actually from the canter light truck so it should be pretty strong. I've had some problem with 2nd gear when cold, not a big issue in the
Pilbara.
132479
Reply By: Member - Camper (SA) - Saturday, Oct 01, 2005 at 23:10
I agree with Cookie. Our Challa has the same noise. When I asked the service manager about it he said he could fix it for a bucket of money but that the problem would return. Seems that they develop a bearing "rollover" noise which does not develop into problems. Ours has not gotten any worse (except when I feel especially paranoid).
Camper
132657
